Another "Does anyone still use this old hotrod trick?"
Does anyone use this type of system anymore? Would it help the LSx PVC issues?
In some cases we had to put the crank seals in backwards, or dirt would get sucked in through the seals.
Personally, I don't like re-cycling engine air/oil back tothe TB, etc. and this system does create vacuum and a clean engine. I just haven't tried in on an LSx motor.
I've seen them at Jegs/Summit a year or so ago.
Edit: They still sell them
There is no way that a header evac system will pull that much vacuum. It takes close to 25 inches to do that.
Open headers worked fine and I have had some success with closed exhaust on other setups, but no experience with the LSx.
Then there is a whole other camp, including Mr. Gasket who think otherwise.
So who is your boss that invented this?
I've been looking at the GZ vacuum pump and some others as well. I may invest in a pump and fab the rest myself. Don't want to spend over $300 or $400, that's for sure.
The amount of oil being filtered out is the same, with or without the holes.
The decline in gas mileage also shows that the slight vacuum from the pcv is helpful. But I think the vacuum is so small that it helps mpg and power mostly in lower rpm ranges.
