Advanced Engineering Tech For the more hardcore LS1TECH residents
VE Table Cracked
Old Aug 18, 2004 | 02:43 PM
  #181
marc_w's Avatar
Originally Posted by P Mack
No, it's not 5.7 liter specific. You can plug in any displacement you want. The 3444 is a combination of one intake stroke for every 2 revolutions (per cylinder), the gas constant for air (.287 kJ/kg K), 60 seconds per minute, and times 100 to make it a percent. The conversion from liters to cubic meters and from kilograms to grams cancel each other out. I can post the derivation if you really want.
Aaah, I gotcha now. Thanks for the clarification.
Have you had any more time to use the VE you've come up with using the formula?
Old Sep 5, 2004 | 02:47 AM
  #182
bob1esq's Avatar
I am wondering why a formula is necessary at all and if it should even be relied upon. If your formula is correct, which I seriously doubt after numerous mods have been made, then it would follow that the degree each cell needs to be modified would be by a percent that the afr increases or decreases for each cell. So what does the formula do for me other than confuse me?
Old Sep 7, 2004 | 02:57 AM
  #183
QuickSilver2002's Avatar
Just an FYI, I wrote a quick program to read in log files and spit out a VE table based on the average readings.
I spit out one based on:
VE = g/sec * IAT / (MAP * RPM * Displacement)
IAT: Degrees Kelvin
MAP: Bar
Displacement: Cubic Meters
and another based on:
ve(non scaled) = (g/cyl*8122)/(Kpa*51.2) * (IAT*32)
ve scaled = ve(non scaled/5.12)
I scanned a friend’s stock (except catback) z06 and compared the output to a stock z06 table. The second method came up with some #s very close to the stock file. The first method seemed to produce values that were too high across the board. I may have had a bug in my code that threw off the first method, but I worked up a spreadsheet and had the same problem. Maybe I just screwed up the formula some how, but it seems off to me. Anyhoo, that is what I found so far.
A few quick data points:
5200rpms
95kpa
88* IAT
avg flow 259.68g/sec
first method calc:2819
second method calc:2398
pcm stock value:2420
3600rpms
75kpa
90*IAT
avg flow 129 g/sec
first method calc:2581
second method calc:2195
pcm stock value:2145
Old Sep 7, 2004 | 05:50 AM
  #184
HumpinSS's Avatar
Nogo'sve% = MAF.gp/s*(IAC+273)/((346*RPM)*MAP)*212544
gameover's = Ve= g/cy * ((IAT+273)*5120)/MAP(kpa)/cyl colume/178
This will output the ve in percentages for use with HPTuners
Old Nov 17, 2004 | 02:47 PM
  #185
FastBlackTA's Avatar
Could someone please send me an a tap log file (or excell spreadsheet)? I am 10 hours away from my car at school and my buddies and I are going to write a program that will make the calculations and put them into a spreadsheet form if we have time.
This will be greatly appreciated as I have no data to work with.
Thanks,
Conrad
Old Nov 17, 2004 | 02:49 PM
  #186
HumpinSS's Avatar
With HPtuners and efilives software all this is done for us...
Those that still have edit will be able to trade their cables in for HPTuners which does the same thing
Old Nov 17, 2004 | 02:51 PM
  #187
So in HPTuners you can simply log the parameters and it will automztically spit out a VE table?
Old Nov 17, 2004 | 02:55 PM
  #188
HumpinSS's Avatar
Yeah in the form of a histogram that displays LTRIM information in ve table format. The Trims are a dirrect correlation to how far from 14.7 your car has deviated from. Adjsuting the ve table by the LTRIM percentage will dial it in. Check around the forums and you will see a few of us are tuning this way with and without the MAF
Old Nov 17, 2004 | 03:13 PM
  #189
Yeah Ive seen all that, but don't want to spend the $$$ for HPTuners right now esp since I can crank out program pretty fast.
If you had a log file that would be awsome.
Thanks,
Conrad
Old Nov 17, 2004 | 04:30 PM
  #190
monodax's Avatar
Thanks,
Conrad
It not quite as easy as just applying the formulas to the data. Their are quite a few formulas and none of them 100% match our VE table all the way throughout the RPM band. I have developed software which I have been beta testing that does semi-accurately map the VE table but it applies many characteristics that I have calculated to match our curve accurately.
There is also data that is logged that does not need to be applied to the VE calculations/map depending on certain conditions.
You can see some screenshots of the VE MAP on my site in my sig.
Old Nov 21, 2004 | 11:32 AM
  #191
TooManyIDs's Avatar
Originally Posted by NoGo
I have been working on the VE table quite a bit lately and I think I found the solution.
Thanks to gameover for some key hints.
The VE table looks as though it is in meters cubed, it is just not used like a conventional VE table. The VE values are such that the PCM can directly backcalculate to g/cyl, the primary means to determine fueling and timing.
This is what makes it so confusing. You can't solve for air mass, you have to solve for g/cyl.
Anyhoo, here is the equation
VE = ((massflow * IAT / (MAP * RPM * Displacement))
Massflow: grams/sec
IAT: Degrees Kelvin
MAP: Bar
RPM: Duh!
To solve for the massflow in g/sec simply re-arrange the equation.
Massflow = (VE * MAP * RPM * Displacement) / IAT
My old method of "Divide by 30" works okay because we are inadvertantly solving for a volume ratio. The molar mass of air is 28.96 g/mol.
I have compared the above equation to every bit of data that I have ever collected for a stock car, and the data matches up perfectly.
Any corrections, comments, or blinding errors please let me know.
Thanks,
Kevin
Did someone verify if the displacement constant should represent total displacement or cylinder displacement? I'm interested in a 5.7L motor (LS1/LS6).
Someone posted "5.7L = 0.708", but that's not 5.7/8?
Old Nov 21, 2004 | 03:23 PM
  #192
gameover's Avatar
5.665 / 8 = 0.708l
Old Nov 21, 2004 | 09:35 PM
  #193
TooManyIDs's Avatar
Originally Posted by gameover
5.665 / 8 = 0.708l
Thanks
Old Nov 22, 2004 | 11:15 PM
  #194
TooManyIDs's Avatar
IAT: Degrees Kelvin
MAP: Bar
Looks like I need to convert IAT from Farenheit and Manifold Absolute Pressure from inches of Mercury. Correct?
Old Nov 23, 2004 | 12:36 AM
  #195
HumpinSS's Avatar
or you could just log in metric units
Old Nov 23, 2004 | 07:50 AM
  #196
TooManyIDs's Avatar
Understood, but I typically log a mixture of metrics to match the units in the PCM tables to match the LS1Edit displays.
Old Dec 1, 2004 | 07:09 AM
  #197
98A4LS1's Avatar
Yes, I would if you do not mind.
Thanks!!
Old Dec 1, 2004 | 08:10 AM
  #198
98A4LS1's Avatar
The value for the density of air being used in this thread (or maybe the other VE thread) is for dry air at sea level. Is elevation, barometric pressure, and humidity ignored? This can be calculated so one could assume average values such as 1,000 feet above sea level, barometric pressure 100 kilopascal, etc.
I just ordered HPTuners. I got a lot of catching up to do!
Old Dec 1, 2004 | 08:30 AM
  #199
HumpinSS's Avatar
when the car is started the PCM takes a barometric reading. This shouldnt change as long as you arent traveling up and down the moutainsides....
Old Dec 1, 2004 | 08:55 AM
  #200
98A4LS1's Avatar
Thanks. Just eliminating variables. Same thing for fuel density I guess? It will vary as well. A/F ratio will vary based on gasoline profile ie oxygenates, alcohol, etc.
