The truth about LSA
First off... most times with a LOW LSA you have a LOW ICL, which closes the intake valve earlier, which improves the DCR and low to midrange TQ. You can have a low ICL with either advance or low LSA. There are places for both, I preffer one method over another.
Let's break these things down....
Yes this is true
Yes and no.... you can increase TQ in the standard dip that's seen on a engine dyno (especially in high output street motors like those found in the Engine Masters contest) in the 3000-3500rpm area by decreasing the overlap. This is because the intake and exhaust tuning events aren't working well together here overlap hurts things even more. In the Engine Masters guys started using heavily worked dual plane intakes to take care of this area and it works pretty well.
I would say that most of the timing increasing the LSA is not going to help the average power numbers. So going to a 114LSA from a 112LSA is going to hurt power.
Increasing LSA and keeping the same advance (notice not ICL) will make the IVC point happen later which will move the powerband higher in the RPM range but maybe not up the HP scale.
I like all of that statement (with a but) which includes:
- helps with emissions
- smoother idle (higher idle vacuum)
- Increasing LSA = decreasing overlap (if duration stays the same)
I don't like that the higher LSA will show a higher HP RPM peak... if you have more than enough overlap for the motor, yeah it can move it higher, if you don't have enough overlap, then it will not move the HP peak higher.
Now on to Adrenaline_Z's comments....
Again it's all in the valve events, a earlier IVC is going to make more TQ. If you have too much overlap it can hurt but otherwise it's not going to hurt the TQ. Again if you have too much duration for the setup then you will be SOL in this deparment and it will hurt power.
watch out there.... overlap and DCR are not related at all... DCR deals with the IVC event and overlap with the EVC and IVO events.
BMEP (Brake Mean Effective Pressure) is directly related to VE so we don't need to talk about both of them... compression and cylinder pressure play into BMEP but the curves follow the same trend, more VE means more BMEP. If they diverge then something is causing you to lose ring seal.
Anywho...
and cylinder pressure also rise later in the RPM band.
The VE will make the effective compression inrease when it increases, but when you don't have high VE's (before the exhaust and intake tuning waves get working for you) you need the DCR from the early IVC point to help your TQ curve out. Balancing those two things out with the octane requirement (expecting that you have the tuning pressures in check) will get you the meanest street motor.
IMHO really mean street motors are as much fun as race motors. You don't have the problems of keeping things from going boom due to RPM, boost or lots of N2O, but you do have a lot of issues all tied in together to make the motor make power AND work as a street car.
Daddy SS,
Bret
BTW thanks for making me think and explain stuff... it helps me as much or more than you guys to have a better idea of motor crap in my head.
IVC is directly related to DCR (as per formula). Does my generalization of
bigger durations not apply to lowering DCR as a rule of thumb (because the
IVC normally occurs later)?
So...we can alter the torque peak with the intake opening and closing points.
Earlier opening IVO coupled with an earlier closing IVC improves torque at lower RPM...IF...the exhaust valve closes early as well.
IE (seat to seat):
IVO - 30* BTDC
IVC - 62* ABDC
In. Duration 272 degrees
EVO - 80* BBDC
EVC - 28* ATDC
Ex. Duration 288 degrees
Overlap is 58 degrees
This above combination would typically yield a high lobe separation which
rolls of the HP curve at higher RPM.
On the other hand, with a later closing IVC and later closing EVC we're dealing
with a camshaft that wants to live in a fast spinning motor. This combination
would move the torque peak slightly higher in the RPM spectrum and also allow
HP to peak higher.
The above being true if the IVO creates a large amount of overlap.
IE (seat to seat):
IVO - 40* BTDC
IVC - 72* ABDC
In. Duration 292 degrees
EVO - 80* BBDC
EVC - 32* ATDC
Ex. Duration 292 degrees
Overlap is 72 degrees
Maybe we can begin to add cam cards and valve events to clarify this topic
from this point forward?
Let's also use a test bench motor to study the theoretical effects of valve timing. How about a showroom stock 2002 LS1?!
IVO - 30* BTDC
IVC - 62* ABDC
EVO - 80* BBDC
EVC - 28* ATDC
IVO - 40* BTDC
IVC - 72* ABDC
EVO - 80* BBDC
EVC - 32* ATDC
I hate saying move everything up in the RPM range here, because if anything these changes are going to cause a rotation of the TQ curve at the HP and TQ crossover (5252rpm) where the larger cam is going to loose TQ below that point and make more above it.
Those two cams aren't for the same application IMHO. RPM ranges would greatly differ and if you threw converters into the mix the converter choice would be vastly different.
When I'm talking about these things all happening I'm talking about two cams that are very close on specs and we are adjusting them around for the same application to make them work better for the said application.
Bret
rolls off the HP curve at higher RPM.
Explain that one again to me Lucy?
What I meant to type was; with a modest overlap, would the HP curve roll
off sooner (using the valve timing in my previous post)?
Still would be a good idea to put up all the specs of these popular cams and I can put the overlap in there so we have more room to compare them.
Bret
Bret
. Thank You!Most of the cam discussions (that I've read) do not stick to a narrowed range of specs (variables).....and this leads to confusion, IMHO.
(seat to seat):
IVO - 40* BTDC
IVC - 72* ABDC
EVO - 80* BBDC
EVC - 32* ATDC
Intake Centerline: 106
Exhaust Centerline: 114
Lobe Center: 110
Since we're discussing the effects of overlap, why don't we play with IVO first?
Any objections? Otherwise, take it away!
Also take the advance crap out of the thing, then we can advance/retard the cam and see what that does.
Just change your example and then I'll rewrite this post and we can change the specs from there.
Bret
I need you to rephrase that one..... Make it longer and think what you want to say and I'll try my best to explain what I can.
Overlap can help an engine make more power when the engine has a tuned exhaust system (long tube headers) that is set up to create negative pressure during the overlap cycle at given RPM ranges (usually higher RPM ranges). The exhaust system actually helps to fill the cylinder under such conditions, increasing power.
Here is a link, which I posted separately as well, to an article which describes this well:
http://www.popularhotrodding.com/eng...exh/index.html
stroke.
It's also a fact that a tuned exhaust will begin pulling intake charge during
the overlap period before the piston even begins moving downward.
Bret, I'll convert the events to 0.050" tomorrow.
We're also going to change one aspect of the valve timing and comment on
the effects on engine dynamics.
I doubt most of this could be found on MFG sites, or most tech forums for that
fact.
I'd like to discuss what the effects of +10 milliseconds of overlap will have on
pulse tuning at 6000 RPM. Possibly supporting mods to make the extra overlap
work (IE: Higher SCR, 6 inches of tuned intake/exhaust runner, etc.)
It's all hypothesis, but it beats watching re-runs of American Hot Rod.
(0.050")
IVO - 3* BTDC
IVC - 51* ABDC
In. Duration 234 degrees
EVO - 56* BBDC
EVC - 8* ATDC
Ex. Duration 244 degrees
Overlap is 11 degrees
Intake Centerline: 114
Lobe Center: 114
If this doesn't fit the discussion, please select something that does.
Let's open the intake valve (IVO) earlier by 2 degrees @ 0.050".
My thoughts are:
- low RPM torque/VE will increase
- HP will peak a touch higher due to extra overlap (to help scavenge the chamber)
- These numbers are very conservative for high RPM use. More fit for a street
cam with good low to mid range power (1500-5000 RPM)
- Smooth idle, good fuel economy.
Take it from here. See how far we can move IVO and what we need to consider
for each step?
(0.050")
IVO - 3* BTDC
IVC - 51* ABDC
EVO - 56* BBDC
EVC - 8* ATDC
Lobe Center: 114
My thoughts are:
for each step?
Anywhoo...
IVO - 5* BTDC
IVC - 49* ABDC
In. Duration 236 degrees
EVO - 56* BBDC
EVC - 8* ATDC
Overlap is 13 degrees
Intake Centerline: 113
Lobe Center: 113.5
Going to the 236/244 113.5 (113ICL / 114ECL) cam is going to basically just take the TQ curve and bring it down below HP peak. This is because while you are lowing the ICL you are doing so by adding duration to the opening. The extra overlap should help the peak HP number since for that application there is not enough anyways.
- low RPM TQ/VE decrease
- the HP peak might raise in RPM but most likely it will just be slightly higher if the exhaust tuning events like the additional overlap which I think they will here
- the duration and LSA numbers are more fitting to a high RPM range than you listed
- the idle will be rougher now than before due to the overlap and no increase in DCR.
Now lets SUBTRACT the 2 degs to the IVC
IVO - 3* BTDC
IVC - 49* ABDC
In. Duration 232 degrees
EVO - 56* BBDC
EVC - 8* ATDC
Lobe Center: 113.5
As you can see we have the same ICL and LSA as the above example of adding the 2° to the IVO. Now we have less duration at .050 on the intake, and the same overlap that we started from.
What should happen...
- low RPM TQ/VE increase below HP peak. Whole curve should shift up.
- the HP peak should be around the same RPM but might be slightly lower in output and RPM
- the duration and LSA numbers are more fitting to a lower RPM range than the cam we started with you listed orginally
- the idle will be better now than before due to the same overlap and increase in DCR.
Bret
However, when comparing to +2 IVO, I can see why your analysis fits.
#2. Cool with that.
#3. I figured 232 degrees intake would be a little shy for high RPM use. It's
pretty amazing to see the stock duration of the LS1 specs compared to gen1/gen2
small blocks.
#4. Agree. Still thinking carb'd early model small blocks. It's easy to forget
that a higher compression LS1 with fast burn chambers, EFI, etc. is going to
handle cam timing in a totally different method.
Where do we go from here? We're barely scratching the surface!
Why don't we start doing a overlap or LSA change, and that's it....
So lets take the 234/244 114 LSA cam and take 4 degs out of the LSA for ***** and giggles.
IVO - 7* BTDC
IVC - 47* ABDC
EVO - 52* BBDC
EVC - 12* ATDC
Overlap is 19 degrees
Intake Centerline: 110
Exhaust Centerline: 110
Lobe Center: 110
So now the intake valve is opened sooner and closes sooner to raise the DCR. The exhaust valve opens and closes later.
The IVO and EVC are both increasing the overlap, which is going to help the top end HP and cause a rougher idle and low speed TQ decreases. The earlier IVC helps increase the DCR and will help out the low and midrange TQ. The later EVO is also going to help the midrange TQ as well.....
The net effect should be a similar or decrease in low end TQ, a increase in midrange TQ and a gain in HP at the high end. All with a rougher idle and about 1.5-2" of vacuum drop at idle. The only issue here is that lowering the LSA like this is basically diminishing returns, the lower you go the less you gain until you come to the best LSA/overlap for the motor. Then you can use the same overlap and find the best duration.
If it was me I would do a bunch more changes to this cam, but this isin't about what I would do for a cam, it's about what changes do what to the power curve
Bret
The problem is that LSA, overlap and even duration are not truly defining characteristics of a camshaft; they are merely a measurable resultant of four independent variables of differing importance, namely IVO, IVC, EVO and EVC. Rather than rattling off all four, plus lifts, etc. in trying to describe a cam, we naturally look for shorthand summaries. For any normal cam design, the I & E durations are reasonable approximations of its general RPM characteristics, but overlap and more so LSA are less clear-cut pointers.
For example, since IVC is by far the most influential event, by advancing a cam we are primarily just closing the intake sooner, thus biasing the engine characteristics towards a lower RPM range. The other 3 events are dragged along for the ride, but any effect from the change in IVO, EVO and EVC is relatively minor. Similarly, if we widen the LCA with no other changes, say by retarding the intake lobe 4 degrees, the exhaust events are unchanged and although we have also reduced the overlap, it is mostly the later IVC to which the engine responds.
In a similar fashion, overlap is not a spec that the cam designer selects directly, it is the resultant of the chosen IVO and EVC points. (How would an engine respond to a cam with 60 degrees of overlap if it was generated by an IVO of 60 and an EVC of zero, rather than 30-30?)
In summary, because overlap and LCA are 'ground-in' resultants which cannot be changed without creating a new cam, it is technically incorrect to talk of 'increasing' the former or 'widening' the latter. We should be speaking directly of the changes to individual events. Human nature being what it is, we will continue to 'shorthand' cam descriptions, but we should at least try to remember the underlying realities.
Thought for the day: Considering the wildly different conditions and requirements, not to mention valve sizes, etc., what are the odds that at any given RPM an engine really needs exactly the same I & E lift, duration and timing, as provided by so many cams?
Bret
