Advanced Engineering Tech For the more hardcore LS1TECH residents
Rocker Arm Round-up
Old Oct 5, 2005 | 02:17 PM
J-Rod's Avatar
6600 rpm clutch dump of death Administrator
Default Rocker Arm Round-up
Just trying to sort out what all is out there from a rocker arm standpoint, if it will clear the stock valve covers, ratios, and perhaps (but not required) list price.
Mfg/ratio/clear/price
Stock GM/1.7/y/???
SLP (stock look alike)/1.8/y/???
SLP aluminum/1.8/y (with minor clearance work)/$499
Comp magnum rocker / 1.75,1.85/y/$483.24
Crane Gold/1.8/?/$699
Crane Shaft/1.7-2.0/n/???
Jesel SS / 1.7,1.75,1.8/y/$699
Jesel J2K/ 1.7-2.0/n/$1437
Harlan Sharp/TBD
Yella Terra/TBD
DRE/TBD
Scorpion/TBD
Please feel free to add to the list. I'll pretty it up as I go along...
Old Oct 5, 2005 | 02:34 PM
joelvette's Avatar
what about harlan-sharps both adjustable and not
yella terras
Old Oct 5, 2005 | 02:38 PM
Cstraub's Avatar
Put DRE in the bag and Scorpion should have some by PRI. It's funny you mention rockers arm J-rod. I thought about you yesterday as I was on the phone with a fellow I consider one of my mentors and one of the smartest men in this industry, French Grimes. Rockers came up yesterday. French simplifies everything so one can understand but when he said the following I had to smile on the phone because I new the answer: "What makes a good rocker a good rocker?", he asked. I said, " a tri-angle". I could hear him grin and we were back on my topic of conversation of trying to diagnose timing chain failures which we feel is do to a Power Harmonic.
. .well back to work.
Old Oct 5, 2005 | 07:45 PM
RPO_Z06's Avatar
Could you add what ones are adjustable with a y/n line ? Nice work btw...
Old Oct 5, 2005 | 07:49 PM
DaleMX's Avatar
Yella Terra stock ratio, using TR230 and Stage 2 heads with CC 977 springs and Titanium retainers, fits under stock valve covers and clears the springs and retainers.
Old Oct 5, 2005 | 08:14 PM
2xLS1's Avatar
Seen in High Perf Chevy magazine.
Old Oct 5, 2005 | 09:24 PM
MUSTANGEATER's Avatar
I thought DRE made Comp's roller Rockers? or did they switch over to T&D?
Old Oct 5, 2005 | 09:26 PM
mrr23's Avatar
the crane are both 1.7 and 1.8 for 669.00
Old Oct 5, 2005 | 09:33 PM
V8er's Avatar
Anyone know the weights of these rocker kits? My Jesel SS kit seems a bit heavy and they do NOT clear the stock valve covers without some grinding.
Old Oct 5, 2005 | 09:35 PM
jrp's Avatar
jrp
SN95 Director
the jesel SS's wont clear the stock valve covers w/o modifications; i.e gut the underside and remove the baffles.
Old Oct 5, 2005 | 10:00 PM
TAQuickness's Avatar
Agreed. I have have the jesels and had to do some fabrication on the valve covers for clearance
Old Oct 5, 2005 | 10:19 PM
liftin'em on nittos's Avatar
maybe add a solid roller applicable line with y/n options also...there's more and more options every day it seems
Old Oct 5, 2005 | 10:45 PM
DavidNJ's Avatar
T&D shafts...a little less $$$ than the Jesels, also race worthy...maybe a little below the Mohawks in finish. T&D and Jesel are major providers of racing shaft systems (I believe all NASCAR teams use either Jesel or T&D).
Old Oct 6, 2005 | 04:04 AM
vettenuts's Avatar
Crane's clear without issue on centerbolt, not on early perimeter. Just installed in my 02 Vette without a problem.
I would suggest, if you can find the information, adding not only weight (which may be less relevant) but also rotary mass moment of inertia. Just not sure if the manufacturers will provide the information or how to obtain for stock rockers. This is perhaps a more important number than just dead weight.
Old Oct 6, 2005 | 09:54 AM
Roger Vinci's Avatar
The stock rockers weigh in at 137 grams. The Crane/VHP rockers weigh 142 grams. The bulk of the weight is located over the stud, which lessens the moment of inertia. on the Crane/VHP rocker. The stock rocker begins to deflect at 2200 lbs pressure and breaks at 2300 lbs. The Crane/VHP rocker is still steady at 3400 lbs. I think the slight increase in weight is well worth the extra strength factor, especially when the weight is centered over the stud. There is no doubt in our minds that the power increases have been well documented on this and other sites. We have never recorded an instance of any sort of rocker failure in the seven years we have been using our Crane/ VHP rockers. Roger
Old Oct 6, 2005 | 10:05 AM
J-Rod's Avatar
I'll start putting htis into an excel spreadsheet with all y'all suggestions. Thanks. If anyone can help dig up more data on mass, adjustability, etc... Feel free to post it up. I'll include whatever we can find.
Old Oct 6, 2005 | 02:26 PM
SStrokerAce's Avatar
This is why I like you!
Is French related to Norm?
Bret
Old Oct 6, 2005 | 02:52 PM
Cstraub's Avatar
Bret
. . .oohh it even got better. We got into rod/stroke ratio and going back to something DenzSS had touched on last year about angularity and cylinder pressure and runner volume based in relation to the CID and intended rpms of an engine. It was pretty interesting listening.
Chris
Old Oct 6, 2005 | 07:06 PM
Ed Curtis's Avatar
Chris
Next you'll be bringing up Miller...
Ed
Old Oct 7, 2005 | 07:59 AM
Cstraub's Avatar
No, I won't bring up Miller. 2 seconds talking to that guy and. . .oh you know!!
