Overlap, how much do you need?
Since the plenum is pressurized, there is a good chance the chamber will be
above atmospheric pressure during the overlap period.
That means, IVC tuning and scavenging do not need to be 'excessive' in duration
to achieve good results.
I'm not aware of any boost cams that do not have any overlap. I would think
there is a need for even a few degrees to purge the chamber after each exhaust
stroke.
I'm referring to seat to seat timing when discussing overlap. I would also guess
that overlap duration is proportional to boost level in turbo/supercharged motor.
In other words, the gas speed through the valves at 15 PSI would need much
less time to scavenge the chamber than at 5 PSI (resulting in less overlap).
