Advanced Engineering Tech For the more hardcore LS1TECH residents
How critical is piston deck height & quench distance for an LS1?
Old Nov 14, 2003 | 05:48 PM
J-Rod's Avatar
6600 rpm clutch dump of death Administrator
Originally Posted by 2000RATA
I hate to be a dick but J-Rod you did not write that yourself. That is word for word from I believe SpeedOMotive's website. I'll have to look tonight to be sure. Own up to it, you copied and pasted.
Chris
Ok, so don't be then. I did a search, found a better article on quench than I could write myself in a short period of time, and I pasted it in. In fact it came from a Pontiac site. I changed the wording since it made references in there about "I did this" or "I did that". Since I didn't I edited it to just speak on the facts, and not any personal "I did this". But for the record I keep my quech area around .035-.040.
Old Nov 15, 2003 | 02:25 AM
2000RATA's Avatar
Like I said I'm not being a dick. I was just trying to razz you a little. I should have used the approiate emoticon to express that. I met you at the shootout. It's all good.
Chris
Old Nov 15, 2003 | 11:26 AM
J-Rod's Avatar
Chris
Like those???? Don't worry, its all good...
Old Nov 15, 2003 | 12:20 PM
93PONY's Avatar
Glad to see you guys have a good handle on this.
I keep quench between .035-.045 max.
& I would also recomend Cometic gaskets. They have gaskets from .025 - .125 thicknesses & will custom make them for your application if neccessary.
Old Nov 16, 2003 | 10:53 PM
John B's Avatar
Moderator
93Pony, with this being the case should I even bother decking the block? Should I just get a custom head gasket to obtain the desired 0.035"-0.045" depth and not worry if the pistons are 0.004" in the hole?ghhhh
Old Nov 16, 2003 | 11:22 PM
93PONY's Avatar
That's what I did.
My new motor has the pistons .005 IN the hole. I bought .035 Cometics to get the right quench.
Which ever way is cheaper IMO....both ways will work.
Old Nov 16, 2003 | 11:26 PM
Brains's Avatar
My pistons ended up being .010 out of the hole, and I run a .041 gasket. Great octane tolerance, zero problems so far with detonation. Motor runs great, despite the poor heads I have on there
Old Nov 17, 2003 | 09:14 AM
John B's Avatar
Moderator
That's what I did.
Excellent! My questions are now all answered!
Old Oct 19, 2005 | 09:11 AM
Nine Ball's Avatar
LS1Tech Co-Founder
good info - moving to Advanced Forum
Old Nov 4, 2005 | 06:06 PM
LSwonderfull's Avatar
In blueprinting my LS6 short block I noted that the piston sits 0.004" below the deck height and when I combine this with the correct GM head gaskets for my LS6 heads the quench distance appears to be 0.064". This seems awfully high to me for an LS1. Should I be decking the block surface to obtain a positive piston deck height above the block to decrease the quench distance? I plan on running static compression in the 11.8:1 range on pump gas.
Yes thats too much clearance, i safely run GM skirt coated, thermal barrier coated Eutectic pistons with .007"+ deck displacement, along with Cometic .040" MLS gaskets for a Quench clearance of .033". My compression is 11.3 with a 62cc LS1 head. No false knock from piston to head contact, runs great on 93 octane, puts down estimated 450 rwhp based on mph and vehicle weight, and gets 18mpg average including weekend of racing on tank of gas!
Old Nov 4, 2005 | 10:21 PM
Mr. Luos's Avatar
Very good info....
Still having a question though.
62cc heads
Mahle -12cc full dish pistons (.008 out of the hole)
Cometic .045" gaskets
402 LQ9
Is quench area less with a full dish piston??
To me, the quench area would be the full volume of each cylinder, regardless of the shape of the piston. But I am also fairly new to this. To me a -12cc full dish piston would have the same quench as -12cc reversed dish piston. Correct me if I am wrong, still learning about quench.
Old Nov 7, 2005 | 08:51 PM
  #32
Ed Wright's Avatar
9-Second Club
.040" is certainly plenty with a steel rod, and especially an aluminium block. I have never used more than .036" with steel rods and iron block, I shoot for .032". When everything is dead nuts, nothing touches, and no carbon forms in the squish area. You can angle the deck of the piston a tad and get away with even less. Since aluminium blocks grow taller at temp, you can run them a tad closer (cold). I ran my 4.125" bore aluminium Rodeck block sprint car engines (Carillo rods) with .034" squish (Fel Pros & .002" out). Ran them 8300/8500 RPM all night long, nothing ever touched. Larger bores &/or looser-fit pistons need more room (piston rock), aluminium rods need more room (you know why). I used .038" to .040" squish on my last drag race engines, but those were 9800 rpm 3 7/8" bores and aluminium rods. I have found tighter squish always makes more power. This is all so much easier now that we have gaskets made any thickness we need.
Good luck, Ed
Old Nov 7, 2005 | 08:56 PM
  #33
Ed Wright's Avatar
9-Second Club
Originally Posted by Mr. Luos
Very good info....
62cc heads
402 LQ9
Squish is the distance between the piston deck (flat area, not the dish) and flat part (gasket surface) of the heads at TDC. .008" out, with .045" (if that is the compressed thickness) gaskets, would be .037" squish.
Good luck, Ed
Old Nov 7, 2005 | 09:40 PM
  #34
DeltaT's Avatar
When people quote from other sources they should cite the source. No worries about plagarism then.
Jim
Old Nov 7, 2005 | 09:46 PM
  #35
MadBill's Avatar
On re-reading this thread, I realize most of us use the words "squish" and "quench" interchangeably, which is not unreasonable, since they describe the same close-clearance region of the combustion chamber. However, apart from confusing anyone new to the concept, there is a subtle assumption baked into these word choices, which I think is misleading: "Squish" tacitly indicates that the operative phenomenon is the ejection of a high speed, turbulence-inducing gas jet from between the head surface and the fast and closely approaching piston, thus increasing turbulence = improved flame speed = reducing spark advance requirements = less negative work on the piston's upstroke and reduced time for detonation to raise its ugly head.
"Quench" on the other hand seems to suggest directly damping out detonation by sucking heat out of the mixture in this sensitive region via a combination of large, relatively cold, metal surfaces and perhaps some turbulence to increase the heat transfer.
My money's on "squish" as the more accurate description. Comments?
Old Nov 7, 2005 | 10:05 PM
  #36
MadBill's Avatar
Also, I think what Mr. Luos is asking: "Is quench area less with a full dish piston??
To me, the quench area would be the full volume of each cylinder, "
relates to how much of the piston/head area is considered quench/squish, i.e., a full dish piston might have only say a 0.300" band of flat horizontal surface around the edge, of which only 1/4 might mate closely with a similar flat head surface, thus the squish area would be ~ (0.3 x 4.0 x Pi)/4 = 0.94 square inches. A partial dish piston might have 2 or more square inches of squish surface.
This raises the interesting question: How much squish area do we want, and how should it be distributed? If there is a lot in one region, there will be a large, high velocity jet, producing lots of turbulence in its path. If the area is similar but distributed all around the piston, it will produce lower velocity jets, but perhaps more net turbulence, due to the colliding streams...
Old Nov 7, 2005 | 11:24 PM
  #37
Old SStroker's Avatar
Taylor and Taylor use "squish". They wrote the "book". I go along with them and MadBill.
T & T list the following desirable characteristics of combustion chambers from the point of view of attaining the highest resistance to detonation:
1. Small bore
2. high velocity through the inlet valve
3. Short ratio of flame path to bore
4. Absence of hot surfaces in the end-gas region
5. Use of squish areas, particularly in the end-gas region.
The point out that 1. and 2. often conflict with the need for high volumetric efficiency, and that they will be chosen by consideratioins other than resistance to detonation.
[The Internal-Combustion Engine by C.F. Taylor and E.S.Taylor]
The most recent Engine Masters Challenges have become an exercise in limiting detonation while making prodigious power and torque. Jon Kaase used the small bore approach quite successfully.
Old Nov 8, 2005 | 09:52 AM
  #38
Adrenaline_Z's Avatar
Is it just me, or would we all run 0.000" quench height if we weren't worried
about thermal expansion and mechanical clearance?
I'd rather push everything toward the valves, and keep most of the boom in
the chamber than down in the bore upon ignition.
Isn't it better to add the volume to the chamber when moving the charge from
the quench area? That means SCR stays pretty much the same.
We're just behind the 8 ball because of the cylinder head and valve train design. Which brings on another question about cross flow /hemi heads:
How much less does detonation come into play with an open chamber?
The temperature across the bore would be fairly even in comparison correct?
Maybe an LT-5 head would be better suited for this discussion since it's closer
to home.
Old Nov 8, 2005 | 11:44 AM
  #39
to home.
Isn't Hemi design undesirable for its poor combustion efficiency? Unblown i'm talking about? Wedge has better comb. control the way i understand it. Anyone?
Old Nov 13, 2005 | 07:53 AM
  #40
383ss's Avatar
so how much is too LITTLE quench generally?
my pistons come out .015 and I have run a .040, .043 and .055 gaskets.
the .040 leave very little, carbon in the quench area. just going to the .043, it leaves a LOT more. but that is only .025 quench for the .040. is that pushing it? I have an iron block and obvioulsy aluminum heads.
