Air to Water Intercooler using gas?
NOTE
Another way to increase the efficiency of your general setup is to improve the pre and post turbo and inter cooler piping. This reduces pumping losses and restriction. A rear mount system has to much piping and bends. And the turbo has to work extremely hard to overcome this. There fore the turbo lacks it potential to build boost correctly. And increases heat. Rear mounts in my view are counter productive.
all of this is ignoring the fact that the fuel does not have the heat absorption properties that water does. Boiling point of fuel can be as low as 100 degrees.
the feasible way to use the fuel to cool the intake tract would be a standard A2W system modded to accept the high pressure fuel. it would work and probably work well as itd be lighter than a whole A2W setup. it would help also by slightly heating the fuel thus making it more easily atomized. i think you should go for it =). leak test EVERYTHING twice and then check again before starting.
Not only that but you would need to regulate it before the intercooler so the fuel was returned to the tank before it was heated up by the intercooler.
Even at max fuel flow at WOT you would have to burn through all of the hot fuel in the intercooler before it even started to see ambient fuel from the tank. What would the intercooler itself hold, half gallon?
In the end I think the only thing you would accomplish is heating the hell out of the fuel and nothing else.
