Advanced Engineering Tech For the more hardcore LS1TECH residents
Camshaft Discussion part II
Old Aug 20, 2004 | 12:01 AM
  #361
Cstraub's Avatar
John,
What do you want this testing to prove?
Chris
Old Aug 20, 2004 | 12:19 AM
  #362
Cstraub's Avatar
The ls1 has a lot of advantages over the sb Chevys and Fords,lets see great heads even stock
They are good heads.
,better valvetrain such as beehive springs
Remains to be seen, these are 25 year old technology. Isky tried them years ago.
and a large cam base circle,
Helps in deflection
longer connecting rods
rod/stroke ratio is what to look for LS1 is 1.68, 351W is 1.70
,better oilpump and route design.
I can assure you this is going to change, trust me.
much better individual coil per cylinder,
Yes, about time OEM's caught up with 60's outboards
better block and maincaps(6bolts)better cooling system(no water thru the intake) and great reusable o-ring gaskets,
All good points.
better firing order( 4-7 switch,)better front cover(don"t have to drop the oilpan to change cam),
Maybe.
what about those lifter trays to make cam swapping easy.Not to mention lightweight and compact design.
Had to be, the engine comes up through the frame rails at the Corvette plant.
The ls1 responds well to most all cam changes compared to other motors,it depends on what you want.
Most engines will.
I believe that J-rod and Denzss(what happened to him?)got us all thinking more about cam choices and the design of such,J-rod has got me curious about LDA and how each would accelarate with a given load say a drag car that turns 4500 t0 7500 in a 5 second 1\8 strip.Hp is not just hp, some cars run quicker with less then others with more hp(explain that).
The car the hooks it and the engine that gets to its power band quickest will always win. Engines are just part of a much large equation.
Thats the fun of this stuff it keeps you thinking of new ways to do something.
Hey Chris, would explain how a motor can be 103%ve without a blower or turbo? You mentioned this 2 days ago about the 500 ci (600hp)marine motor you are building.
Yeah should have dyno numbers soon. The test engines that were built 5 years ago were that also. Most of your good NA stuff will be in that range. Your Comp elimnator busch stuff in the 110 range, PS stuff in the 115%. It's what we refer to as the RAM effect. I will be more then happy to explain it, but not tonight.. . dinner involved to many Bud's and to explain it I need to be a little more sharper.
Chris
Old Aug 20, 2004 | 01:00 AM
  #363
racer7088's Avatar
Arrow
Originally Posted by Cstraub
John,
5.0 and LS1
Call BHJ and get a cylinder hone plate for a SBF. Bolt it on your LS1. . .it fits. Most of you who have had bore and hone jobs I will bet the shop used a Ford Hone plate. Actually we can generalize most production engines today. . .its all been done and re done. Now if you want NEW, go to www.coatesengine.com thats new.
John, I do thank you for this site. It is something you should be proud of. I mean that.
Chris
Actually not to be mean to you Chrus but that will not work so good but it can come close to the 6.0 block stuff. You need to cover the fire ring of the HG you are using and the stock LS1 stuff is 3.897-3.905 and the gaskets are 3.970 bore diameter or so which is out in the open witha 4.100 normal Ford Windsor TQ plate. Now on the 6.0 stuff with the 4.000-4.030 bore stuff it would work alright with th right gaskets.
That's why I have so many different TQ Plates. I have 4 just for LSx engines right now. I've done from 3.905 to 4.165 with 6 kinds of gaskets.
Old Aug 20, 2004 | 01:06 AM
  #364
racer7088's Avatar
Arrow
Originally Posted by FASTONE
The ls1 has a lot of advantages over the sb Chevys and Fords,lets see great heads even stock,better valvetrain such as beehive springs and a large cam base circle,longer connecting rods,better oilpump and route design.much better individual coil per cylinder,better block and maincaps(6bolts)better cooling system(no water thru the intake) and great reusable o-ring gaskets, better firing order( 4-7 switch,)better front cover(don"t have to drop the oilpan to change cam),what about those lifter trays to make cam swapping easy.Not to mention lightweight and compact design.
The ls1 responds well to most all cam changes compared to other motors,it depends on what you want.I believe that J-rod and Denzss(what happened to him?)got us all thinking more about cam choices and the design of such,J-rod has got me curious about LDA and how each would accelarate with a given load say a drag car that turns 4500 t0 7500 in a 5 second 1\8 strip.Hp is not just hp, some cars run quicker with less then others with more hp(explain that).Thats the fun of this stuff it keeps you thinking of new ways to do something.
The LS1 has the Ford Windsor / late model Ford 5.0 firing order if you renumber the cylinders. The 4-7 swap is different but the Ford firing order is also better than the original SBC as Ford figured out a long time ago and all new chevies are also like this even the new 8.0 stuff. The LS1 oiling system is not so good.
The old Chevy is 18436572
The 4-7 swap is 18736542
The LS1/Ford is 18726543
Old Aug 20, 2004 | 02:08 AM
  #365
SilverSurfer's Avatar
Well it's a well known fact that GM copies other manufacturers, they all do. The throttle by wire idea came from the 1990 BMW 750. GM went out and bought one and transplanted the engine into a Caprice.
I still don't see how the 3.8 copied the LS1 when the 3800 series I even had that style intake back in the early 90s. But that's not all that important.
The whole point I was trying to make is that "box" cams are good for some of us. Now, if someone could make a custom cam that fits my needs (smooth stock idle and better TQ and HP than an LS6 cam) I'm all for it and so would a good number of other people on this board. Ever notice what happens when an LS6 cam is posted in the Parts For Sale section? Someone snapps it up. In part because of the price and because not everyone wants a lumpy cam. Not every cam has to be max effort.
Another point I was trying to get across is that every cam designer has his own way of looking at what an engine's cam requirements are. Unless every cam design is tried on the dyno and track then all you're getting is a cam in a box that should do what the customer wants. Like I said give the top 5 cam designers all the info they require to design a cam for you and you'll get 5 different cams. That is unless they're all using the same software to design that cam. So it's not as simple as all that.
Old Aug 20, 2004 | 09:44 AM
  #366
J-Rod's Avatar
6600 rpm clutch dump of death Administrator
As stated, everyone copies everyone else. There is no secret there.
Composite manifolds are composite manifolds. I think you'll find some of the fiirst were on 4 cylinders. If it works, and its cheaper, GM will do it...
Agreed, and you can get a stock type idle cam, or a pretty stealthy cam anyhow. As for the Ls6 cams, folks do that for 2 reasons. The cam is cheap, and it can go in without much tuning in many cases. So its a cheap power adder. In thinking about your argument I see a couple of points here that have been glossed over.
You have a 224/224 114 that isn't tuned properly and has a poor idle and poor drivabilty. That is your frame of reference, and your point of view. If I was in your shoes I might be a lot more skeptical of what a bigger cam might do.
Can I make a suggestion? Get your car tuned, then see how you feel about the idle of a aftermarket cam in your car. Honestly, a 224/224 114 should not be an offensive cam.
Look, there are a couple of "givens" about a motor. If you look at what Ed, Chris, Mr. Rawls, Erik, David Vizard, and a whole host of other folks they are all saying the same thing which you seem to want to contradict. Why is that?
Not everyone uses a computer program to design a cam (but there is some software to help out with some of it). Also, I know for a fact that if I gave cam specs to two cam designers I'd get 2 different cams. If I gave them to 5 I'd end up with 5 different cams. But, whats different? Are you basing that just on duration @.050? What you and a lot of other folks out there are missing is ther is more to a cam than duration @ .050. When you start talking about duration @ .200 or .400 folks don't even know what to think. Thats been the point of this thread. Think about more than duration @ .050 and calling it a day. Ok, so the specs on paper look different, but are the cams themselves all that different? If you look at the total lobe area, and the valve events I'd bet you'd find they are a lot closer than you might think. Unless someone is doing something might tricky and making more or less power than the rest.
Here, I don't know if you remeber this thread.
https://ls1tech.com/forums/generation-iii-internal-engine/11-found-ultimate-old-man-cam.html
Call me fickle.
I love going fast like the next guy. That's why I've been running the awesome Thunder Racing reverse split 230/224 111LSA cam for quite some time. It's tops for max power. But I gotta admit something, I sure love the way a stock ZO6 idles and runs. Super smooth idle, no shake, no stinky exhaust, but BIG power. My SS convertible is so nice, I figured I could try to find my own cam that would idle like stock, but still pull over 400 rwhp. Back in the old days on another board, we used to have discussions on what would make for an ideal "old man" car.
Here's what we were trying to achieve:
1 Quiet exhaust, but free flowing
2 Smooth shake free idle, but not wimpy
3 Gobs of torque down low plus great power up high
4 Emissions legal
5 Low underhood noise (stealthy)
6 Wife, girlfriend, police approved
I got a call a few weeks ago from Geoff at Thunder Racing. He said he felt like he had come up with the ultimate "sleeper" cam (or Old Man Cam as I like to call it). The key elements to making power everywhere while keeping a super smooth idle would require using all the latest technology and experience Thunder Racing has developed for the LS1. Here's the cam:
214/220, .600/.527, 115 LSA, -2 degrees ground in
Now look at the specs for a little bit. At first glance, it looks like a conventional "split duration" cam. It is and it isn't. The ramps on the intake are super, super fast. The total area on the intake is quite a bit bigger than the exhaust. In essense, this is really a "reverse split" cam in execution (just like the ones Thunder Racing has had so much success with). The big lift on the intake side allows my SAM ported heads to breathe, but the short duration and wide LSA keeps the idle smooth. Most people make the mistake of running a short duration cam (like a 214-218 cam) with several degrees of advance ground in. This is wrong. When you're running too small a cam, you want to close the intake valve later (to keep peak power up high). We accomplished this by having the cam ground 2 degrees retarded. This allowed the intake valve to close at the same exact time as my 230/224 111LSA cam. Guess what? I still was able to make peak power at 6200-6300, just like my 230/224 cam. Most 214 cams make peak power at 5700-5800 rpms. Not this one. The rwhp numbers stayed with the 230 cam all the way to 6400 rpms (where the 230 kept on pulling). By extending power to 6300, I make at least 10 rwhp over a 214 cam ground +4 degrees advanced. The 214 cam was done by 6500 rpms, but the low and mid range torque and hp matched or exceeded the 230/224 cam. It's like having your cake and eating it too. No small cam I've seen ever made this kind of power everywhere. It flat kicks ***. Idle is smooth. Torque down low is abundant. Pull to 6400 is incredible. I now shift at 6400 vs. 6700 with the 230 cam. Under hood noise is noticably less (since only half the valves have super fast ramps).
Thunder Racing is encouraged by the results. Next they want to install it in a 6 speed car. Keep in mind, this cam was made for MY combination. My heads flow well to .600 lift, so I could use this kind of lift to my benefit. Also, I run double springs. I'm afraid 918 springs aren't up to the task on these super fast intake lobes. Gas mileage has improved, no more stinky exhaust, got to lower idle speed from 900 to 800. Sounds completely stock. Can't ask for much more than that. Call it a 2002 ZO6 cam on steroids, haha.
If you were wanting to lower the peak torque and hp points you could easily do that by advancing the cam 4 degrees, but that would give you less total hp and torque under the curve. Here's the thought process. A 214 cam is too small for a 346 with great heads. A 236 cam is too big. A 224 cam is just right. If a 224 is just right, it would run best with 0 advance. A 214 cam, being too small benefits by retarding the timing a few degrees. A 236 cam would benefit by running a few degrees advanced. The key is placing the intake closing point exactly where you want to make power. Close the intake later, you make peak power later and vice versa. I chose to mimic the intake closing point of the Thunder 230/224 111LSA cam, which is 45 degrees ABDC. The 2002 LS6 cam is 204/218 117.5 LSA with 2.5 degrees of retard ground in. It has an intake closing point of 42 degrees ABDC which is really late for a 204 @.050 cam, but that is why this little cam pulls to 6500. The Thunder Racing "Sleeper" cam makes more torque and hp at low and mid ranges than the TR230/224 cam, so I think that it would work incredibly well even with no gear!
The reasons why this cam is so awesome:
1. The wide LSA flattens the torque curve, makes power down low very smooth and strong, plus cleans up the idle and emissions.
2. The short intake duration with lots of lift gives as much "open area" under the curve as most 224 cams with.560 lift. The short duration cleans up the idle and keeps the torque down low nice and high.
3. The lazy ramp on the exhaust is easier on the valvetrain, reducing under hood noise, plus the longer duration helps with overlap. The reduced area under the curve (compared to the intake) makes this cam more like a "reverse split" duration cam. The cam would be more like a 214/208 cam if the exhaust had fast ramps too, but the added duration of the slower ramps help with overlap (which is a benefit when running headers).
4. The intake closing point of 44 degrees ABDC allows the motor to make peak hp much higher than most comparable cams with 214 intake duration. This is key in making the big rwhp numbers. Most 214 cams have 114 LSA and are ground with 4 degrees of advance. This makes the intake closing point 37 degrees ABDC which will only allow the engine to pull to 5700-5800 rpms before the power peak starts to drop. The extra 7 degrees of intake opening make this cam 7-10 hp stronger than a normal 214 cam.
  #367
J-Rod's Avatar
If you look up in that thread, Patrick and Thunder were trying to build a cam that had stock manners. They thought a bit more about it that many of the shops who would order smal lobes put them on a 114 or 115LSA, and then grind it +4 degrees and have a cam that runs out of steam @ 5200.
So, have you paid attention to the valve events? Look at the valve events of the Z06 cam. You can design a cam with similar events and make the power you are looking for. If you go with a lobe of 220 or less chances are if you do it right you won't have any overlap and thus no "chop". I'm not saying you have to put a 230 lobe on every cam. What I am saying is that the conventional school of thought which you are trying to propagate in this thread is that LSA is the magic bullet when in fact it is not. You have your motor, you have your heads. Now its time to pick lobes and valve events to get the job done. If you use a 220 or 218 or 215 lobe as long as you use the right valve events you can get a cam to meet your needs. But if you follow the conventional shool of thought and just keep spreading the LSa and adding advance, you will have a pig.
Other folks would prefer to use good valve events, a bigger lobe, and get a bit of overlap, and fill in the lower portion of the powerband that one of these small lobe cams won't have... The thing is you can go with a smaller cam than many of the "Box" cams, with a tighter LSA, get the same ovelap, and make power in more of the power band that the motor is capable of using.
Thats what I'm trying to point out here.
In the LS1 we have a couple of limitations:
Stock Type Intakes - Runner length dictates torque peak
Heads - Dictate lobes size, duration, and lift
Exhaust - Dictates I/E ratio
Valvetrain -Dictates operational RPM
If you design a cam for a motor and you design it so that it should make peak torque @ 5700, and peak power @ 7400, but the design of the motor only allows you to make peak torque by design @ 4200-4800 and peak power @ 6200-6500 does anyone here see an issue? Again, I don't think anyone is trying to say a "box" cam can't make X ammount of power. But what I think is trying to be explained is that you can build a cam that is designed better. In fact it may have less duration. It might have a tighter LSA it might even be retarded (imagine retarding a cam???) instead of +4. IT might have some chop to it, but it will probably have better drivability and make more power than an overly big, overly advanced cam that is designed wrong, but makes decent power.
Again, there is no magic LSA there is only opening and closing the valves at the right time... Thats all there is to this folks...
Old Aug 20, 2004 | 10:15 AM
  #368
JNorris's Avatar
Moderator
The last two posts just made all these cam and CFM threads worth reading. I have seen the light.
Thanks!
Old Aug 20, 2004 | 10:55 AM
  #369
Cstraub's Avatar
RAM Effect:
When the inertia of the intake charge "rams" the cylinder volume to produce greater cylinder pressure without the need for added cfm or greater compression.
To factor Ram % you have to deduct the Losses created by, Mechanical, Thermal, Pumping and Cycle time. You also have to take in piston velocity, hmmm Denzss does this remind you of a conversation, so for example on a 2 barrel engine with a PV of 3500 to 4500. Your RAM is 25% and your losses are 10%. Your RAM effect is 115%.
With 115% the engine is now, for lack of a better term "fooled" into thinking it has more air then it really does in the cylinder, but the dyno probe has measured what has gone into it. So this is where a "false" but usable number comes up.
Chris
Old Aug 20, 2004 | 11:27 AM
  #370
J-Rod's Avatar
The ProStock guys really work hard to tune a combo to achieve efficency far above the 100% that "should" be the limit of the engine's performance. As Chris has pointed out there are a lot of factors that have to be considered.
This is why the intakes nad heads of many P/S teams are so "secret" they don't want folks seeing how they achieve that ram tuning. This plays into a lot of X order wave dynamics. I have heard of folks looking all the way into the 7th order wave to achieve performance.
Think about it in this "very" simple explanation. Please don't crucify me if I am GREATLY oversimplifying many of the concepts needed to make this work.
You have a pressure wave each and every time you open and close a valve. You have a pressure that is pushing down the intake runner (atmospheric pressure). You have a reflected wave when the valve closes which is sent back up the intake runner for each cylinder, along with any reversion from overlap. In other words there are several waves (and harmonic events) which are bouncing around in this closed plenum.
What guys are doing is in a VERY small window is to try to catch that wave when it is reflected back, at some point in the intake cycle. What this does if you catch the wave correctly is to help stuff more air and fuel into that cylinder. Its a form of free supercharging in a very limited RPM window by taking advantage of certain harmonics in an intake manifold.
As for runner length tuning, that is one of the things I hope to play with in the coming year. Ideally you should tune everything from runner length, and cylinder heads, and also headers (primary length, 4-1, 4-2-1, etc...) and also design the cam accordingly...
Old Aug 20, 2004 | 01:57 PM
  #371
J-Rod's Avatar
So, lets discuss...
Anyone have the math for figuring out optimal intake runner length.
Or how about
Optimal primary length, optimal distance for Y's and secondary tubes in a tri-Y setup, etc...
Old Aug 20, 2004 | 02:00 PM
  #372
J-Rod's Avatar
A quick search reveals:
http://www.zaxjax.com/intake_runner_...calculator.htm
Intake Runner Length Calculator
http://www.zaxjax.com/IntakeRunnerCalcsRevised.xls
This is an excel spreadsheet I put together to help with finding the proper intake runner length for a tuned system. By taking advantage of the pulses created inside the intake runners, a ram charging effect will happen at a specified RPM.
Just to explain the layout, the first sheet is the stock ports and the second is a 1/2 bridge port for a 6 port motor. The timing numbers are estimates from timing graphs on the rotary engine illustrated site. The volume of intake charge after 3800 RPM is shared between the primary and secondary ports. This explains the second two sets of calculations involving what I called an adjusted displacement. The adjusted displacement is simply a fraction of the total displacement per rotor based on intake port areas. I am assuming the secondary ports are twice as big as the primaries, hence the 25%/75% ratio I did. You can change it if you want by adjusting the % in the constants section. This effects diameter only.
Anything in the constants section can be changed to affect the output.
Intake Runner Calculator
Explanation of the Calculations involved:
The following facts are based on empirical knowledge, direct observation and published data.
After the intake port opens, a low pressure pulse is produced. This pulse propagates along the intake runner until it reaches the end (the end being the point where the diameter of the runner increases significantly) where it inverts and returns as a high pressure pulse. It has been demonstrated that the characteristics of this pulse (amplitude, duration, slope) are proportional to the air requirements of the engine at that throttle setting and RPM. The runner length should be set so that the returning pressure pulse coincides with the closing of the intake port. For proper wave reflection the runner must terminate in a full radius bell mouth (Radius >25% ID for >90 degrees). The absence of the bell mouth will result in a vena contracta significantly smaller than the runner ID and attendant flow losses.
The intake tube ID should be selected so that the mean air velocity during the intake period is 100 meters per second (3937 inches per second). For a 40 cuin rotary at 6000 RPM and a Ve of 1.0 the intake runner diameter should be 1.313 (1.50 tube with a 0.065 wall). For a Ve of 1.3 you want an ID of 1.497 inches.
At 6000 the port open duration is 0.0075 seconds. Sea Level speed of sound is 1100 ft/sec so the propagation distance for the port open period is 99 inches. The peek amplitude of the of the induction pulse occurs between 25% and 30% of the initial port opening, therefore the optimal propagation length should be between 40% and 50% of the total. The runner length is 1/2 the propagation length or, in this case, between 19.8 and 24.75 inches. Actual length must be determined empirically.
Of course this is for a rotary, but maybe it can be modified for a conventional motor.
Old Aug 20, 2004 | 02:05 PM
  #373
J-Rod, your post goes to illustrate my point of view. LSA plays a very important part in the idle characteristics of a cam. That's the only school of thought I'm propagating. And in that cam it obviously works. They built a cam that to a degree (or -3 degrees lol) mimics the LS6 cam, with a wide LSA for smooth idle and a retarded ICL for added RPM capability. They went around duration by means of added lift. That's alot more innovative than big duration/narrow LSA, or big duration/wide LSA for that matter. And the best part is that it was made in conjunction with one of the first LS1 "box" cam sellers.
The RAM effect is a proven phenomenon, but I think it's kinda pointless when it comes to LS1s with plenum intakes and aftermarket cams. It would take ALOT of dyno time to get right combination to get a RAM effect in an LS1. For the "most" part it's race car stuff, but obviously it's taken into consideration even by the factory when they design an intake manifold.
Old Aug 20, 2004 | 02:13 PM
  #374
J-Rod's Avatar
See, you still have it all wrong. They didn't pick a wide LSA and go from there. They selected a small lobe to keep overlap down. They selected the valve events needed to achieve the RPM they needed, and the LSA and advance or retard in this case falls out the bottom as dictated by the valve events. In this thread and others we have addresed the idea of trading lift for duration and vice versa. Unless you have a compelling reason for doing so I don't. In some class racing we do we are limited to .485 lift at the valve. So, we trade that off by using a ton of duration to compensate. Again, it all depends on what you or the other guys wants. I'm not saying its wrong to want a stock idiling cam, but its also not wrong to want a cam that has good manners and more low end, and a little bit of lope either. Most folks in here are not asking about stock cams hence the reason cams like the T-Rex, X3, G5X3, and others are so popular. Most folks it the Performance section want Performance... I'm not faulting you for wanting a stealth cam. I see lots of uses for one. I'm just saying if you aren't limited by a constraint (like yours of a stock idle) then for max power I would look in other directions.
You are right witht he stock manifold its probably not going to happen. But if you can do a 8tb intake you have other options...
Old Aug 20, 2004 | 02:21 PM
  #375
True the LSA is a byproduct, but I'm willing to bet that when the cam specs were being decided upon this byproduct was taken into great consideration. Just take a look at the first reason being given as to why this cam is so great. But aside from that, if the cam specs produced say a cam with a 110 lsa, it would not have fit Patrick's requirements for a smooth stock idle.
And yes with 8 TBs you can do ALOT more than with a $350 LS6 intake. Like wide LSAs it's just another compromise, but still alot can be done even when compromising.
Old Aug 20, 2004 | 03:00 PM
  #376
racer7088's Avatar
Arrow
Originally Posted by J-Rod
So, lets discuss...
Or how about
J-Rod you are the ulitimate in these threads becuase this is where I am right now doing some sheet metal stuff thats just plain crazy! It gets really interesting the farther you go. You have to decide which pill you want to take and then you can't go back.
Old Aug 20, 2004 | 03:05 PM
  #377
racer7088's Avatar
Thumbs up
Chris,
Speaking of TQ plates, we sat Cleveland heads on an LS1 one time and took pictures at SAM but got in trouble for putting Ford heads on it! Not really but it is a close fit!
Thankfully with the LS1 the stockers are probably the best heads ever put on a small block of any make!
Old Aug 20, 2004 | 05:31 PM
  #378
Ed Curtis's Avatar
Exclamation
Originally Posted by racer7088
Chris,
There's picture of Grumpy putting a Cleveland tunnel ram "intake" on a small block Chevy short block in one of his famous "Jenkins" books...
Really funny...
Silver: Repeat after me... "Timing events, timing events, timing events..."
Ed
Old Aug 20, 2004 | 05:53 PM
  #379
Ed - Repeat after me......
Yabba Dabba Dooo
Old Aug 21, 2004 | 01:09 AM
  #380
Ben R's Avatar
I was wondering when somebody was going to start serious R&D on sheet metal manifold for these LS1 cars. For a few weeks it looked like the new FAST manifolds were going to be a winner, but their performance isn't exactly what some thought it was going to be.
What CID motors are the manifolds you're working on designed for? Anything for a 382/383 inch motor?
