Advanced Engineering Tech For the more hardcore LS1TECH residents
optimising fueling vs timing
Old Dec 25, 2005 | 10:48 AM
ringram's Avatar
Default optimising fueling vs timing
Ok, after noticing how changing timing changes afr if VE is kept the same.
I asume that max power would be attained by obtaining the maximum ve at any point while meeting the commanded afr. This can be done by varying timing and watching afr changes.
So you would move timing around so afr was at its leanest, (optimal combustion) then add fuel (increase ve table in SD mode) to get back to commanded afr. Seeing you are burning more fuel and combusion is optimised (Stoich, or whatever you command), cylinder pressure is optimised!?
How valid is this, or have I missed something?
If its semi valid perhaps this is a good way to tune timing without dyno?
Comments, corrections and points of note appreciated.
Old Dec 26, 2005 | 01:16 PM
ringram's Avatar
After some more thought, more advance will mean it gets leaner in any case. I guess if its not at misfire/knock point then it might be in the right area.
Old Dec 26, 2005 | 04:03 PM
redmist's Avatar
This makes sense to me but you should read the J-rod post on timing before you start "maximizing" timing.
Old Dec 27, 2005 | 03:58 AM
ringram's Avatar
Yeah, I have done. My comment isn't correct to a point. Timing also depends on the combustion rate and pressure wave. Advanced timing will generally always be leaner than retarded, the key is to place the right point of the combustion pressure curve at the right point (14* atdc or so). So while more fuel is good, too much pressure before tdc is bad.
So I guess this method might be a useful tool, but not a rule.
Old Dec 28, 2005 | 11:47 AM
white2001s10's Avatar
No you were pretty much correct in your assessment.
Real-world doesn't always match up to the ideal world.
In a way the engine makes it easy for you to maximize the timing. When you have gone too far you will notice a power loss.
This is easy to see for WOT tuning with a g-meter or accelerometer.
For part throttle you need to log throttle-angle vs speed.
If you can hold a steady speed on flat ground with less throttle, then you're making more power.
There will be 2 or 3 degrees of advance where power levels off before it drops. If you ride the edge of maximum timing, then other little things like air temp, engine temp, or fuel quality can push you over the edge into power loss or spark knock. That's why most people stay a bit on the conservative side.
You were right in that you want to increase advance to get the most power, but some people look at it or state it another way. They say you want to run as little advance as nessessary for best running.
That just means don't go overboard and then use extra fuel to cover it when it's not making you any more power.
That's why I say to watch your throttle angle.
Old Jan 3, 2006 | 11:59 AM
RedHardSupra's Avatar
Exclamation
This is THE ONLY right description of PE/timing tuning i've seen on this forum so far!
