Advanced Engineering Tech For the more hardcore LS1TECH residents
Ls awd swap?
Old Dec 27, 2013 | 01:44 AM
MorePower37's Avatar
Default Ls awd swap?
Before you guys hate on my yes I am asking about an engine swap and yes I am using ls and awd in the same sentance. I was wondering if it was possible to swap an ls motor into an awd car. What cars would be good for something like this? Is this even possible in the first place? Could I turbocharge/supercharge my engine in the future? I realize there would have to be custom work done but that would be done by a performance auto shop. I would like to do it own ny own but I think it would be too much work and require too many tools. Let me know what you guys think.
Old Jan 1, 2014 | 08:04 PM
ayousef's Avatar
I cant see why its not possible, everything is possible more or less. We have 4wd LS motors in trucks that we take to 1000+ hp, there are also AWD truck transfercases that have also seen that kind of abuse.
Old Jan 5, 2014 | 02:43 AM
Yeah your right anything is possible with enough money but I was trying to get some ideas flowing on how the project would go. I don't want a truck but swapping a transfer case from one along with its ls motor would be a good idea. What coupes/sedans would be good for something like this?
Old Jan 13, 2014 | 04:24 PM
Kbodls1's Avatar
Well first off you need a list of awd cars, then pick what ones you think would have enough room for a ls. I was thinking about this very idea on my way home the other night, for me it would be the Acura TL (I know...A HONDA??!!), get the SH-AWD. Big Car you could stuff the LS in and a good looking.
Old Jan 18, 2014 | 08:16 PM
dirty_old_chevy's Avatar
You should look for a wrecked awd CTS-v for swap parts
Old Jan 22, 2014 | 12:41 PM
raven154's Avatar
There is no such thing as an AWD CTS-V. There is an AWD CTS with a V6.
Old Jan 24, 2014 | 12:40 PM
AmishAssassin's Avatar
Default Solution
I was going to keep this under wraps but since I am forever lacking funds for a dedicated project car, I guess I will divulge a build I had plans to do. It will in theory work. Audi c5 A6 6 speed, there was a company that makes an adapter to bolt directly to the O1E transmission in the Audi. You would need a twin disk clutch and upgraded axles aside from that it should fit with the intake flipped backwards and the battery relocated to the trunk. Notch out the primary firewall to make it a functional air intake. I want to do this so bad it could easily be done for under 15-20K and you would have a very reliable comfortable car with great handling. I wanted to do it to a B5 but there is just not enough room as in the A6.
Old Feb 14, 2014 | 08:11 AM
chobes's Avatar
It's been done, here's motivation for you... https://ls1tech.com/forums/conversio...ect-judas.html
Old Dec 7, 2017 | 07:36 PM
imporericanHa4g63's Avatar
Thoughts on an evo 8 or awd 2g eclipse holding the monster swap with ls
Old Dec 7, 2017 | 11:49 PM
pdxmotorhead's Avatar
E46 BMW 330 XI. Has a 6 speed manual thats the same as the m3, the 2005 is the magic year it does not have a torque sensing center diff its fixed 60rear 40% front diff.
The challenge is merging the LS pan with the BMW front diff, in the BMW they are bolted together, unless a colorado 4x4 with the V8 does the same thing?
The 2005 also has a kinda neat engine mount that is a steel frame that bolts up to teh bottom of the car so fabbing a motor mount to it should be relatively straight forward.
Plan on just gutting the wiring, there are almost 100 fuses in the factory fuse box..
Old Dec 8, 2017 | 07:16 AM
TrendSetter's Avatar
i have an awd silverado, uses np149 transfer case.
an s10 can also be done with the typhoon transfer case (bw4472)
anything else that im aware of would be a significant undertaking.
Old Dec 15, 2017 | 03:14 PM
logic factory's Avatar
what is your goal with the project and why do you want awd?
i may have further questions for you pending your response. please try to be as descriptive as possible so i have more to base my follow up questions on.
thank you!
Old Nov 21, 2020 | 07:25 PM
Benjamin Jones's Avatar
Default Miata
I’m currently making an awd lm7 Miata rally car. I would higly suggest it although you have to raise it a couple inches so that the drivetrain clears because the engine sits so low. Either way Miata Is Always The Answer.
Old Dec 1, 2020 | 06:47 AM
what are you using for drivetrain?
Old Feb 23, 2023 | 12:45 AM
Catfish Prince's Avatar
Benjamin, what drivetrain/setup are you using for it?
Old Feb 23, 2023 | 01:23 AM
Benjamin Jones hasn't been around since Nov 2020
Old Feb 23, 2023 | 02:03 AM
aw man, im writing out an lm7 swap rn. WOuld be great to see if I can make it awd.
