Advanced Engineering Tech For the more hardcore LS1TECH residents
@@ Lobe Dynamics @@
Old Jul 13, 2011 | 10:30 AM
racer7088's Avatar
I would not use the LSK unless you have light valves and a really good spring.
Old Jul 13, 2011 | 12:33 PM
87silverbullet's Avatar
Ya'll are making start to wonder. I was spec'd LSL's with a stock LS3 valvetrain just upgraded springs.
Old Jul 13, 2011 | 01:07 PM
racer7088's Avatar
The hollow stem LS3 stuff will work with that fine with good springs.
Old Jul 14, 2011 | 10:09 PM
A.R. Shale Targa's Avatar
I remember reading somewhere on here that EPS lobes while ground by comp
were uniquely designed by Geoff and Pat G....can any one verify this ????
I looked real closely @ my baby EPS to see if I could understand what was
different about it and the opening flank looks aggressive and fast like a LSR
shape, but then the closing side sorta looks gentle so as to set the valve on
the seat and not drop it....perhaps a HUC shape. Geoff reitterated many times
about "smooth control...like a stalled auto; not an M6 snap"......then I remembered all the threads I read when cam searching about quiet valvetrains
and killer power w/beehives, etc....I know I'm just rambling but relative to this
thread kinda makes me go Hmmmmm.
Old Jul 14, 2011 | 11:37 PM
01ssreda4's Avatar
The LSG lobe is EPS's lobe. G stands for Geoff I suppose
Old Jul 15, 2011 | 12:49 AM
JS01's Avatar
As far as I understand it, the only person that actually designs lobes at Comp is Billy Godbold. When you want your own lobes made you just tell Comp what kind of properties you'd like them to have and he engineers them for you. Definitely not cheap.
Old Jul 16, 2011 | 06:52 PM
Advanced Induction's Avatar
Lightbulb
Originally Posted by LSOHOLIC
Hello there, I've been searching for a thread or post on LS engine lobe tech. And it seems there nothing out thread, so I figured I start one.
For me, I'm some what tech savvy but could still stand to learn more about the secrets of lobe dynamics.
Just to be clear, I'm only interested in hydr. roller cams.
My question is; has any one put these different lobe designs (with same; INT Open, INT Close,EXH Open, EXT Close, and with all other specs being equal ) in a cam doctor to check ramp rates at specific areas (.006, .050, .200, ect..).
I'm really interested in the new HUC lobes but theres not much info floating around.
Thanks...and I'm looking for an education..
There really aren't any "secrets" per-se in our experience. The overwhelming majority have nothing to go by other than claimed durations in a lobe catalog. Those claimed or design specs are so vague as to be nearly useless when it comes to making comparisons. That being all most have to work with tends to create a great deal of speculation, misinformation, and perceived mystery. Claimed catalog specs are so ambiguous that the common interpretations based on them are often 180deg opposed to the reality of the lobe or series. As it pertains to the common GM LS1/LS2 valved, stock rocker, OEM lifter, & 5/16" PR setups there are lobes assumed to be mild that are actually anything but, and lobes assumed to be aggressive that are better choices than the "mild" lobes in that particular application. It only takes a few guys repeating a talking point they feel sounds correct or realistic for it to become a viral assertion and thus an internet "fact."
Most guys asking questions like this are attempting to determine what they are trading for performance, but with only vague generalities to go by it is rare that they manage to choose an appropriate grind based on forum claims. There are so many ways a lobe can be aggressive or mild depending on the remainder of the valve train system that your best bet is typically to do as you mentioned & find someone to determine what is appropriate for your specific setup & intended use. Lobe "aggressiveness" not only varies from lobe family to family, but also between various areas of the individual lobe. That is compounded by the fact that often times not all lobes in the family exhibit equivalent velocity/accels/jerk/etc, have slightly different operating ranges, etc. Furthermore, "aggressive" and "mild" are also relative terms and require a point of reference to be meaningful.
Originally Posted by Hemi2Slo
Ha I've noticed on here that a lot of the folks that know a lot don't wanna share their knowledge, they just wanna say "do a search" or just don't post.
Very few have actual data on various lobes/systems/etc. It also helps sell cams if you perpetuate the myth that lobe design & cam selection is akin to black magic.
IMHO, there should be a sticky on ongoing data pertaining to lobe tech. Because inevitably thats what seperates the players from the wannabes (in terms of camshafts).
Lobe 'technology' is largely a marketing idea/term IMO. I have begun to put together some cam info on our revised site that attempts to point out what we think the average consumer should consider vs. the common vague talking points. It touches on the common "technology" talking point: http://www.advancedinduction.com/LSX...BilletCams.php
Originally Posted by WKMCD
Why only hydraulic lobes???
Some people run solid lobes with hydraulic lifters.
Don't even think about doing it they other way around.
While it is certainly common to run a hydraulic lifter on a "solid" lobe, it is also common to run a solid lifter on "hydraulic" lobes. It is no more inherently precarious than the former situation - both require careful selection & application in our experience.
Generally that is how new designs are come up with. A customer will typically request something be made either for a specific application, or a line of lobes be made so they have something unique to sell. You can specify particular limits to specific characteristics, but very few have the data to even begin to do that. More often than not new lobes are only minutely different from existing catalog designs. While the performance value is often low, the marketing value of something new is typically high. That being the case, paying for "new" or proprietary lobes can be worth doing.
Beyond that, one can employ some of the same tools & software to come up with profiles for a particular system that do offer a performance advantage. Our proprietary grinds were refined/created based on simulations & testing w/ existing known good cam grinds. I used 4sthead which many cam companies, race teams, etc. utilize. There isn't a great deal of info on their site, but http://www.profblairandassociates.com/index.html does have some tech articles you may enjoy.
In the end, there being thousands of lobes out there, it is rare that it is actually worth creating a new lobe design. Additionally, getting a theoretical system "perfect" is simply beyond the point of diminishing returns for cams sold to the public. With no control over their implementation I personally ended up with so much headroom (safety margin) that almost invariably there was a readily available suitable lobe for a given application. We are typically supplying camshafts with our heads, and with a superior head design it does make it easier to simply back things down a notch & rely on the head to get the results. The power is in the head/manifold & machinework... while your valve train will largely determine the reliability/longevity of a given setup IMO. In the end, almost all common lobes can be made to run reliably if the rest of the VT is appropriately selected, installed, and adjusted.
Erik's comments are a good example of what I am talking about - the LSK's work OK for many people, but a milder lobe sacrifices little if anything considering the longevity, rpm headroom, etc. it may gain. That is the kind of mentality you want your builder to exhibit when it comes to engines that have to live awhile.
I think most would be surprised at how similar most of the commonly run LS lobes are. I realize this is tough to really read, but it illustrates the point:
Still, there are distinct advantages and disadvantages to them. To further muddy the waters, consider that those graphed are all similarly styled. There are many different styles of lobe out there.
In the end I think you'll find that the only truly useful info for the consumer is the link to our cam page. However, these discussions are certainly engrossing.
-Phil
Old Jul 18, 2011 | 12:05 PM
Tireburnin's Avatar
How do you argue with a graph like that? Why would anyone run a cam that is so much mroe agggressive, yet yields little gain.
I like my valve springs to stay in one piece for a long time.
Old Jul 19, 2011 | 06:20 PM
Smile
Well, some people don't mind the trade off for a few extra hp, or the same power w/ slightly less low rpm trade off. I believe the most likely explanation is that many simply don't know what the trade off will be. Dyno #'s at 0 miles sell parts. It's all a compromise & this being the aftermarket, there are no guarantees.
Old Aug 21, 2011 | 02:57 AM
LSOHOLIC's Avatar
I hope this question is not to generalized;
If my valve train is relatively light....
1)Intake valve..high 70's...grams
2)Exhaust valve..high 50's...grams
3)PRC .675...Install Height: 1.800"
Closed Spring Pressure: 157lbs @ 1.800"
Open Spring Pressure: 471lbs @ 1.125"
Maximum Spring Lift: .675"
Coil Bind 1.060"
Spring Rate: 483lbs/in
4)Comp Ti retainer..high 50's...grams
5) stock locks..3...grams (x16)
6)stock rockers..low 80's...grams + weight of trunnion....with the rocker arm trunnion supported and the tip of the rocker on the scale. Scale zeroed prior to measurement it measured 8.3 grams.
Is this cam optimal considering what was said about the LSL/HUC lobes ??
CAM
(LSL) INT. 235@.050 (HUC) EXH. 247@.050
Lift INT.=.620 w/1.7 EXH.=.632 w/1.7
Or would I be better with a "faster" ramp considering the lightness of the valve train ?? Or maybe I should first ask if you consider this a light setup ??
Thanks.....
Old Aug 21, 2011 | 11:12 AM
FlamingTA's Avatar
Coil Bind 1.060"
CAM
Thanks.....
What is your intake valve?
I would think you would be just fine on the LSL lobe.
Old Aug 31, 2011 | 11:31 AM
  #32
Smile
Coil Bind 1.060"
CAM
Thanks.....
Your masses appear off to me. You can run any lobe with any spring for the most part, the question is what kind of RPM will it control the valve train to, will it be hard on specific parts etc. That is quite a bit of spring load - the LSL's are typically controllable to 6800-7200rpm with far less spring & the HUC's even more so. If you were staying with Comp, you could move to one of their higher lift series lobes, but if they're in the same duration range it won't likely make a large difference in output vs. the LSL.
Old Sep 3, 2011 | 06:08 PM
  #33
LSOHOLIC's Avatar
Just your typical 243...2" hollow stem intake 73 gram valve.
Thanks....
Old Sep 3, 2011 | 06:10 PM
  #34
LSOHOLIC's Avatar
LS6: intake = 73 grams, exhaust = 65 grams ....not sure if that is what you were refuring to...and about the RPM..I'm spinning it to 6800-6900ish.
Thanks...
Old Sep 3, 2011 | 09:30 PM
  #35
macca33's Avatar
Some good discussion here.
FWIW, I ran a 223/227 Comp LSK cam in my H/C LS1, which made approximately 295rwkW (395hp) on an Australian dyno. When I changed lifters at around 40k miles of (mostly) highway use - steady 60-70mph - I found it had become a bit pitted on a couple of lobes. I was using Patriot Gold duals with Ti retainers and set up properly, etc and was revving it to 6800rpm.
I put a 223/227 Comp LSL cam in to replace it and made 3rwkW (4hp) less at peak and a little less torque, so not a great deal of difference - certainly not to a purely street-driven car. So, in my application, not a large trade-off, for a slightly milder lobe.
I think the LSL is a good compromise lobe, not as aggressive from .006 - .050 as the XE-R and not as aggressive from .050 - .200 as the LSK, but a fairly good compromise between the two.
In my current car, I'm using a 215/223 LSL camshaft and it is making some great numbers (better than the larger cams did!) and peaks at 6250rpm, with the rev-limiter set at 6600rpm - no need to wring it out at all.
cheers
Old Sep 3, 2011 | 11:05 PM
  #36
01ssreda4's Avatar
Pitted lobes sound like a faulty cam....
Old Sep 4, 2011 | 11:27 AM
  #37
JS01's Avatar
Not always, especially with lobes like the LSK.
Old Sep 4, 2011 | 04:44 PM
  #38
01ssreda4's Avatar
Well I know Comp has had some quality issues in the past.
Old Sep 15, 2011 | 02:31 AM
  #39
TurboAv's Avatar
HUC lobes on my cam. 7200rpm shift point. Good enough to make my 4000lb heavy beast go 11.5004 @ 118.8mph with a 4200ft DA.
Old Oct 28, 2011 | 05:44 PM
  #40
LSOHOLIC's Avatar
Found some interesting reads....that I thought you guys might like.....of course valve train based.
http://www.cds-valvetrain.com/Doku/Valve%20Train.pdf
http://www.tech.plym.ac.uk/sme/desnotes/valvet1.htm
And here is an interesting thread on the bullet about increasing base circles...and the effects.
http://www.yellowbullet.com/forum/sh...d.php?t=420668
Thanks...........
