Advanced Engineering Tech For the more hardcore LS1TECH residents
Bad Fuel in tank
Old May 1, 2025 | 03:16 PM
IGN-1A's Avatar
Default Bad Fuel in tank
i have fuel in my customers' tank that is 10 years old.
The engine starts, BUT will NOT IDLE.
There is NO tank drain.
Old May 1, 2025 | 05:46 PM
FCar2000TA's Avatar
Veteran: Air Force
If it has an electric pump, you should be able to trigger the pump, and drain the tank from the fuel lines at the engine. Just need a lot of spare line, but I am sure you know that..... Sorry just noticed who the OP is. My bad.
Old May 1, 2025 | 08:43 PM
Lance, you know enough to get that varnish out of the tank. Remove the tank, drain it all. Rinse the tank. Rinse/clean all the lines. Remove injectors and have them cleaned. Fuel rails need to be cleaned also. No other way to do this right…
I would have never even turned the key on….
