Advanced Engineering Tech For the more hardcore LS1TECH residents
vats
Old Jan 7, 2011 | 05:32 AM
gcouse7's Avatar
Default vats
A friend of mine has a stock 96 trans am, lost his keys, had one made up without the black insert in the key. Car will turn over but will not start. He said it was running with the new key but ?. My question is; Without the vat, will the car turn over or not? I thought that without the specific key the car would not even turn over. thanks
Old Jan 7, 2011 | 04:25 PM
gcouse7's Avatar
Default vats
There are some real smart people here, just looking for one. Thanks in advance for your help.
Old Jan 7, 2011 | 11:20 PM
Speartech's Avatar
9 Second Club/LS1TECH Sponsor
VATS is split into two parts; the crank enable thru the BCM, and the injector enable thru the PCM.
If the system is working properly the car shouldn't crank or start with an incorrect key pellet.
The car can be modified on either part or both to get around VATS. If the BCM side was modified (starter relay disconnected from VATS) then car would crank, but not start.
__________________
91 Z28 LS2 408CI, LS9 Supercharger, LPE GT7 cam, Yank3000, 3450 raceweight.
Latest numbers: 9.71 ET, 141.42 MPH, 1.40 60' , 610 RWHP Mustang Dyno
www.speartech.com
Old Jan 9, 2011 | 02:55 PM
gcouse7's Avatar
Default vats
Thank you.
