Benefits of a 32 valve heads
http://www.coatesengine.com/csrv.html
how is that for a head??
I wouldn't use Ford as an example of "how it works". That design makes no sense to me at all.
When you can get better performance out of ideas like VTEC, VVT, ICT, etc, how much should really be put into 3-valve development? The ideal setup to replace the LS2 might be a 32-valve pushrod VVT/ICT setup. It could be done a lot smaller than the hulking Dominator heads, IMHO, and very streetable.
Posted Dec 8th 2005 7:00PM by Eric Bryant
OHC vs OHV
Spurred on by Joel's post on pushrod engines and some of the comments that it generated, I think it's time to take a closer look at the differences between OHC and OHV engines. We all "know" that OHC engines rev higher, produce less torque, increase specific output (power per unit displacement), operate more smoothly, and so on and so forth. Those are stereotypes, but ones that are indeed based on some honest real-world experiences. So were do these characteristics come from?
To figure this out, we need to first understand that engines are air pumps, and the volume of that air is what affects both power and torque characteristics. Peak power is basically determined by the limit of airflow per unit time. Peak torque is determined by airflow per combustion cycle; essentially, how much air is crammed into the cylinder on every intake stroke. This should hint towards the intertwined relationship between horsepower and torque, but we’ll cover that at some other time.
Peak power is relatively easy to achieve, airflow on a naturally-aspirated engine mostly being a function of the cross-section of the intake tract (the exhaust tract is important as well, but less so because there’s more pressure available to expel the exhaust gases). Specifically, the smallest cross-section of the intake port is going to present the largest restriction to flow if an even velocity is achieved throughout the port (and that’s a big “if”)*.
Valve curtain areaUsually, the area of the intake valve(s) is the ultimate determining factor, but this assumes that the intake valve is fully opened. By this, I mean that it’s lifted off the seat by at least 0.25 times the valve’s diameter, which is where the valve “curtain area” (the circumference of the valve times lift) equals the area of the valve itself. This should allow the valve to flow at its maximum - we’ll come back to this in a moment.
To achieve a large valve area, we need to maximize the diameter of the valves. In a two-valve head, this places each valve alongside the edge of the cylinder, a condition called “shrouding”. Due to the proximity of the cylinder wall along a part of LS6 chamber with cylinder outlinethe valve diameter (shown to the right as a red line superimposed on the combustion chamber), a significant portion of that curtain area becomes unusable. This is why it’s often necessary to lift the valve well beyond the 0.25 x diameter figure of merit in order to achieve peak flow. This is also why, all things being equal in terms of displacement, larger bores usually make more peak power - it frees up room for more valve area. Four-valve setups take advantage of more of the cylinder area, but almost as importantly, they suffer less from shrouding since the smaller diameter of the valves doesn’t as closely follow the cylinder wall (the valves can shroud each other, but that’s less of an issue).
All of the above points to an obvious airflow advantage for four-valve heads, given a fixed cylinder bore size. But there’s yet another advantage, this one related to the curtain area. Since multiple valves necessarily result in smaller valve diameters, this means that less valve lift is required to maximize flow. Less lift and smaller (read: lighter) valves makes the job of the valve springs much easier. Indeed the difficulty of closing the valves is often a limiting factor to how high an engine can safely rev, and it’s an extremely difficult problem to work around in a production engine where a valve spring life of a few thousand miles just isn’t acceptable.
This clearly points towards a multi-valve design - and almost by default, overhead cams** - as being superior for peak power. No big surprise, eh? But peak power is rarely what we’re after in a production engine.
More important is maintaining a healthy amount of torque over the usable rev range. No, this isn’t some sort of claim that Torque Is King, since proponents in that camp are usually interested only in peak numbers, and preferably at a low RPM. To obtain this, we need to fill the cylinder as much as possible across the rev range. Simply maximizing the valve area is not the way to accomplish this task, and choking down the intake tract to maintain velocity at low revs isn’t the way to go, either.
Assuming that sufficient bore diameter is available, and that there is enough displacement - such a nasty word! - to keep the maximum operating speed under, say, 6000 RPM (for those engines not employing exotic valvetrain components such as titanium or hollow-stem valves), it is quite possible to achieve great results with a 2V pushrod engine. Spend enough money on the valvetrain, and that arbitrary rev limit goes away, too. Additionally, the low-RPM airflow characteristics of a 2V wedge-type head are usually superior to those of a pent-roof narrow-angle 4V design, with more swirl (airflow rotation parallel to the cylinder axis) and tumble (perpendicular to the cylinder axis). Additionally, the area of the chamber that’s not occupied by valve allows the addition of addition quench area, which adds further turbulence to the mixture during the compression stroke. All of this can add up to excellent low-speed and part-throttle performance, which is why an engine like Chevrolet’s LS7 can offer nearly 75% of its peak torque anywhere between idle and redline, offer up 10% additional usable revs after hitting peak power, and manages to pull down some extremely respectable economy numbers. Hey, there’s a reason that Honda’s VTEC system on its V6 Accords barely cracks open one of the two intake valves below 3000 RPM.
For those that evaluate an engine based on mass, packaging volume, and fuel efficiency, OHV designs are very attractive, for stuffing a pair of cams into the cylinder heads adds volume and mass at just about the worst possible place on a V-configuration engine. Add in some roller followers and tall valve springs, and all of a sudden we’ve got V6s that are larger than V8s, and “small” V8s that are larger than the big-blocks of the 60s. During an SAE presentation that I attended, Chevy’s Dave Hill stated that the Nissan VQ35 DOHC V6 was benchmarked during the development of the C5 Corvette, and was clearly found to provide significantly less power per unit mass and unit volume than the GM’s GenIII V8. Peak-power-per-unit-displacement is strictly an amateurish way to compare two engines.
What about smoothness, NVH, power delivery, the touchy-feely stuff - do OHC engines really offer an advantage? To some extent, yes. The OHV valvetrain tends to create a rather long string of mechanical interfaces, each bringing with it the potential for noise and vibration. And rocker arms can make a heck of a racket as well (as anyone who as installed a set of aftermarket roller rockers knows). But OHC engines necessarily place the cams far away from the crankshaft, which means that the cam drive system often has an opportunity to emit noise. As well,
The there is the LS7 and the Viper/Ram V-10. Dodge does it with displacement. Lots of it. GM does it with lots of little tricks: very light valve train, very sensitive MAF, two-mode exhaust. GM also wins the smallest packaging.
If someone said to pick from this group for the best engine for a 24-hour road race, I'd pick the MB. My guess is it also has the highest ultimate power capacity of this group if built as race engine (with the appropriate bottom end, cams, intake, and exhaust.
Just something to think about.
Ranger engine bays aren't all that big.
As for the SL65, well gearing doesn't even matter. The only way I know when it shifts is when the tach moves. Power is LITERALLY the same from 1500rpm to 6000. At least it feels it. It is just an outrage of thrust at any RPM, any gear.
So in summary, if my eyes were closed, I wouldn't notice the difference between a 8000rpm BMW and a 6000rpm MB assuming their acceleration was the same, the only difference being RPm orientation. I will all but guarantee the MB will have no off the line advantage, due to the BMW's amazing trannsmission work. Ok, that's all, a lotta useless info and statation of the obvious there...
I also had the question of if it were possible for variable valve timing to be implemented in pushrod V8s but had this answered by a magazine article. I know there are many variants of VVT and one type brings forth another question. Ferrari had a version of VVT to where the cam lobes were uneven and achieved more lift by advancing the cam laterally. I was wondering if this could also be possible in a push rod V8?
I thought this would be the most appropriate forum for this since you people would most likely know what youre talking about.
Russ was trying to sell them things when I was a kid (and so was he)
As another has stated YOU DONT WANT to deal with him
If anything goes wrong with his products Its YOUR fault
You can PM me for further info as well as the other guy =)
However, I still would not think twice on running a set. Those heads will simply devastate and embarrass ANY 2 valve head on the market.
Supposedly it was a pain in the *** though, and a lot of stuff needed to be fabbed.
yeah you guys have no idea. we used to carry his products and just recently had a deal get fucked over because he couldn't produce them. if he could fill the orders we got those heads would be BIG but i guess he didnt want the cash....FYI he just produced some marine heads that flowed over 500cfm and had retardedly high low lift numbers as well. but you have a better chance finding hens teeth than picking up a set
I know this by personal experience as well as a bunch of people I know personally that have delt with Russ
you should know I have nothing to gain or loose from any of his sales or no sales I am only looking out for the members interests here
He is also know for his exageration abillitys as well
I personally watched him dyno a VW 1835 he claimed made 250 hp + it was N/A btw
and the next day we heard it seize on the dyno from next door (we had a nice chuckle)
