Advanced Engineering Tech For the more hardcore LS1TECH residents
24x reluctor relation to crank angle
Old Jan 24, 2022 | 04:13 PM
rjb2968's Avatar
Default 24x reluctor relation to crank angle
Hi All,
I am trying to take advantage of my ECU's injection timing table but the way they have it setup is causing my head to turn.
I have a 24x LQ9 motor and the way the ECU is setup is in a way that the table is in teeth not crank angle.
So do I do 360/24= 15 degrees per tooth. So in the attached screenshot for example at the 60 kPa and 1800 RPM crossing where I see 15. This means tooth 15...
However the LS reluctor does not have a missing tooth from what I can tell so how to I know what the crank degrees are?
