Female flare fitting bung ideas for aluminum fuel tank?
I'm building an aluminum fuel tank right now that I have elaborately over engineered. I've hit a small wall though.
I need to keep the fittings inside the o.d. of the fuel tank for reasons that are irrelevant. Problem is that; I don't want to use a fitting that requires sealant. I want a flare fitting. So, NPT weld in bungs are out of the question. All the female AN weld in bungs seem to be flare-less style.
Has anyone come across AN female weld in flare type bungs? Does anyone have another female flare type bung idea?
I want to stay away from sinking in a small box with male bungs. I've asked a few go-to people and haven't come up with anything for a flare type female bung. Searched the internet endlessly. Any solutions for me guys?
Need a bit of clearification on this one.
There is no such fitting that is AN in a Female end. In a standard AN application the female end is made up of the Tube, ferrel-sleeve, and Nut.
That's what I always thought, I was hoping there were specialty fittings or something.
The perimeter of the tank must stay flush due to mounting concerns. This is fixed, I can't change the way the tank mounts into the car.
I need the face of the fitting to not protrude past the perimeter of the tank.
The cleanest most reliable thing I can think of would be a female flare fitting welded to the inside of the tank. Then screw a male adapter into that once the tank is installed.
I just want to stay away from say a female NPT bung because I have never had good luck with any sealant being submerged in gas.
In short, I don't care what kind of female fitting it is. As long as it does not require sealant on the threads for a complete seal. I would like to shy away from o-ring fittings as well but I'm sure they would probably do the job.
Right now my options are looking like:
A: Use a female AN bung meant for o-ringed fittings.
B: Sink a small "box" into the side of the tank with male AN bungs in it, in a fashion where the face of the male AN bung is flush with the perimeter of the tank.
I would pay to have a female flare bung machined if any sponsors would be interested?
Next option would be to start of with a MS type bulkhead fittning and then transition back to you AN. Bit more work with more parts.
Look here might see something you can use.
Look here might see a option. http://www.gen-aircraft-fittings.com/
Just weld in a AN-threaded bung and use a fitting with an o-ring, same as all the Aeromotive stuff.
Or weld a flat plate into the tank and drill/tap with the appropriate thread so you can screw in a male fitting with an o-ring seal. No different than screwing the fitting into a fuel rail, regulator, pump, whatever.
