Advanced Engineering Tech For the more hardcore LS1TECH residents
Suspension Geometry & Weight Distribution
Old Aug 28, 2012 | 01:28 AM
SS10Tech's Avatar
Default Suspension Geometry & Weight Distribution
Would like to really bat a few ideas around with others and see what technical data is out there - ive been chewing and researching on this for months and cannot seem to come up with any tangible connections as to why some spring-rate, wheelbase, and weight distribution setups simply work better or worse than others. Similarly, how some people have very similar setups and wheelbases but one launches like a rocket and the other requires a wheelie bar and serious driver abilities.
Suspension geometry ranges from ladder bars to 4 links. Ideally getting the rear to squat is what hooks at the track - but i've even seen it on 275 tires and just dont get it.
Weight over the nose of a vehicle, wheelbase, soft or hard launches with gearing, transmission selection/boost control, lightweight tube chassis frames, solid box frames, and many other theories or applications of design exist, but i do not see a real connection that deals with one or the other that directly effects the hook at the track as a single variable. Elimination of frame twist and other things come into play as well.
I know i have heard talk of finding the center point of balance in the car and adjusting it, but adjust to what reference? Tire or calculated center of gravity? What other variables exist? Literature to recommend for reading? Is it simply the knowledge of tuning coil rates?
Tim Lynch's team has always pushed the limit. Would really like to know what theory and knowledge exists on the subject and what to look out for or tune for with a build.
Old Aug 29, 2012 | 04:59 PM
paq's Avatar
paq
I'm in for the dicussion! It should be interesting!
Old Aug 30, 2012 | 01:38 AM
SS10Tech's Avatar
I would believe a lower center of gravity would help as well - getting your car as low as possible and removing top-heavy components could make it handle better as far as top end response and stability might be concerned - just something else that comes to mind.
Topic does not seem to get much love - its black magic knowledge
Old Aug 30, 2012 | 11:40 AM
mark21742's Avatar
Also if instead of squating the rear end the suspension forces the rear of the body up in the air pushing the tires into the ground....this is how to get the best launch
Old Aug 30, 2012 | 10:30 PM
SS10Tech's Avatar
Removing the front sway bar in favor for the rear sway bar is a must it seems?
I also know a common trick is to put in a 1x1x1 steel bracing bar at the front of unibodies - it is something i have seen in monte's and g bodies a few times. I wonder the difference it would make compared to without or with the front SB?
And there is another topic in itself - unibodies versus solid frame platforms for certain ET's
Old Aug 31, 2012 | 06:12 AM
mark21742's Avatar
A huge thing you could do is subframe connectors and a 12pt cage...that would make a unibody insanely stiff. When I started to do the 4 link in my 04 GTO I ran 2x3 tubing for the main chassis, then ran a modified 12pt + cage to make the car stiff as possible.
Also set the four link pointing up from under the axle towards the center of the car...this way it pushes the tires into the ground when it launches.
Old Sep 2, 2012 | 04:31 PM
SS10Tech's Avatar
Any correlations to wheelbase length versus weight/balance?
Old Sep 3, 2012 | 10:41 AM
mark21742's Avatar
With a longer wheelbase you can shift more weight to the rear tires without lifting the front tires in the air
Old Sep 3, 2012 | 05:07 PM
GIMPY02's Avatar
some x275 cars ive seen and worked on have had a 10 to 15% more weight in the front. we can hit the tire harder and allow the car to 60ft better.. let me tell u though it doesnt always work that way.. every track is different and to be honest we change it alot.. it all depends on track conditions.. you go to a track that has alot of bite we shift weight forward and hit it harder. less bite we move it towards the rear and take some power out if its needed to keep from going otb.. as someone stated b4 u want the body to lift and force the rear end into the ground... squating is the old school way of getting a carr to work. not saying its completely wrong its just not how people are getting these cars to 60ft as hard as they are now adays
Old Sep 3, 2012 | 10:32 PM
cainsw's Avatar
Gotta follow this one
Old Feb 10, 2013 | 08:28 PM
South's Avatar
How would adding a Ford 9" effect the weight distribution? Would this bring the caar close to a 50/50?
Old Feb 11, 2013 | 12:47 AM
Wnts2Go10O's Avatar
i was typing something out but i found some better info. read:
http://www.hotrod.com/techarticles/c...tire_traction/
not just the chassis itself plays a role... the type of differential, aero, etc all come into play.
Old Feb 11, 2013 | 03:01 AM
mark21742's Avatar
I did not weigh my whole irs and all its parts, but the 9" is lighter than the old irs...in my case I'm not completely sure how you would calculate the change, because 90% of the irs system was part of the unibody and sprung weight, whwre the 9" is unsprung weight.
Old Feb 11, 2013 | 03:44 PM
Wnts2Go10O's Avatar
it also transferred weight differently than a solid axle
Old Feb 16, 2013 | 06:37 PM
mark21742's Avatar
Every irs ive driven including mine the rear of the car wants to skate out to the right.
I found the best thing I did to mine for weight transfer was to move the engine back a foot
Old Mar 6, 2013 | 07:30 AM
Blackpanther99's Avatar
Soo how better was your launch with the 4link and the 9" swap?
Old Mar 6, 2013 | 10:36 AM
mark21742's Avatar
Gutted the car and still trying to finish the wiring do I can drive it out of the garag lol
I built a full tube chassis, moved the engine back 12.5"s, dropped ton of weight, and went from "stock" size tires to a set of 15x 18" wheels and 33-21.5 15s in the back, so I hope to be able to launch strait and put it hard on the wheelie bars.
Old Mar 11, 2013 | 11:58 AM
Ahh I see. Will be very interesting to see the results!
Old Mar 25, 2013 | 12:10 PM
mark21742's Avatar
Its been well over a year now since I drove the car and I can not wait to get it back out and test it when its done lol. Atleast the car is back in the garage again!
