Advanced Engineering Tech For the more hardcore LS1TECH residents
Camshaft discussion: CFM requirements by RPM.
Old 05-07-2004, 08:07 AM
  #301
Cstraub's Avatar
Black,
Your welcome. J-rod, that is the first time I have ever seen Ed give any "specs" out. You better mark this day.
Chris
Old 05-07-2004, 08:29 AM
  #302
Ed Curtis's Avatar
Originally Posted by Cstraub
Black,
Chris
Well...
There's a few times where I get weak...
BTW... nothing from Watson Racing yet...
Why is it your customers are slow paying???
Ed
Old 05-07-2004, 08:40 AM
  #303
6600 rpm clutch dump of death Administrator
J-Rod's Avatar
Black,
Chris
I am, I am.
Ed, and Chris both. Thank you both for your input. Hopefully discussions like this will help folks think about more than just LSA.
I do think its interesting though...
Chris:
233 Int.
229 Exh.
Max HP at 6100 will pull till 6500
Max Torque at 4300
Ed:
.585" Int - .575" Exh
232* Int - 234* Exh @ .050"
111* LSA - 110* ICL
Of course depending on lobes design and rocker ratio, these could be identical cams.
Old 05-07-2004, 09:01 AM
  #304
99 Black Bird T/A's Avatar
Received 1,454 Likes on 1,008 Posts
Beast,
for the Absolute LS6 2.75 head listed above that flows 294 cfm at .600, my ghetto math says the following...
383/2*6800 divided by 1728 = 753 cfm needed
753/8 is 94.2 per cylinder
to get 94.2 in per cylinder with 294 of flow w/intake
94.2/294 = .320 out of 720 degrees of rotation
720*.320 = 230.4 degress of intake duration
~230.4 of intake duration which is actually smaller than most 383 use. Of course very few heads can flow like Jay's or TEA's.
Old 05-07-2004, 09:03 AM
  #305
Wow Ed actually gave us a number of a cam....I'll mark this in my calander too Chris & J-Rod.
Old 05-07-2004, 10:21 AM
  #306
DenzSS's Avatar
Damn those numbers at .050" are a bitch....just can't tell what is going on.
Thanks for participating Ed and Chris. It is greatly appreciated.
Maybe our next conversation should be a discussion on how poor of a performance metric horsepower is....
Old 05-07-2004, 12:16 PM
  #307
Cstraub's Avatar
Glad I could input. Duration needs to be address from the seat duration all the way up the lobe. By selecting lobes that compliement the heads, a well balanced combinaton can be had by the end user.
Chris
Old 05-07-2004, 01:05 PM
  #308
J-Rod's Avatar
DenzSS - Where is that math you promised us?
Old 05-07-2004, 01:18 PM
  #309
DenzSS's Avatar
Doh. I'll get the equation written out this weekend.
Old 05-07-2004, 01:32 PM
  #310
DenzSS's Avatar
This will get you the velocity and acceleration curves, the cfm is fairly easy after that.
You can see how it is much easier to do in an application...
Old 05-07-2004, 03:59 PM
  #311
SScam68's Avatar
thats a nasty derivative
Old 05-07-2004, 04:07 PM
  #312
Looks simple enough to crunch.
What does each of the variables stand for? I'm guess r is radius but have no idea bout b,w, t etc.
Thanks
Old 05-07-2004, 05:02 PM
  #313
lsx24's Avatar
Thanks
Yes, and sorry if I missed it inside the calculations but all are a function of t, but what do the 3 calulate in relation to t?
Old 05-07-2004, 05:12 PM
  #314
Beast96Z's Avatar
Beast,
But as you can see, you had to add the larger heads to get the formula to work. If a person where stuck with poorer flowing heads, such as the heads in the first equation (275 w/intake) the cam would have to be in the 250* range according to the math. Then again, what about more CI eating up camshaft? Now we have a 383 with less camshaft than the 346. Can you guys hit on adding CI to the mix? I'd like to see how that factors into the equation.
Old 05-07-2004, 08:30 PM
  #315
verbs's Avatar
Beast,
Using your ghetto math I cam up with about a 218 intake duration for my car LOL!!
Old 05-08-2004, 10:56 AM
  #316
jmorgan's Avatar
I have a 2000 v6 camaro A4
Heads with intake might flow say 170ish, the max ive seen or heard ported heads for my car flow 235-240ish with no intake
from the getto math I came up with
(231ci/2)*6200rpm/1728= 414cfm
414/6 cylinders= 69cfm per cylinder
69/170 cfm(head flow)= .405
.405*720= 292 duration
that would be a huge cam
unless my head flow numbers were off by over 50cfm more which I know cant be
anyone know whats wrong (besides missing 2 cylinders)?
ohh yea lift is limited to about .520 with stock heads
Old 05-08-2004, 02:28 PM
  #317
BADFNZ's Avatar
Originally Posted by J-Rod
I am, I am.
Chris:
233 Int.
229 Exh.
Max Torque at 4300
Ed:
111* LSA - 110* ICL
The cam I came up with for this situation was:
(@.050)
Intake Duration - ID 234/.588
Exhaust Duration - ED 230/.582
Lobe Center Angle - LCA 111
Intake Centerline - ICL 109
This was before the experts posted theirs. "I'm learnding"
Old 05-08-2004, 09:55 PM
  #318
critter's Avatar
Thanks
Black Bird and Carvinta - you can find answers here. Rollins gives the derivation and tells what the variables are. Good stuff.
Old 05-09-2004, 06:41 PM
  #319
lsx24's Avatar
That's impressive. That'll take another couple mods to digest.
Old 05-10-2004, 05:50 AM
  #320
jrp
SN95 Director
jrp's Avatar
this thread is , great info.
Quick Reply: Camshaft discussion: CFM requirements by RPM.
