Advanced Engineering Tech For the more hardcore LS1TECH residents
VE Table Cracked
Old Dec 1, 2004 | 11:38 AM
  #201
P Mack's Avatar
Originally Posted by 98A4LS1
The value for the density of air being used in this thread (or maybe the other VE thread) is for dry air at sea level. Is elevation, barometric pressure, and humidity ignored? This can be calculated so one could assume average values such as 1,000 feet above sea level, barometric pressure 100 kilopascal, etc.
I just ordered HPTuners. I got a lot of catching up to do!
The air density is calculated through manifold pressure and temperature. It doesn't account for humidity though, which is why i believe people see their ltft's change without changing their tune.
Old Dec 1, 2004 | 01:55 PM
  #202
98A4LS1's Avatar
Not sure I follow what you are saying since density is mass per volume.
Old Dec 1, 2004 | 04:04 PM
  #203
P Mack's Avatar
It is, but it can be calculated from pressure and temperature using the ideal gas law (line 6 of the attachment).
Yes, I would if you do not mind.
Thanks!!
Here you go.
Old Dec 1, 2004 | 06:10 PM
  #204
Bink's Avatar
Here you go.
P Mack - That's a nice simple derivation! Very straight forward ...I think.
Old Dec 2, 2004 | 04:21 AM
  #205
98A4LS1's Avatar
Here you go.
LOL, thanks P Mack. I really appreciate the reply. I will take a look at it today at work. I use IDL and more everyday, it's second nature being an environmental engineer. I apologize for all of my questions which I'm sure have been asked many times before. I'm trying to come up to speed quickly since I have parts laying around dying to be installed on my '98 Z
Maybe it will be more clear when the software I ordered arrives tomorrow and I start logging and reviewing some data.
Again, muchos gracias!
Great website!
Old Dec 9, 2004 | 11:51 PM
  #206
gojo's Avatar
"{SAE.MAF.gps}*({SAE.IAT.C}+273.15)/(346*{SAE.RPM}*{SAE.MAP.kPa})*6155274.2"
This will match the LS1 Edit values.
Old Dec 30, 2004 | 09:39 PM
  #207
TooManyIDs's Avatar
Did a quick calc for a cell and it does look like a match on the LS1Edit value. Please explain the constants of 346 (cubic inches???) and 6155274.2?
I tried to create a spreadsheet equation using the cylinder volume (mentioned above) as the only constant. Sadly, my attempt to match the LS1Edit table failed.
=(MAF Rate[gm/sec]*((Intake Air Temp[F]+459.67)/1.8)/((MAP[inHg]*0.033863881)*RPM*0.708))
Convert IAT from Farenheit to Kelvin
Convert MAP from in.Hg to Bar
Old Jan 1, 2005 | 10:26 AM
  #208
TooManyIDs's Avatar
gojo,
This looks like what ChrisB posted here:
https://ls1tech.com/forums/showpost....9&postcount=76
except for the last constant, which ChrisB explained here:
https://ls1tech.com/forums/showpost....6&postcount=83
I'm still looking for how you arrived at 6155274.2 as a constant. Thanks.
Old Jan 1, 2005 | 10:39 AM
  #209
TooManyIDs's Avatar
I'll have to do some searching to see if you guys covered this, but I'm concerned about the impact of air filter changes on the MAF values.
If all these VE calculations are based on the MAF gm/s value, which itself is derived from the value in the MAF table associated with a given MAF frequency, then it is critical to have a MAF table that matches your air filter characteristics, right?
The cars I've been playing with all have VRam intakes, but I haven't made any MAF table changes to match the cold air filter. I guess that was taboo a while back, but seems to me that it has to be addressed.
I'm also still wondering how it impacted the gms/cyl calculation for the timing table, see this thread:
https://ls1tech.com/forums/pcm-diagnostics-tuning/238860-abnormal-timing-values.html
Old Jan 2, 2005 | 02:34 PM
  #210
randt's Avatar
After reading and bit of confusion...What is the 'general consensous'?
I'm trying to decipher and adapt to other formats...
Harley-Davidson applications and also a MegaSquirt converted VW Beetle
Old Jan 3, 2005 | 06:09 PM
  #211
Bink's Avatar
https://ls1tech.com/forums/showthread.php?t=238860
The MAF may NOT be perfect but it will get you close - regardless of air intake type ( gojo has a VaraRam and his VE calcs have been very good). You can then use a Wideband and Commanded AFR to evaluate your MAF - Open Loop or SD.
For Timing Values see the EFILive Forums -> Inside the "FlashScan" Forum GMPX has a Thread on "The Importance of a Good Scanner" (or something like that?) ...he discusses the final timing values we see and how the PCM arrives at them.
T
here are some new PIDS for pulling the various Timing "Adders" and "Subtracters" together for the Final Scanned value we ultimately see.
Hope this helps some.
Old Mar 1, 2005 | 11:58 PM
  #212
DVCrazyCamTAWs6's Avatar
this is the expression i'm using to crack the VE in EFILIVE
({SAE.J1979.MAF} * {SAE.J1979.IAT} / ({SAE.J1979.MAP} * {SAE.J1979.RPM} * 0.0059))
0.0059 = 364ci 6.0L
0.0056 = 346ci 5.7L
Must Set PIDs to : (or will not work)
MAF = UNITS- Grams/Sec, FACTOR - 0.010000, OFFSET - 0 (limits = 0 to 530)
IAT = UNITS- Kelvin, FACTOR - 1, OFFSET - 233.15 (limits = 0 to 500)
MAP = UNITS- BAR, Factor - 0.010000, OFFSET - 0 (limits = 0 to 1.0500)
Expression : (MAF x IAT x / (MAP x RPM x DISPLACEMENT))
After logging i export RPM/MAP/VE Crack, I'm then trying to put together a excel sheet to grab averages from the logged data then have them placed into a excel VE TABLE by MAP KPA / RPM automaticly.. then pasting then new VE table into the editor.. i'm still woking out how to accomplish doing so in Excel. once done this should bring things pretty close to what the car is asking for VE otherwise. hopefully i can come up with a way to make this excel app work, Help!
Old Mar 2, 2005 | 02:43 PM
  #213
RedHardSupra's Avatar
please send me what you got so far, i'm working on a very similar thing. marcinpohl at gmail dot com
Old Mar 2, 2005 | 06:38 PM
  #214
Bink's Avatar
Why not enter your xls files into ChrisB's LS1 Log Analyzer??
Here's a link to info -> https://ls1tech.com/forums/pcm-diagnostics-tuning/98555-new-data-reduction-ls1-edit-automation-software.html
And to the Log File analyzer-> http://www.slowcar.net/analyzer/
Do a search for more info. It works very well.
joel
Old Mar 3, 2005 | 11:47 AM
  #215
Here's a link to info -> https://ls1tech.com/forums/showthread.php?t=98555
joel
I haven't tried this yet, i'll have to give it a try. still going to see if i can work up an excel app though.
RedHardSupra: i'll send you what i got soon as i figure out why it's not allowing me to use the length of the expression i'm using to to average out RPMs and Map data within a 200 range which would be half of the 400 increasements which is in the table. it might be the version i was using on my laptop haha office 97. going to try the 03 version so if that makes a differnce
Old Mar 6, 2005 | 08:46 PM
  #216
alright i finished the APP it's 25mbs. you log from efilive , export RPM,Map, and VE crack data. into the excel app. it then in turn makes out a VE table to paste into edit
Old Mar 6, 2005 | 09:11 PM
  #217
TooManyIDs's Avatar
DVCrazyCamTAWs6,
Can you email it? You've created something that will reduce all of the data to values for the appropriate cells? Sounds great, just started wondering how I would do that.
Old Mar 6, 2005 | 11:23 PM
  #218
yeah it's on my laptop my lady has right now, i'm also goona upload to a server everyone can download from. keep you posted
Old Mar 7, 2005 | 04:38 AM
  #219
ve crack table edit
Alright there it is. it's my first attemp, so go easy on me. but it works. if you have any question email me ( high10sws6@yahoo.com ) or just post it here..
I'll be working on a more user friendly one with the VE crack built in so you dont have make a new pid for the ve crack in efi live and chang some settings
remember you need to log RPM, map(bar), and the Calculated Ve Crack list below
0.0059 = 364ci 6.0L
0.0056 = 346ci 5.7L
~SoL~
Old Mar 7, 2005 | 08:10 AM
  #220
TooManyIDs's Avatar
Thanks for posting. I'll be trying to use this with data logged using EASE.
