Modifications Necessary To Use Gen I Rods
Shane
I am aware of the piston compression height. I did actually find an off the shelf unit that will work. I've got an LS6 and will be using the stock stroke along with the 6.25" rods. I need a compression height of 1.179. Probe has a piston for a 3.900" stroke and a 6.125" rod. It's part number is 14228-PS-C373. It shares the compression height that I need.
My question is actually based on the modifications needed for the rod itself. There is something to do with correcting the off-set of the SBC rod and the fact that SBC rods are chamfered at the big end and apparently LS rods are not. It's these type of issues that I'm questioning.
I was reading in engine masters about Robin Lawrance's LSX build for that nova and he was originally having problems with scalloping of the bearings due to crankshaft deflection. To correct the problem he dropped the stroke down and brought the motor from a 454 to a 434 inch motor and had a custom crankshaft built that utilized small chevy 2.100 rod journals for added strength.
Anyhow maybe that will give you something to look into. As far as the chamfering goes a chamfered rod can go on a non chamfered crankshaft but not vice versa. But the bearing itself is what you have to worry about most. P series bearings are for normal stock style crankshafts and H bearings are for your better aftermarket style cranks utilizing .125 fillets for added strength.
Shane
Shane
