Advanced Engineering Tech For the more hardcore LS1TECH residents
Camshaft Discussion part II
Old Feb 29, 2004 | 09:01 PM
  #201
VINCE's Avatar
Shorty Director
Originally Posted by Plan B
My 422 n/a ran a solid 258/262 on 108lsa .650” lift 680 fwhp at 6,800rpm. It drove nice with 8tb’s a little ugly with the stock LS6 intake though, still drivable. I’ve since pulled the engine and I’m in the middle of putting a 4 link rear end in. It was a little too strong for the street on our size tyres.
Glad you’re enjoying it over here J-Rod.
Pics of that setup would be nice. What were your idle rpms? I also think your solid roller cam is really not that big for your size motor. Solid Roller cars idle much better than Hydr Cams of the same size. I for one drive my car great distances. I would be a little scared to have to stop every now and then to check my valve lash. Plus, my springs would get beat to hell in less than a year.
Old Feb 29, 2004 | 10:30 PM
  #202
383ss's Avatar
I'd love to try something like one of these on my 90% drag race 383 engine. Was looking to swap cams anyway. who can I contact to get one??
Old Feb 29, 2004 | 10:37 PM
  #203
Jammer's Avatar
J-Rod...one last Congrats.
Do you feel the small seperations also hold true in regards to turbo set ups? I have a hard time thinking say a 110 is going to give me what say ,a 115 might give me...but I do like to go against the grain.
Old Feb 29, 2004 | 11:24 PM
  #204
Mike K.'s Avatar
I hope I'm not coming into this too late but whats the difference between speed density and Mass Air Flow? MAF I understand but what is the speed density tune and why when using it can you ditch the MAF?
Old Mar 1, 2004 | 12:09 AM
  #205
GTBMad's Avatar
Ye of little faith.
We have just tuned on engine dyno a small single pattern cam in speed density for an Auto daily driver 244\244 .620 110lsa. It will be on the chassis dyno thursday for some idle setup behind the drive train.
When i originally got ls1 edit august 2002 we found that there was no benefit to be had with a descreened ported Maf , we tuned the car with a stock Maf which resulted in allround better package. The car travelled 60,000k on this setup.
With the new motor it was decided to go with speed density rather than keep the Maf as we were aiming to max airflow for 429 ci motor, as it was the LS6 Manifold pulled us up short just over 5200 rpm with the MAP going down to 94. We nearly had an opportunity to do a back to back on a LSX with 90 mm TB unfortunately could get it overnight.
My setup isnt solid roller but comp r with yella terras and comp 921 and the yella terras take a bit of work to get right on compRs.
All this post is about is to give you what we went through to get the setup, as a matter of interest our first tune with edit 18 months ago was on my head and cam auto with a comp 216\220 to get it right it took many hours on chasis dyno.
Now the same person does speed density tunes within a couple of hours hence why he has stacks of MAFS on the shelf
Old Mar 1, 2004 | 12:26 AM
  #206
VT2 EXEC LS1's Avatar
Originally Posted by binksz06
So, is everyone agreeing that the LS1/6 is a "Smallblock Chevy"- i.e. same cam rules apply?
J-Rod - How do they adjust for the low map at low rpm idle - as far as the automatic tranny requirements? I know very little about automatics but I realize they require vacuum.
I wouldn't follow the Aussies belief in MAFLESS tunes for the Street.
joel
I'll be the first to let you know how my car goes when it's running Joel. I'll be running the GM GrandAm cup cam kit in an A4. Engine comes back from the machine shop this week so it should be running in 2 - 3 weeks.
Old Mar 1, 2004 | 01:30 AM
  #207
J-Rod's Avatar
6600 rpm clutch dump of death Administrator
There are some "tricks" to setting up an auto to work right. In fact the car I drove was getting that sorted out.
Old Mar 1, 2004 | 07:50 AM
  #208
Plan B's Avatar
Sorry Vince, what pics are you after? I'll post what ever you want to see!
Old Mar 1, 2004 | 08:42 AM
  #209
Bink's Avatar
Here are a couple of pics I have - I'm not sure if they represent PlanB's current motor. Absolutely BEAUTIFUL setup. Pic 1
Pic 2
joel
Old Mar 1, 2004 | 08:43 AM
  #210
Bink's Avatar
Thanks man - can't wait to hear of your results.
joel
Old Mar 1, 2004 | 07:17 PM
  #211
J-Rod's Avatar
Plan B's ride is pretty trick. He has a nice daily driver ute to replace the one that went under the knife. The old PlanB is now a back halfed car and should have one of those pretty 8TB setups with 1000HP on tap soon.
Old Mar 1, 2004 | 07:34 PM
  #212
VINCE's Avatar
Shorty Director
I want to see pics of your car and engine compartment..
Old Mar 1, 2004 | 08:03 PM
  #213
Bink's Avatar
VINCE - I posted a couple of his car a few posts above. I copied them last month off the LS1.Au forum because they looked sweet.
PlanB - Are the Pics I Posted of your current setup - i.e. Sam's TBs ?
Old Mar 1, 2004 | 08:20 PM
  #214
VINCE's Avatar
Shorty Director
I saw them after I posted. That engine shot looks sweet.. I wonder how we could have a intake like that..?
Old Mar 2, 2004 | 01:44 AM
  #215
J-Rod's Avatar
All it takes is money. Actually, I think a production version is scheduled to be out soon for around $3000 US.
Old Mar 2, 2004 | 06:25 AM
  #216
VINCE's Avatar
Shorty Director
Wow!!!! $3k.. There better be some SERIOUS gains over the current sheet metal intakes.
Old Mar 2, 2004 | 09:11 AM
  #217
CHRISPY's Avatar
Great thread guys!!
I have a question. Is there a calculator out there to take various events and have different grinds to match those events.
Take for example the 242/248 110LSA +2 TREX.
Would it be possible to extrapolate these valve timing events to a cam with less duration but wider LSA/less intake/exhaust duration/different advance/retard to improve drivability but give the same event characteristics.
Old Mar 2, 2004 | 12:35 PM
  #218
BADFNZ's Avatar
Originally Posted by Chris ARE 360
Great thread guys!!
I think the best way to do this would be to just play around w/ the VE and see which ones mirror the TREX. But that wouldn't give you an exact duplicate due to cam lobes, ramp rates, etc.
Old Mar 2, 2004 | 04:47 PM
  #219
J-Rod's Avatar
The problem is knowing lift @ .006, .050, .200, etc... You need to know more than .050. But in terms of the Valve events, you can use my VE calculator, and that will get you in the ball park. I have it set up to calc .006, .050, and .200
Old Mar 3, 2004 | 12:17 AM
  #220
Bink's Avatar
J-Rod - Where is the link to your VE Calculator? I thought it was in this thread but I can't find it . Thanks.
joel
