Advanced Engineering Tech For the more hardcore LS1TECH residents
brake specific air consumption
Old Sep 14, 2020 | 09:40 AM
MaroonMonsterLS1's Avatar
Originally Posted by NSFW
True, so don't **** that up.
If your injector flow rate is accurate, and if your wideband matches your target AFR, then you can be reasonably confident in your MAF curve.
It's almost like the air and fuel are directly tied to each other and you can use either for the desired calculation
Just playin
Old Sep 18, 2020 | 10:39 PM
NSFW's Avatar
Sure but if you want BSAC (as the OP does) and you're measuring fuel consumption, you need to multiply that by AFR. Measuring airflow directly takes one variable out of the equation.
