Advanced Engineering Tech For the more hardcore LS1TECH residents
valve train forces
Old Aug 6, 2022 | 06:12 PM
Darth_V8r's Avatar
Moderator
Originally Posted by IGN-1A
Hi Dian, sure all this data is fine.
What is your reason ?
My ADVICE is the find ways the reduce valve train inertia.
Remember the valve train needs to be accelerated.
A lite valve well reduce required forces, spring pressure requirement and allow the engine to "spin up" faster.
100% this ^^
I have seen guys take over a pound and a half out of their valvetrain with springs and locks, no cam change, rev out 400 rpm higher. Motors were quite snappy
Old Aug 7, 2022 | 01:49 AM
Dian's Avatar
sure, the problem being that you need sturdier pushrods most of the time.
Old Aug 7, 2022 | 12:33 PM
Darth_V8r's Avatar
Moderator
Which is why when I build a valvetrain I use the beefiest rods I can fit. I worry about weight on the valve side, not the lifter side. In my mind it's the heavy side and the light side
Old Aug 7, 2022 | 09:02 PM
IGN-1A's Avatar
Default Pushrod tube design
Hi Darth I too agree and add that a pushrod can be made with tubing that has a larger center diameter than each end's diameter.
Old Aug 7, 2022 | 10:10 PM
The only issue with that is, the head must be lowered over them if the center diameter is larger than the pushrod holes in the head.
