Advanced Engineering Tech For the more hardcore LS1TECH residents
porting cylinder heads = better mpg
Old Apr 28, 2015 | 07:32 AM
redtan's Avatar
Maybe I'm the only one who's done an h/c/i with ported heads and actually gained MPGs on the highway. City is a different story alltogether, but on steady state driving my efficiency has gone up (and verified)
Old Apr 28, 2015 | 03:56 PM
thunderstruck507's Avatar
I just swapped from an LS1 with barely touched 799 heads and 230/238 cam to an LS2 with fully ported 799 heads and a 230/238 cam.
Went from 19-19.5 average MPG to 21mpg so far similar driving conditions (all highway). Time will tell if that gain continues to present itself.
Old May 28, 2015 | 02:32 PM
musthaveLSx's Avatar
Originally Posted by HAZ-Matt
I bet this is the best answer.
As far as fuel economy is concerned, you are principally concerned with lower flow, relatively low throttle, higher vacuum states. I don't see how you can presume that porting the heads would actually improve the efficiency of filling the cylinder in this state.
If you want to imagine that the improved flow means that you get more VE and more power at low throttle and that somehow translates into efficiency, I do not think in this scenario it is necessarily the case. Say I want to cruise at 60mph. That will take a predetermined amount of power. Perhaps that is at 10% throttle on whatever stock car. If porting the heads increases the flow at 10% throttle (which it very well may not) and whatever vacuum then all that will happen is that you will end up using 9% throttle with perhaps more vacuum to make the same amount of power. The higher vacuum from the closed throttle blade may in turn rob any of the efficiency you have gained. In addition, the point about fuel atomization and swirl is important. What is your ported head going to do to those variables?
I do not think that you will find that the porting really improves cylinder filling in a way that results in greater efficiency. If you look at AFM (formerly Displacement on Demand) the whole way it get's its limited efficiency gains is by cutting half the cylinders so that you can run the same RPM but with a wider open throttle blade and less vacuum, which means more efficient cylinder filling for the remaining cylinders.
This is the correct answer to the OP IMHO.
Old Jun 1, 2015 | 08:31 PM
Kip Fabre's Avatar
G
Originally Posted by bp944
I was wondering if porting a 5300 vortec cylinder heads would actually improve mpg? If there's more air coming in with less throttle therefore less gas used or is my logic off?
If you make the exhaust port better it could help. You may need to change the cam to compliment the new exhaust port. The combustion chamber could be ported/reshaped to help combustion which could lead to lower timing making the
Engine more efficent😊 = better MPG so to answer your question yes it could help.
Old Aug 11, 2019 | 05:35 PM
Stephen Grant's Avatar
In the last 50 years i've had some good powerful mpg motors and you can study their specs, '67 Galaxy 302 2brrl 21mpg., '71 Newport 383 2brrl with electric retard/advance 26 mpg highway 9:3:1. '72 New Yorker 440 19 mpg highway 4brrl., '69 Polara 318 21mpg, '68 coronet 500 426 2x4 7-9mpg. But then I was filling up a 20 gallon tank for $6.75. I have a 99 burb now, 383 blueprinted and i get 22-24 stock, pistons are wpc coated and the rear gears are ceramic coated. Looking at the 5.3 LS (325c.i.) there is nothing you can do to improve the heads and the 2019 Suburbans are getting upwards of 28.5 mpg stock with a 6-speed. I'm sure with some high tech tweaks it will be close to 38. Sometimes headers will give 4-5 extra on a stock exhaust. You just never know what will do the trick. I changed the New Yorker over to Amsoil and it went from 12 to 19 mpg. There is a ton of friction, 50% more in uncoated rings, gears and bearings. Anything that gets more power to the pavement on stock fuel will get you more mpg and more kick in the pants.
Old Aug 11, 2019 | 05:58 PM
The best mpg improvement would be to blend the bowls and polish,polish the intake, gasket match, very carefully. Do not open them up. Maintain .035- .040 quench!. On Iron heads polishing off sharp spots and edges to avoid detonation and unburned pockets of fuel. The Flame front travels in a straight line. On LS heads you might have only to blend the intake seat and bowl but they are near flawless out of the box like a R07 head but the rotating assembly is a good 30-80 grams off!!!!. That said, I'm glad i wont have to polish anymore iron heads!!!
Old Aug 11, 2019 | 08:31 PM
Good stuff Stephen! I own a 2004 Tahoe with 5.3 LM7. About 9.5 compression, 290HP (I think), 2WD w/4L60E, 3.42 rear gear. Granted it has the aero of a smooth brick, but if it gets more than 19 hwy it would be a miracle. I'm going to put a better exhaust and possibly a CAI on it, but long term I would like to increase compression to an 87octane-friendly 10:1 and put in a cam with an earlier IVC and slightly narrower LSA. Cam Motion has a few that way. Modded as above, mileage can only go up. Am I on the right track?
BTW I just got it 2 months ago, and THINK it has full synthetic or synthetic blend in it, but next oil change it WILL get a good full synthetic.
Old Aug 12, 2019 | 04:07 AM
you should be able to get 24 without opening the motor if its a FLEX. LS heads are matched well with the pistons, much better than a 5.7. I would go to 10.5.1 with those aluminum heads
Old Aug 12, 2019 | 10:11 AM
It is not a flex fuel, being an LM7. The L59 is the flex fuel 5.3. Besides exhaust and air intake, what else can I do besides a good tune?
Old Aug 12, 2019 | 10:40 AM
Kfxguy's Avatar
You put amsoil in and it went from 12mpg to 19mpg? So you picked up 7 mpg from oil? lol
Old Aug 12, 2019 | 10:54 AM
Kinda doubt it...
Old Aug 12, 2019 | 11:16 AM
  #32
Kfxguy's Avatar
Originally Posted by G Atsma
Kinda doubt it...
Well I didn’t wanna say something smart ***. But I did laugh when I read it. Because it is quite funny.
Old Aug 12, 2019 | 12:20 PM
  #33
Well I didn’t wanna say something smart ***. But I did laugh when I read it. Because it it quite funny.
I can see maybe 1 or 2 from just the oil, but not more, unless anyone else here knows different, AND can prove it.
Old Aug 12, 2019 | 01:42 PM
  #34
Kfxguy's Avatar
i agree. maybe 1 mpg if you are using crap oil that is way past time to change it. but 7mpg. ummm, no.
Old Aug 13, 2019 | 10:28 AM
  #35
psicko's Avatar
I'll take "Bullshit that Never Happened" for $500 Alex.
Old Aug 13, 2019 | 11:33 AM
  #36
LOL!! Good one!
Old Sep 27, 2019 | 08:04 PM
  #37
gderian's Avatar
Part throttle fuel economy is gained by reducing pumping loss. Closing the throttle to reduce torque for cruise causes high intake vacuum. The engine has to work to pull air into the cylinders. This harms efficiency. Non throttle means to reduce torque improves fuel economy. High valve overlap to dilute the air with exhaust, big EGR to also dilute the air, retarded cam timing, tall gear for low rpm, lean fuel mixture are all strategies used to improve fuel economy. Porting has nothing to do with any of these strategies. DOHC engines with double cam phasers add a lot of overlap at part throttle to reduce VE. LS engines with a single cam are limited to retarding the cam at part throttle.
Old Oct 2, 2019 | 10:49 AM
  #38
LT-4Play's Avatar
We recently built a 5.3L for endurance racing - we had Cam Motion spec us out a cam and we tweaked the heads a little - blended the intake ports and touched up the exhaust ports a little - but for the most part we left the heads as cast. I have to say I was amazed by the results.
The same car previously had a real torque monster LS7 installed with LS3 heads and it was designed for sprint races. We could only run that combo for about 45 minutes with a full tank of gas (I think during competition we were getting around 4.7 mpg). With the 5.3 designed and tuned with fuel economy in mind we are able to run for 1 hr and 15 min and we are averaging around 7 miles per gallon during competition. Granted the drivers are not running as hard (a lot of short shifting and coasting where we can) but it's still amazing to me to add 30 minutes of run time.
