Advanced Engineering Tech For the more hardcore LS1TECH residents
Main seal, labor ? --- Help
Old Mar 11, 2012 | 07:17 PM
johnp94's Avatar
Default Main seal, labor ? --- Help
How many hours is the norm for a main seal replacement. I'm leaking a ton of oil. A home mechanic is charging me $300.00 labor. I would give him more if the job takes longer than he thought. Also he completed job but it is still leaking the same amount of oil. He will now pull the tranny down again. Do you guys have any advice for him.
Old Mar 11, 2012 | 07:51 PM
johnp94's Avatar
the mechanic spoke with his buddy. His buddy told him he should not have used an aftermarket seal. He should only use GM seal ( gasket ). He will now get a GM replacement. Have others gone through this before.
