Bore materials: Steel vs Nikasil (or chrome)
I know of several advantages of nikasil bore VS a standard steel bore-
Better Heat transfer into the block, due to not having steel to travel through
Less piston/ring friction
Less wear
better high rpm durability with tighter tolerances
Is there more good things that a hard coating could do for an engine that I am missing? What if any reasons are there that people arent using this to their advantage? Why isnt GM interested in this? seems like the Piston slap issue could be overcome by using a cylinder coating instead of the band aid fix that was done with the LS6 pistons. As a bonus we might get a little more HP out of the same Head/cam combos, IMO.
my 2.5EFI is a little more basic, it measures air and throttle position, but no tattle tale on me when I run it WFO at 8000rpm untill the tank goes dry
I car at 150 mph is NOTHING like a 20' bass boat at 100...
Back to the topic though... yeah, the repair costs are higher but the engines would last longer at a higher rpm for a longer time as stated above.
jmho
Do some searching on XJ8 V8 Nikasil issues or BMW issues and you will see plenty. Basically dodgy gas with higher than normal sulphur content will degrade the coating and the next thing you know you have iron rings ripping away at your now aluminium bore. Not nice.
The Jag fix was to fit Steel bore liners.. My XJ8 appeared to have died in this manner. Life on average is 100K Miles before death. Jag replaced many under warranty.
I for one am glad my bores are Iron. GM isnt cutting edge, but by heck they are reliable in the main.
Richard
jmho
Mint.
Mint.
I miss the thrill of the wild "water rides". Left Sacandaga Lake this morn. Was lookin out and wishin I was ripping across the lake.
The new toy takes some of the pain away!!
