Advanced Engineering Tech For the more hardcore LS1TECH residents
Intake design
Old Jan 2, 2006 | 09:30 PM
Kano's Avatar
Default Intake design
I would like to see more information on intake design.
runner length vs rpm max flow that sort of thing
and at what point the intake becomes a restriction.
Here is what Im facing
I have a LQ9 with WCCH heads and F-11 114 camshaft
all bolt ons TD exhaust 2.5" no cats
CR is 10:1
BTW this is with the long runner truck intake
heres my graph
You would think this cam would pull higher than it does
I think the reason its not is due to the intake design
Around 5000 my maf readings jump around like crazy from 42 to 48 lbs
I have a friend with the same setup as mine except cam that does exactly the same up top.
he will chime in also
Any info, thoughts, opinions on this would be appreciated
Old Jan 2, 2006 | 09:41 PM
mattrem's Avatar
I have the almost same combonation, except the cam. I had a 216/220 Comp with 1.8 Harland Sharp rockers, on the dyno mine fell off at 5200 rpm. I had some valve float I think from the rockers. I have swapped cams again, 220/224 581/581 with the stock rockers, hope to go to the dyno this week with it.
I made 355ftlbs and 350 hp, it stopped pulling at around 5000 rpm.
We are the only 2 truck guys with heads and cams that are N/A. Could the manifold be holding us back? All the truck guys making big power are FI, I know the FI could be helping the truck manifold, but could it be hurting us?
Old Jan 2, 2006 | 09:51 PM
Beast96Z's Avatar
The trucks are designed to make peak power and TQ early for towing and other things. Changing to a shorter runner will move that power band up and probablly sacrifice some of that mid range TQ. The higher you can rev, the more air that can be moved, equaling more HP. Changing to a LS-6 intake or a FAST will give you a power band that looks more like the cars.
Old Jan 2, 2006 | 10:02 PM
Kano's Avatar
so this a runner length thing?
What exactly happens inside the intake that causes this?
Im not but theoretically,
What would happen if I went with a larger cam?
Lets say 238/240 114 +0
would top end gain
or is the powerband stuck at a certain RPM?
Old Jan 2, 2006 | 10:55 PM
Kano's Avatar
How about plenum volume , runner volume, and runner length
differences between the LS6 truck and trailblazerSS intakes?
Old Jan 2, 2006 | 11:14 PM
Beast96Z's Avatar
If you went with a bigger cam, your power band could gain in the upper rpm's some, but it is still going to be mostly low-end since the intake was designed for truck type duties. If you keep adding camshaft, you'll end up with a cam that makes power outside of your intakes powerband, and then you'll be left with unsettling results. I'm deffinatlly no expert on port volumes vs. legnth and other things, but I do no that longer runners build TQ, wearas shorter runners are better suited for high rpm HP. If you look at some LS6 intake dyno's, you'll see that most of them have a HP that is higher than tq. Wearas yours has a very fat TQ curve, that produces more TQ than HP. You'll have to comprimise somewhere, because you need a fair amount of low-end TQ to keep the heavy truck from being a slug off the line, but you also want to pull up top a bit more.
Old Jan 3, 2006 | 12:01 AM
Sport Side's Avatar
Ignoring the intake design, it comes to this.
1. Truck Intake + 6000RPM shift point
vs.
2. LS6 Intake + 6500RPM shift point
A 'correctly' cammed 6.0L with supporting gears/stall will
net you the lowest ET.
Like Beast stated, the LS6 intake is going to allow more
RPM travel which will give you more HP.
It's going to take experimentation because it is hard to
say right now 'how much' low end will be lost when and if
you add a new intake.
So, lets recap... How much street-ability are you willing
to give up?
Well, this depends on how much you loose on the low side
from the intake swap. It's going to take testing.
Old Jan 3, 2006 | 12:31 AM
Kano's Avatar
I understand all that
Im just trying to get a grasp on why
We got 2 applications here one with a 228/230 114 and the other with a 216/220 11?
My understanding is the f11 would pull higher than the 216/220
but we're within 6rwhp and both fall off around 5000.
So I think its best to call the intake... "done for after 5000"
Thanks for the responses beast
Its good to know someone else agrees with us and
this being an intake thing.
Old Jan 3, 2006 | 12:40 AM
Kano's Avatar
vs.
to give up?
Sending you a PM
oange ss's Avatar
airflow stallin in the runner at high rpm
Old Jan 3, 2006 | 05:47 AM
mattrem's Avatar
My cam was on a 114lsa to clear this up. Now the next question, will the LS2 truck manifold, help or hurt in our situation? It looks also to have long runners like the truck manifold.
Old Jan 3, 2006 | 07:47 AM
oange ss's Avatar
i didnt know there was an LS2 truck manifold
Old Jan 3, 2006 | 07:57 AM
mattrem's Avatar
Yes its used on the TBSS and SSR, it has a 90mm TB. Scoggin Dickey is testing a harness to go from the 6pin to 8 pin TB. Its tall like the truck manifold, I think it has more volume. If it makes 395hp on that LS2 would it support the same on a LQ9?
Old Jan 3, 2006 | 08:05 AM
Sport Side's Avatar
I don't think the LS2-Truck will be the answer. It's making
395HP at the motor. Kano and yourself are more than likely
already past this point.
I think it is the design of the intake leaving us RPM limited.
Swap the intakes, and cam/stall/gear occordingly and you
will go quicker down the 1320.
Old Jan 3, 2006 | 08:21 AM
Sport Side's Avatar
Here are some examples.
Some look better than others but, the 6200-6400RPM peak that the LS6 intake usually shows does not appear in these graphs.
6.0L + 228/230-110ICL + Truck Intake
6.0L + 224/224-108ICL + Truck Intake
5.3L + 220/220-108ICL + Truck Intake
5.7L + 224/224-108ICL + Truck Intake
Old Jan 3, 2006 | 08:23 AM
mattrem's Avatar
So I quess a manifold with a shorter runner? How about if the mainfold had more volume? And use a 90 mm TB for more air?
Old Jan 3, 2006 | 08:35 AM
Sport Side's Avatar
Is anyone positive on the runner lengths of the Truck intake?
I heard it was very similar in length to the LS6 intake so, it
may just simply be the design of the thing that is holding us
back. I truly do not know. All I see is proof that something
is wrong. Best thing to do from here is try the swap and see
what happens.
Old Jan 3, 2006 | 08:37 AM
mattrem's Avatar
I think the runner length is just hear say, Not sure myself. If someone could make a harness to adapt the LS2 TB(6 pin) to the truck (8 pin) I would try this, I mean I will just about try anything, just not changing everything for the LS6 manifold.
Old Jan 3, 2006 | 08:39 AM
Sport Side's Avatar
That could very well be possible. Look at what has been said
over in the truck sections for the past 2 years. Everyone
thought the LS6 intake would be a waste and that they had
very similar operating ranges.
Old Jan 3, 2006 | 08:41 AM
mattrem's Avatar
I quess some flow bench work would help also?
