Advanced Engineering Tech For the more hardcore LS1TECH residents
Coolant System Voltage
Old Apr 8, 2018 | 09:54 PM
kingtal0n's Avatar
And again, back to pH -- run water with propylene glycol, which won't go acidic, enough to get the boiling temps and freezing temps covered, a surfactant to improve heat transfer, and let her rip. Its the best way to handle it.
That sounds like my original statement , coincides with everything posted
Put distilled water in,
with enough coolant for the climate conditions.
/done forgotten
Lol great minds
Old Apr 8, 2018 | 09:57 PM
Originally Posted by kingtal0n
That sounds like my original statement , and coincides with everything I just posted
Lol great minds
He said PROPYLENE glycol. Coolant is usually ETHYLENE glycol. He did NOT reiterate your statement.
Old Apr 9, 2018 | 12:22 PM
Darth_V8r's Avatar
Moderator
That sounds like my original statement , coincides with everything postedLol great minds
Yup. It was actually my first post in the thread. AMSoil makes a propylene glycol coolant. The other cool thing is if you catch your dog licking some of it up, it will not kill the dog.
But I do agree we were basically saying the same thing. Almost violently agreeing.
Old Apr 9, 2018 | 12:23 PM
kingtal0n's Avatar
you know, I never stopped to consider any difference. to this, what is it now? propylene as opposed to ethylene? You are saying to use this instead? Care to elaborate its the first time I've heard of it and I'd rather you say than me using google etc...
Old Apr 9, 2018 | 02:35 PM
pantera_efi's Avatar
Default Propylene Glycol = AL
Hi Jake, yes I too support/use Propylene based coolant, AMS's Yellow.
My reason is more related to the AL Radiators/AL Crankcase/AL cylinder heads fitted in Racing Cars.
MANY coolants are MORE suited for use in Iron Blocks/Brass Radiators.
The more MODERN Organic coolant is NOT RATED for use in Brass Radiators.
Lance
Old Apr 9, 2018 | 05:14 PM
Darth_V8r's Avatar
Moderator
Pretty much what lance said. Ethylene glycol is a two carbon, two -OH group. Its almost like a two carbon sugar. Propylene glycol is a three carbon chain with two -OH groups. Its used as industrial antifreeze/coolant. Its also used in foods as a combination sweetener and emulsifier, and in shampoos as a "humectant".
Old Apr 9, 2018 | 06:25 PM
pdxmotorhead's Avatar
Peak antifreeze is prop glycol IIRC,, thats why its the non poison stuff.
Don't care what you use for a coolant,, if any water is present it will eventually react with metal and oxygen and make rust..
Only answer is to keep it changed and clean. One bit I have done which seems to help or at least I convinced myself it has,, is to put a good ground from each part of the motor that sees coolant, including the radiator to a common ground point. sometimes the vibration control on the radiator insulates it so it can become a anode/electrode in the equation.. YMMV
Old Apr 10, 2018 | 09:30 AM
Default Radiator Grounds
Hi PDX, GREAT TECH, the "grounding" of the radiator to the crankcase/head.
YES, this method will NOT allow the Coolant Voltage to be high.
AGAIN, too simple of a fix, too low cost to be important in engine life increases. (joke)
The PDX report, the first about Coolant Voltage Correction Method WON him a FREE set of E-3 SparkPlugs.
They will be shipped to you for free if you supply your address/heat range requested ?
Lance
Old Apr 11, 2018 | 01:32 AM
NSFW's Avatar
Where do you measure the voltage? From the block to the radiator?
With the engine at idle, or just with the key on?
Old Apr 11, 2018 | 12:11 PM
joecar's Avatar
Measure voltage between coolant (in radiator neck) and:
- engine block,
- vehicle chassis,
- battery negative terminal;
i.e. 3 measurements.
Then measure voltage drop between engine block and battery negative terminal.
Old Apr 12, 2018 | 11:00 AM
Default VE Labs Anaheim, CA.
Hi Joe, great report on measurement method.
I "strip" the insulation off a copper wire about 3", the probe used for the coolant side.
There is another report by, VE Labs in Anaheim, CA. with great tech about Coolant Voltage.
Summit offers Radiator Drain Plug Anodes.
Lance
Old Aug 8, 2018 | 10:45 AM
  #32
cam's Avatar
cam
As a man of many grounds, I have never had this problem. Add grounds, more the merrier
Even my boat motors which come with these OEM installed look like new. Grounds I tell ya
Old Aug 8, 2018 | 11:51 AM
  #33
I see you lead a well-grounded life. I try to...… lol
Old Sep 23, 2018 | 10:15 PM
  #34
nsaltwater's Avatar
I have an LS2 and an aluminum radiator. After about 8 years and only 5,500 miles, the aluminum radiator started leaking. When I pulling the radiator it was determined that most likely free voltage cause damage to the radiator. Installed new radiator filled with tap water (soft). Measured voltage from - battery to water. 0.6VDC. After turning on all accessories and lights on, I got the same measurement of VDC. Turn engine off, same measurement. Disconnect + terminal from battery....same measurement. I have not added any coolant yet but is seeing 0.5-0.6VDC “normal” without having the + terminal connected? The previous radiator always ran DexCool. I’m using a quality voltmeter. I have multiple grounds between battery, block, heads, tranny, body, frame and roll cage.
Any help would be appreciated.
Old Sep 24, 2018 | 03:02 PM
  #35
Default Radiator core grounding
Hi NSW, install a "ground wire" between the radiator CORE and the engine crankcase.
Lance ( GREAT REPORT)
Old Sep 24, 2018 | 11:33 PM
  #36
nsaltwater's Avatar
radiator. Manufacturer said not to ground because it would become a conductor upon doing so and that’s not what I want at all. The radiator is mounted in a rubber isolated configuration. Do you agree with this? What about measuring VDC with the battery disconnected? Is this telling me something I need to investigate?
thanks.
Old Sep 26, 2018 | 11:20 AM
  #37
Default Volta = battery = Rad/Engine
Hi NSW, Volta invented the Battery (1794) WITH YOUR OWN measurement of .6 Volts as stated, your application (Rad/Engine).
This is NOT good for radiator core life. (.6 volts)
I WOULD trust 200+ YEARS of proven "tech"
Lance
Old Sep 26, 2018 | 06:24 PM
  #38
nsaltwater's Avatar
Yes, I understand. I understand that .6VDC is bad. The question is how do I get rid of it? There is nothing attached to the + post of my battery. Other than the battery in the radio in the dash, there’s no other power source onboard. How in the heck do I get rid of this .6VDC. I’ve attached a ground from the battery to the water in the radiator and I still get .4VDC.
