LS2 TB Butterfly Axle...
My intent is NOT to machine, grind or modify the body of the Throttle-Body...just the butterfly axle...as on the pictures here (or similar)
My concern is with the electronic of the butterfly command on the LS2 Fly by Wire TB.
To access the axle I need to dismount the four screws visible on the pictures below...and I have no clue of what I am going to find when I will take the top off...
Appreciate all the help.
Thanks in advance
Christian
Thanks in advance
Christian
FWIW, you can do all that while it is still in the TB. I did that to a 78mm DBW TB. A dremel comes in handy.
