Advanced Engineering Tech For the more hardcore LS1TECH residents
What affect does advance ground into a cam have?
Old Oct 23, 2003 | 06:58 PM
mikey's Avatar
LS1TECH Sponsor
Default Re: What affect does advance ground into a cam have?
Cam Card will tell you but the ONLY way to tell exactly is to measure it in the motor. We have seen advertised specs vary from 1 - 4 degrees depending on the grind and manufacturer.
Old Oct 23, 2003 | 07:24 PM
2001 Pewter WS6's Avatar
Restricted User
Ok so say that it came with +4 ground in and I advanced it +4 more. The peak power is supposed to be around 7200 rpm. Where would it effectively be at +8 advance. How much power am I giving up here? In rwhp and in track ET/MPH. Approximately?
Old Oct 23, 2003 | 07:48 PM
J-Rod's Avatar
6600 rpm clutch dump of death Administrator
Most cams from the aftermarket come with +4 ground in from the very start. So, on a 114LSA you end up with a 110ICL. Add another +4 and you are at a 106ICL. LSA cannot change ICL can as a function of an adjustable timing gear. Read the Comp article on cam basics.
Also, some of this might be a bit to much on the techo-babble side. But here goes...
Lobe centerline: This represents an imaginary line referenced from the true center of the base circle out to the end of each lobe, in crankshaft rotational degrees. Intake centerline values are found in the crankshafts rotation ATDC, while exhaust centerlines are found at travel BTDC. Lobe centerlines are commonly thought to be the actual mid-point of the flank and are usually close to that, but different ramps on the opening and closing sides may change that reading. For this reason the true center of the cam core is used as a reference. For those who use the intake centerline method for degreeing in a camshaft, you can now see how if the phase of the camshaft is off, it will require a different amount of crankshaft rotation to find this point. When using the intake centerline method lower crankshaft rotational degrees represent the cam being in early or advanced. This statement is correct since in relation to the crankshaft's rotation ATDC, the valve event happens sooner.
Lobe separation angle (LSA): LSA is measured in camshaft degrees and refers to the amount of rotation it takes to travel from the intake centerline to the exhaust centerline. As this number grows, the distance between the centerlines is spread out. Often LSA is considered an indicator of overlap, or the period of time that both valves are open on the same cylinder. Because it is a partial function of LSA, overlap can be calculated with fair accuracy using duration and LSA values. The issue concerning this is you need accurate duration numbers at 0.006 inch to calculate overlap at the industry standard.
The following equation can be used for the approximation of overlap:
For single pattern (duration being equal on both the intake and exhaust lobes):
Overlap = Dur. - 2 X (LSA)
For split-duration cams (different durations on intake and exhaust lobes):
Overlap = Intake Dur. + Exhaust Dur./2 - 2 X (LSA)
NOTE: Non-symmetrical cam lobes will have increased error using these calculations.
Not a single function of LSA alone, overlap is affected by changes in centerlines, ramp designs, and duration. The rumpty-rump sound that we all love in a hot LSx engine is the hallmark of overlap. Used to help scavenge the cylinder, overlap is a function of the complete cam design.
Now some VERY general info on what advancing a cam will do.
By advancing the cam, the valves open and close earlier. Duration and overlap remain unchanged. Advancing raises the cylinder pressure (due to earlier valve closing) This improves low end and mid-range torque at the expense of some top-end power. The result is similar to using a shorter-duration cam since the intake valve closing point is more critical than its opening point.
Retarding the cam so valves open and close later has the opposite effect. This should increase top-end power, at the expense of low end, and mid-range torque. Thus: 1) Advance Cam: More low and mid-range torque, 2) Retard Cam: More top-end power.
Advancing and retarding are easily accomplished with offset bushings or keys for the cam or crankshaft, depending on the engine. The bushings and keys are usually supplied in increments of 2, 4, 6, and 8 crankshaft degrees. Remember that one crankshaft degree equals two camshaft degrees.
Trial and error is usually the best method when advancing or retarding a cam to alter performance. I.E. make a change go make passes and see if the car makes more power.
Before attempting to advance or retard a cam, you must know the actual valve timing, not the manufacturer's specifications. I.E. Use a degree wheel and don't believe your cam card. They have been known to be wrong...
Advancing and retarding a camshaft will move valves closer to the piston. Valve-to-piston clearance must be checked after advancing or retarding alterations to prevent possible engine damage. Also, changing the cam timing will also change ignition timing, which must then be reset.
A bit of the same info from Crane...
What is meant by basic RPM?
The camshaft’s basic RPM is the RPM range within which the engine will produce its best power. The width of this power band is approximately 3000 to 3500 RPM with standard lifter cams, and 3500 to 4000 RPM with roller lifter cams. It is important that you select the camshaft with the “Basic RPM Range” best suited to your application, vehicle gearing and tire diameter.
What is camshaft duration and why is it important?
Duration is the period of time, measured in degrees of crankshaft rotation, that a valve is open. Duration (at .050” lifter rise) is the deciding factor to what the engine’s basic RPM range will be. Lower duration cams produce the power in the lower RPM range. Larger duration cams operate at higher RPM, but you will lose bottom end power to gain top end power as the duration is increased. (For each ten degree change in the duration at .050”, the power band moves up or down in RPM range by approximately 500 RPM’s.)
What is the difference in advertised duration and duration at .050” lifter rise (Tappet Lift)?
In order for duration to have any merit as a measurement for comparing camshaft size, the method for determining the duration must be the same. There are two key components for measuring duration— the degrees of crankshaft rotation and at what point of lifter rise the measurements were taken. Advertised durations are not taken at any consistent point of lifter rise, so these numbers can vary greatly. For this reason, advertised duration figures are not good for comparing cams. Duration values expressed at .050” lifter rise state the exact point the measurement was taken. These are the only duration figures that are consistent and can accurately be used to compare camshafts.
How does valve lift affect the operation of an engine?
Lift is the distance the valve actually travels. It is created by the cam lobe lift, which is then increased by the rocker arm ratio. The amount of lift you have and the speed at which the valve moves is a key factor in determining the torque the engine will produce.
What is camshaft lobe separation and how does it affect the engine?
Lobe separation is the distance (in camshaft degrees) that the intake and exhaust lobe centerlines (for a given cylinder) are spread apart. Lobe separation is a physical characteristic of the camshaft and cannot be changed without regrinding the lobes. This separation determines where peak torque will occur within the engine’s power range. Tight lobe separations (such as 106°) cause the peak torque to build early in basic RPM range of the cam. The torque will be concentrated, build quickly and peak out. Broader lobe separations (such as 112°) allows the torque to be spread over a broader portion of the basic RPM range and shows better power through the upper RPM.
What are intake and exhaust centerlines?
The centerline of either the intake or exhaust lobe is the theoretical maximum lift point of the lobe in relationship to Top Dead Center in degrees of crankshaft rotation. (They are shown at the bottom of the camshaft specification card as “MAX LIFT.”) The centerlines of the intake and exhaust lobes can be moved by installing the camshaft in the engine to an advanced or a retarded position. Generally speaking, the average of the intake and exhaust lobe centerline figures is the camshaft lobe separation in camshaft degrees.
How does advancing or retarding the camshaft’s position in the engine affect performance?
Advancing the cam will shift the basic RPM range downward. Four degrees of advance (from the original position) will cause the power range to start approximately 200 RPM sooner. Retarding it this same amount will move the power upward approximately 200 RPM. This can be helpful for tuning the power range to match your situation. If the correct cam has been selected for a particular application, installing it in the normal “straight up” position (per the opening and closing events at .050” lifter rise on the spec card) is the best starting point.
Why is it necessary to know the compression ratio of an engine in order to choose the correct cam?
The compression ratio of the engine is one of three key factors in determining the engine’s cylinder pressure. The other two are the duration of the camshaft (at .050” lifter rise) and the position of the cam in the engine (advanced or retarded). The result of how these three factors interact with one another is the amount of cylinder pressure the engine will generate. (This is usually expressed as the “cranking pressure” that can be measured with a gauge installed in the spark plug hole.)
It is important to be sure that the engine’s compression ratio matches the recommended ratio for the cam you are selecting. Too little compression ratio (or too much duration) will cause the cylinder pressure to drop. This will lower the power output of the engine. With too much compression ratio (or too little duration) the cylinder pressure will be too high, causing pre-ignition and detonation. This condition could severely damage engine components. It is important to follow the guidelines for compression shown on the application pages of the catalog.
How does cylinder pressure relate to the octane rating of today’s unleaded fuel?
In very basic terms, the more cylinder pressure we make the more power the engine will produce. But look out for the fuel! Today’s pump gas is too volatile and cannot tolerate high compression ratio (above 10.5:1) and high cylinder pressure (above approximately 165 PSI) without risking detonation. Fuel octane boosters or expensive racing gasoline will be necessary if too much cylinder pressure is generated.
How does an increase in rocker arm ratio improve the engine’s performance?
The lobe lift of the cam is increased by the ratio of the rocker arm to produce the final amount of valve lift. A cam with a .320” lobe lift using a 1.50:1 ratio rocker arm will have a .480” valve lift (.320” x 1.50 = .480”). If you install rocker arms with an increased ratio of 1.60:1, with the same cam, the lift would increase to .512” (.320” x 1.60 = .512”). The engine reacts to the movement of the valve. It doesn’t know how the increased lift was generated. It responds the same way it would as if a slightly larger lift cam had been installed. In fact, since the speed of the valve is increased with the higher rocker arm ratio, the engine thinks it has also gained 2° to 4° of camshaft duration.
Old Oct 17, 2005 | 12:09 PM
Nine Ball's Avatar
LS1Tech Co-Founder
TTT for new forum
Old Oct 20, 2005 | 08:35 AM
BURN'EM's Avatar
Ok I used to think I knew this stuff. Now I have a question. ok your cam reads 114+4 this does not make it 118 it makes it 114 b/c it was a 110 that added 4* to make and advanced 114, right?
So If you turn it back 2* it would be a 112?
I was ok for years till I read this, thanks guys now I'm falling apart here.
Old Oct 20, 2005 | 12:46 PM
SStrokerAce's Avatar
Ok lets make this simple....
Lobe Seperation Angle (LSA) is a byproduct of the Intake Centerline (ICL) and the Exhaust Centerline (ECL)
To get LSA you add ICL and ECL and divide by two.
So if you have a cam with
114 LSA
If it's not advanced or retarded the ICL and ECL will both be 114 (114+114 / 2 = 114)
If it's advanced 4°, then you will have a ICL of 110 and a ECL of 118 (110+118 / 2 = 114)
Starting to make more sense???? You can't teach ICL without ECL or ****'s get confused.
Bret
Old Oct 21, 2005 | 01:13 PM
J-Rod's Avatar
Most cams come ground +4 because people always put too much cam in their car. The +4 helps to overcome the car being "overcammed" and helps wake up what would otherwise be a "soggy" bottom end. +4 is just what most of the mfg's (Comp and Crane) do by default, thus it trickled into most "shop" cams.
When you see a cam come in +0 or ground -3 or something like that, it usually means someone actually put some thought into what they were doing and why. Its not to say +4 is bad, its just folks seem to get hung up on a certain number and not the events behind them.
Old Oct 21, 2005 | 06:31 PM
I agree with that notion... some cams need advance to work, a good amount of them dont
Bret
Old Oct 30, 2005 | 07:32 PM
vettenuts's Avatar
So if you grind in more advance, say 5*, when the power peaks will it also roll off faster?
Old Oct 30, 2005 | 08:02 PM
Sport Side's Avatar
You might start a new trend.
Old Nov 3, 2005 | 02:19 PM
WAHUSKER's Avatar
Another thing about advancing the cam (during install) that we have been discussing is what affect it has on your timing. Since the cam position sensor is what the PCM uses for setting ignition advance, it seems reasonable that the timing should be adjusted too (in the opposite direction and in equal value). Meaning if you advance your cam +4*, you would then need to pull 4* from your timing tables.
