Hydraulic diameter of turbo piping
Why rob yourself of horsepower for no good reason?
I do plan to do some analysis using Solidworks Simulation once I get some routing decided to see some numbers.
I think to really take advantage of it, it may need to be extruded.
The stuff about turbulence and friction loss are kind of irrelevant, such as if a 2" round pipe is sufficient or let's say ideal even and that has a cross section of 6.28"; you fab up a rectangular-ish pipe that's 4" x 1.5" which is almost same cross sectional area but for example and easy math say it's also 6.28". So you have some extra loss because of the shape and the bends or extra bends needed, then you simply need 4.1" x 1.6". that would be no different than needing a 3.1" round pipe over a 3". And don't forget after all this piping is the throttle body with a big ol' throttle plate blocking airflow.
