Need Help with my DCR/SCR
LS2 Block Bore: 4.010
Stroke: 3.622
Heads: PRC 227 Heads CCs: 56
Pistons: -10cc Dish Top, Compression Height: 1.330"
Heads Gasket: .051 (GM 6.0 Gasket)
Deck Clearance: 0.001 (3.622/2 + 6.098 + 1.330 = 9.239) LS2 Deck Height is 9.24
Connecting Rod Length: 6.098 (LS2/LS3 rods)
IVC @ .050: 45.5 [112-2+(231/2)-180]
Advertised PRC 227 Heads Flow:
Lift 0.200" 0.300" 0.400" 0.500" 0.600" 0.650"
Intake: 145, 214, 261, 300, 322, 330
Exhaust: 115, 167, 202, 219, 238, 236
Camshaft: BTR Stage 3 LS1/LS2 NA (33142122) : Specs @ .050: 231 / 242 .671 / .593 112+2
Using this calculator: Static and Dynamic compression ratio
SCR 10.78:1 DCR 8.86:1 - Not sure if I got the DCR right, and if 8.86 is safe.
Maybe I need to change out my cam?
Would this set up make good power?
Going into a C5 Corvette w/ a 3600 stall and 3.90 gears
The simple math calls for dividing the stroke in half (3.48 / 2 = 1.74 inches) and then adding the connecting rod length and compression height. This is then subtracted from the engine's deck height to find the deck clearance, which can be positive (above deck) or negative (below deck).
http://www.wallaceracing.com/dynamic-cr.php
Found the card for XER (found online), one of the cams above, so IVC is 74??
So if 74 is correct, based on my SCR of 10.78:1, my DCR is 7.91:1
Your dynamic is around 8.1-8.3 with the 231 cam
Will update this thread with the combo I select. I’ll be running the final build on an engine dyno, so I’ll share my results from that
We can’t assume dynamic as this is movement of air, and isn’t something you can assume without data of some type. None of that data is calculated by any ECM, other then straight AFR/EQ from VE. At best, this number only helps us guess the actual dynamic compression ratio. There is simply no way of knowing how much air a particular cam actually compresses under flow, aside from our VE with PERFECT AFR numbers. Even then, it’s an assumption considering scavenging and reversion are not factored in.
With all of the above, if you are playing with the compression limits on your fuel, there may be places in the RPM band where it’s completely fine, and other places where it will simply detonate. No confirmed number on 93, but all I’ve seemed to find on it hints at a 8.63:1 ECR. Above that and there will be issues. Since DCR technically cannot be calculated, I’d keep the ECR well under that number to be safe. My 427 Camaro is at 8.51:1 and I have had to reduce timing significantly to eliminate knock on that particular motor. Even N/A, timing is as low as 14 on ramp in, and up to 18 WOT.
Now for that second number you are referring to, that is called Boost Compression Ratio or Final Compression ratio. That number uses SCR to be on the safe side. 12:1 is a typical safe range for pump gas with no other mods.
And yes, the 8.63 ECR is for high compression N/A motors typically, since your static has to be pretty high in order to hit that number. It’s not the end of the world if it’s exceeded, as all of these depend on a lot of outside factors, like IAT and ECT, materials, AFR, timing, etc.
Those factors would have to be added in at a minimum, and plugged into the calculated ECR, which is actually known. In fact, like I said before, mathematically it’s all we really know. If we don’t know the true VE number at “x” RPM, then we don’t know the DCR. Most engines cannot actually move the volume of air that they displace. It’s usually a percentage of the swept volume essentially.
Dynamic obviously refers to “movement” and since there are so many additional factors with that, I simply won’t use it as a calculated reference. That’s just me though. There are other folks out there I’m sure that also think enough into it to feel the same about it. If you look at the progression of generational advances in ECM programming, the engineers seem to feel the same. The difference in detail when calculating VE on a Gen III vs a Gen V is actually quite staggering. Even so, there are still a lot of missing parameters for the real DCR number.
I applaud your idea of correctly the terminology. Alas, I think it's gone on unchecked for so many years, that just like when people started referring to every displacement GENIII as an "LS," you'll never get enough traction to make it go away.
Thanks for the feedback.
