Advanced Engineering Tech For the more hardcore LS1TECH residents
Why "zero deck" custom pistons?
Old Oct 19, 2005 | 09:53 PM
mattr228's Avatar
Originally Posted by Zippinzee
The zero deck is to keep the compression at a reasonable level with the 408 cubic inches of displacement. If you run the pistons .008 out of the hole and use a .040 gasket on a 408 I am pretty sure the compression will be too high.
that would affect it so much , somewhere around .21 gain in compression
not as dramatic as you are making it sound
Old Oct 19, 2005 | 09:58 PM
SStrokerAce's Avatar
The quench depends on the material in the block... iron and Al have different quench needs.
Bret
Old Oct 20, 2005 | 01:50 AM
Keith's Avatar
I know it's 2 strokes and all, but there is some good infor regarding quench here:
http://www.aircooled-rd.com/squish1.htm
Old Oct 20, 2005 | 01:04 PM
Zippinzee's Avatar
I believe it is closer to .30 but my point is there is going to need to be some adjustments made to lower the compression for a street car and most definitely on a forced induction so why shoot your self in the foot and start with a piston .008 out of the hole. I am pretty sure that is what the piston manufacture was thinking.
