Advanced Engineering Tech For the more hardcore LS1TECH residents
Difference in horsepower production and cylinder pressure...
Old Nov 21, 2005 | 05:34 PM
Phil99vette's Avatar
7 Second Club
Default Difference in horsepower production and cylinder pressure...
Here is my question. What difference does the power adder play in how much cylinder pressure your engine makes? Here's what I am trying to figure out...
Setup 1:
High Compression Big inch motor makes 900rwhp
Lots of cubes: 450+ CID + high compression
Setup 2:
Low Compression 340-360 inch motor that makes 900 rwhp
- turbo motor boost comes on progressive like any normal setup.
Setup 3:
Medium Compression 340-360 inch motor that makes 900rwhp
- Nitrous motor with a progressive controller to control cylinder pressure spikes, each stage is phased in over 1 second to mimic how a turbo comes on line.
Which setup would be more durable assuming the tune was dead nuts on and you bang on it all the time???
Phil
Old Nov 21, 2005 | 06:39 PM
Beast96Z's Avatar
I would assume that the big inch motor would be the most durable due to the fact that it will see the lowest cylinder pressures. The power adders should signifigantlly increase the pressures in the cylinder, thus wearing on the rings or gaskets, thus making your chances for premature failure more iminent. Not sure if that was the answer you are looking for, but that's the way I would see it durability wise. I guess we could also do a comparison between your car and mine. My 454 CI/265 ET headed motor vs. your 346 No2 motor. First one to blow up looses. Literally.
Old Nov 21, 2005 | 06:54 PM
white2001s10's Avatar
IMO big inch parts are much stronger, but you generally have to spin them faster to reach that kind of power level. The extra mass can become a liability, and lightweight parts can cost a fortune.
The power adders allow you to reach that power level at lower engine speeds, so it then comes down to a matter of heat management which one would survive longer.
Turbo engines are generally trickier to control the tune, and harder to manage the heat, but in practice tend to be fairly reliable. According to the books, they are easier on parts than any other power production method.
Nitrous engines are much easier to tune and manage the heat, but in practice people tend to find the mechanical limits of the engine quicker... maybe due to the massive torque production.
Old Nov 21, 2005 | 06:58 PM
7 Second Club
My thought is if you have one of the new nitrous systems that allows you to bring the nitrous on depending on the RPM it will make it more like a turbo or supercharged application.
Phil
Old Nov 21, 2005 | 08:10 PM
Beast96Z's Avatar
Phil
That could be true, but a forced induction motor will still see much higher cylinder pressures than a N/A motor. It comes down to how well built and well tuned th ediffrent set-ups are as to how long they will last.
Old Nov 21, 2005 | 09:14 PM
v8pwr's Avatar
The turbo engine would be the most durable . The other engines would definitely need rpms to attain those power levels . The big inch n/a engine is exceeding 2hp per cubic inch , considering any ls1 that size has been stroked you'll have some high piston speeds , same for the small nitrous motor but it has spray to account for what you can't make n/a . With race fuel the turbo motor will have a realtively easy time making the numbers and if built properly can lead a fairly long life . All of these engines would require special attention just to be a reality let alone "durable" .
Old Nov 21, 2005 | 10:06 PM
Beast96Z's Avatar
That's a good point. I didn't consider the HP levels into the considering factor of durability. If you had a LSX based motor making 900hp N/A, you would probablly run into some durability issues somewhere. If it were my goal to obtain 900 hp, I would choose a turbo for longevity and driveability among other things.
Old Nov 22, 2005 | 12:26 AM
Ben R's Avatar
Cylinder pressure is torque, not horsepower.
Old Nov 22, 2005 | 09:39 AM
treyZ28's Avatar
MEP = Pressure on piston
VE = Torque
Torque at a given RMP is power.
As you can sea, pressure doesn't mean power. you can have two engines with the same pressure and one can make 5x more power depending on displacment and rpm.
Constant power, displacement and rpm engines will have roughly the same IMEP values (indicated mean effective pressure. BMEP, what it puts out. So I - L (losses like friction or pumping losses or a blower) = B
Old Nov 22, 2005 | 12:22 PM
Ric's Avatar
Ric
Good point, Ben. I've always contended that torque is what tears apart an engine, trans, read end, you name it. Not horsepower. Understood that stupid high rpm will cause an engine to fly apart... that aside, if you run into things like broken rods, failed main bolts/studs, or broken cranks, chances are, the torque output broke it, not the hp.
As far as banging on it all the time, why not a turbocharged big-inch motor? It would be able to make the big power of the NA big motor without having to go stupid crazy on things like wild cam, triple valve springs, and other things that would shorten the life expectancy of the engine. Simply put, given a specific power goal, a big turbo motor could use a milder cam, meaning milder springs, which means less wear on the timing chain, pushrods, valve stems, valve seats, etc. and make the same power as a big-inch NA race engine, and do so more reliably.
Old Nov 22, 2005 | 12:40 PM
treyZ28's Avatar
lets not forget other failure moders introduced with a turbocharger. You have oil and coolant that need to go in and out of the this snail shell shaped thing revving to 100,000+ rpm, more tubing, tighter packaging, things under positive and negative pressure, something that will be much harder to tune and a lot of other varriables.
depending on your goal, boost may not be the answer.
Old Nov 23, 2005 | 12:05 AM
Ben R's Avatar
IMHO, bad tune-ups brake parts. VERY rarely do parts just 'fail'. It's either due to improper machining/assembly or a bad tune-up. RPM will hurt parts faster than you could ever imagine. Turning twice the RPM results in 4 times wear.
Old Nov 23, 2005 | 08:10 AM
Patrick G's Avatar
LS1 Tech Administrator
The high rpm that the NA motor will need to achieve 900 hp is also very hard on the supporting driveline parts...transmissions, driveshafts, rear ends, clutches, converters, etc.
I've seen 200-4R transmissions live behind an 800 hp Grand National (turning a max of 5500 rpm) and die behind a 450 hp LS1 (turning 6800 rpm). RPM is harder on other things besides just the motor. Keep this in mind when you're talking durability.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old Nov 25, 2005 | 09:46 AM
speedz06's Avatar
cylinder preassure is fine,but where at?I think better power comes from how long you maintain cylinder preassure throughout the power stroke--how do you achieve this?I dont know.I have 80000 miles on a 550rwhp car the takes a beating like a *****.If I ever get a 900rwhp setup to beat the **** out of daily we'll see.
Old Nov 25, 2005 | 06:43 PM
treyZ28's Avatar
Very true. Bored? Make a graph.
Piston velocity vs rpm
Piston G's vs Rpm
Investigate fatigue in metals. Then check out the forces on a 327 con-rod at 9,000 rpm.
Pressure on a piston usually isn't too bad so long as its well distributed (ie, not detonation). Hydrolocked rarely crack pistons. Why? Hydrostatic pressure is very equal in its distribution. Check out metal strength and then measure a piston. you'll be suprised how bad *** metals are
go figure, numbers work out and physics wins
