Advanced Engineering Tech For the more hardcore LS1TECH residents
MAF or Timing Cover STL or STEP files????
Old Jan 10, 2022 | 12:28 PM
Jazz-LT1's Avatar
Default MAF or Timing Cover STL or STEP files????
I was wondering if anyone has STL files or a STEP model of the MAF sensor for the TPI/LTx/LSx ? If not I could create them, but it would be much easier if they were existing and someone could share them.
I'd like to print them with some extra material so I can add a nitrous fogger to it so really I just need the back side. I also considered adding a band around the factory part with threads for the single fogger.
With 3d printing there's a lot of options. I also considered 3d printing a timing chain cover with the mounting for the crank sensor since it's such a rare part. There are factory timing chain covers in plastic so it seems like the temperature might not be a big issue. PAHT CF15 is good for 300 degrees so I think it's suitable. I'd want to take some temperature readings but since it's cooled by oil and keep cool by the fan it might be okay in that application. Any thoughts on that are appreciated as well.
