Advanced Engineering Tech For the more hardcore LS1TECH residents
big snout vs small snout?
Old Nov 5, 2010 | 08:24 AM
bp944's Avatar
Default big snout vs small snout?
Can someone explain why some racing cranks have a big block snout on a LS crank? What is the advantage to that? Can is still be setup normally? I'm also wondering can a R07 crank fit into a Ls3 block since the R07 is based on the LSx blocks? All of the main journal, rod journal sizes match up but I'm not sure about everything else.
Old Nov 5, 2010 | 11:30 AM
venom99's Avatar
it has to do with wet sump and dry sump i think but don't quote me on it
Old Nov 9, 2010 | 02:45 AM
matty169's Avatar
Default snout
High RPM longevity is why the big snout. It is just stronger.
Old Nov 10, 2010 | 05:20 AM
LSPerformance's Avatar
RO7 crank won't fit, bore spacing different.
Old Nov 10, 2010 | 03:53 PM
Callies Performance's Avatar
The bigger the Snout the more stout! This set up first became popular with small block cranks, and has now gained popularity in the LS world. With the gains in power and the added force to the snout, the thicker post is needed for durability. -Adam @ Callies
Old Nov 28, 2010 | 07:04 PM
gluon's Avatar
Small block snouts can snap right off on blower motors. R0X is small mains and 4.500" bore spacing.
