Advanced Engineering Tech For the more hardcore LS1TECH residents
Crancase with Thickwall "proud" sleeves
Old Jun 1, 2024 | 01:53 PM
IGN-1A's Avatar
Default Crancase with Thickwall "proud" sleeves
Many here will increase the bore size of their AL Crankcase.
The sleeve can be left higher than the deck surface/
So I ask, How much higher?
Old Jun 1, 2024 | 02:04 PM
Are they normally installed a bit "proudly" above the deck surface??
If not, not many will have a ready answer to your question.
Old Jun 1, 2024 | 10:19 PM
Keith's Avatar
Isn't that something normally done with diesels, not gas engines?
Old Jun 2, 2024 | 06:02 PM
IGN-1A's Avatar
Default Mike Costin Sleeve Tech
HI ALL, Mike Costin called me for help with the Ignition system AND Ignition Coils for his F1 engine
His Race Engine had a displacement of Two Liters, 120 CID and benched 1400 HP.
My question to him was about head gasket sealing.
He too was concerned with the Crankcase growth difference when an Iron Sleeve was installed in an AL cylinder.
The method he used was to "bake" both of these items and then measure the difference.
Old Jun 2, 2024 | 11:12 PM
Lance, I’d love to have that data. What temp did he heat the block to? What was the adjusted liner height…above or below…the deck at temp? Very interesting.
Old Jun 3, 2024 | 01:23 AM
1FastBrick's Avatar
That's Probably a good question for Steve Demirjian at R.E.D. He probably has the most knowledge on this board about that topic considering his background.
@Steve - Race Eng perhaps you can shed some light on this subject?
From what I have seen, depending on the application usually .002 - .003 proud of the block. But certain applications, I have heard can go up to .005.
Here is an example from Steve Morris. He states he uses .003 proud of the block.
https://www.enginebuildermag.com/202...gh-horsepower/
Old Jun 3, 2024 | 01:56 AM
Steve - Race Eng's Avatar
LS1TECH Sponsor
Default Step decking
Leaving the sleeves proud of the deck surface is called "step decking". This is done mostly on wet Darton MID liner blocks on imports. Typical height is .003" above the deck surface using an MLS gasket. Much more than this will lead to coolant leaks out the side of the block. Also keep in mind that the head will twist a bit which can lead to valve seats leaking until the engine comes up to temp.
On a dry sleeved block where the sleeve sits in the deck surface, not much more that one thou step with MLS else coolant leaks out the sides of the block. I don't recommend doing this on LS, Viper or Coyote blocks. O ring with copper wire works better in these, less chance of leaks or head distortion. I usually machine the grooves in the sleeves to leave the copper wire protruding nine to ten thou. The wire should sit on the flat areas of the head gasket if possible.
With higher boost levels consider using the Vulcan gaskets with stainless steel sealing rings on the dry sleeved blocks. No machine work is required. The blocks are decked flat as are the heads. These work very well if available for your application. SCE sells these.
If running a lot of boost, 90 or more pounds in a billet block fuel hoops with copper gaskets are the way to go. The stainless steel hoops are installed in machined grooves in the head. The hoops press the copper gasket into receiver grooves machined into the sleeves. This takes time to do right as the grooves must line up in the block and heads. Not an inexpensive proposition but neither is a billet block.
[QUOTE=1FastBrick;20559489]That's Probably a good question for Steve Demirjian at R.E.D. He probably has the most knowledge on this board about that topic considering his background.
__________________
Steve Demirjian
Race Engine Development
Oceanside, Ca.
760-630-0450
web: www.raceenginedevelopment.com/
e-mail: race-engine-development@***.net
Old Jun 3, 2024 | 02:09 AM
1FastBrick's Avatar
Thanks Steve for sharing your expertise with us!!!
Old Jun 7, 2024 | 07:59 PM
Agreed 100%. Thank you Steve for taking time to teach. Im taking notes here.
