Formula for exhaust density relative to temp.
PV=mRT
but you probably want
P= Density*(R/M)*T
Again you'll need the specific R and M for the mixture
If this is your true question, you can only answer is you are in one specific location and the weather condition stay exactly as it is when you capture your first reading.
Dew point, humidity, elevation and temperture determines the A/F at a given moment in time.
I have a closed loop system that manages my A/F ratio via dwell time thru my injectors.
It changes so fast it's unreal.....
To help you, please provide what result you are looking for.......
