2 turbos
exhuast drives the small turbo first, then drives the second bigger turbo.
Air comes in the bigger turbo first then goes to the smaller turbo then to the intercooler.
I run compounds on my cummins (12 valve), with three intercoolers as well.
A cummins is only 359 inches.....and it weights about 1200 lbs......the bore in mine is 4.020.
Find a gas engine that can hold up.....and maybe. I ve thought a 7, 7.5 to 1 motor might get away with it.....on methanol........and say 50-60 psi....
1320 that statement is not true there uis a guy in a DSM that is running a compount turbo with no problems...my eclipse was compound before i went to a large single for simplicity. I will find the thread for you...
My setup was close to his buy my first turbo was pointing up and the second one was below it similar to the cummins settup. but poor turbo choice and only using a SFMU for fuel management limited me so i went with a single and nitrous.
Your statement about gas engines not holding up it what I didnt think was true. Any built engine will be able to hold boost. thats all i was disagreeing and my eclipse was a 420A chrysler engine that i built up for boost with JE pistons Eagle H beam long rods and cams nothing spectacuar but enough that i could beat on it and not have to worry about pushing 25# boost through it and have the wastegate line come off like it did with a factory bottom end.... Ya **** hit the fan when that happened...
I think it was the old detroit diesels the military used were "twin charged"
Also there is plento of buick and pontiacs with 3.8 SC charged cars that they add a turbo on and make them beasts.
