Advanced Engineering Tech For the more hardcore LS1TECH residents
need help!!!!
Old Aug 29, 2017 | 02:11 PM
99silveradot56's Avatar
Default need help!!!!
I have a 99 Silverado rcsb 4.8 and I was looking to purchase a new t56 and my concern is it has a 31 spline output . can I just get a new slip yoke for a 31 spline that will adapt to my stock drive shaft . I know that sounds like a ford spline but the info on the tranny is for a ls t56 with 26 input and 31 output just woundering cause ive been doing my research on this t56 swap and its lol just let me know someone please thanks
Old Aug 30, 2017 | 09:50 AM
pantera_efi's Avatar
Default Drive Line Specialists
Hi Silver-*-, I work with Drive Line Specialists, a local shop in Irvine, CA.
This is a "chain" shop, a part of other franchised shops.
What is your area ?
American Powertrain ?
I have never had a driveshaft "yoke" problem as it is supplied when I buy a Magnum
I can supply the Yoke
Lance
Old Aug 30, 2017 | 10:17 AM
im located in Prattville Alabama , im going to a t56 from a 4l60e I believe that the yoke spline is a 27 on output and I don't want to buy a used tranny so ive been lookin and all the new tremec t56s have is a 31 output that I can find . is it possible to just change just the yoke that uses the same u joint as the stock 99 Silverado 1500 2wd rcsb that has 31 spline
Old Aug 30, 2017 | 12:47 PM
ive also seen a 31 spline yoke with 1310 u joint its hard to find out which u joint is in my drive shaft with me doin research , instead of the parts guys asking a bunch of questions and not having what I need to compare so if I knew what u joint I have then I can go from there in order to see what yoke I need for the tremec t56
