What kind of testing would you like to see?
Will dyno it next month, checking back pressure with the muffler and power with/without. If I could figure out how, I'd post a pic of our terminator box..
The engine should be on the dyno next month and we'll see how we did, but if you were interested in evaluating something out of the ordinary rather than just 3, 5 or ? of the most popular existing grinds, I would be prepared to come up with optimum cam specs for your appliction and you could get it ground and tested.
I'm very interested in the results though. Do you have any projected power numbers for the motor. I'm looking for something to deal with just about 700 hp. Thanks.
The right side merge/megaphone collector is mostly inside the terminator box. The pipe is the collector & terminator chamber for the left bank, as seen in these pics. The reverse cone megaphone ends inside it and because it is so big (5") and extends upstream past the end of the meg, it does not affect the 'tune' of the exhaust system, which ends at the meg exit. Its volume is 12X one cylinder capacity and the muffler-like box in the above pic is 16X, well over Vizard's suggested minimum. The outlet of the box flows into the Series-mandated 5" Flowmaster.
(Oops!: Fat pix, will have to split them up...)
