What accelerates an engine?
My science teacher always said "Science never sucks.... It blows" He loved that line
Which is why we have a throttle blade (and a rev-limiter when the blade is open), to restrict the amount of air it gets and (feed) control it. I like the analogy of taming a wild animal
I think you understand now!!!! That was pretty quick for a learning curve. Good explanations everybody.
Just 1 thing to add.
Air is not sucked into an engine, it is pushed!!!
An engine is mearly a pressure drop, therefore, the pressure on the front of the throttle blade is greater than that behind it.
The pressure wants to be equal so the high pressure on the front of the throttle body wants to move in and take over the low pressure on the engine side of the throttle body.
I hope this helps evaluate it a little better for you. Or it may confuse the heck out of you, either way, its all about learning.
But, isn't the engine really sucking air in, or at least its a sucking process of the pistons that starts the whole process off, therefore we can say that air is being sucked into the air by way of this process, which is Bernoulis.
I'd like to know how high the psi gets from a BBC with 1,000 hp normally aspirated at WOT, I would think it would surpass the ~14.7 psi that the atmosphere has to offer at sea level to keep pushing air into the engine. Therefore isn't there a point that an N/A engine is purely sucking air in to keep accelerating itself to a point that it maxes out even that, red line?
Tommy
Re: the original question.
Piston movement in the cylinder expands the volume of the cylinder and lowers the pressure. The atmosphere wants to come in via the intake port to equalize the pressure. The throttle is the pressure regulator. The more you open the throttle, the closer the pressure in the cylinder will get to atmospheric pressure. Air at higher pressure has a greater density and contains much more oxygen. As pressure in the cylinder goes up, engine power goes up.
Fueling or the addition of fuel is simply to maintain the right Air/Fuel ratio as the amount of air/oxygen is changing with throttle opening.
This would be the case even if our atmosphere already had the correct ratio of fuel vapor in it. The power would still be throttled or controlled by the amount of pressure allowed into the engine. IMO you should think of it like this instead of the amount of fuel going in making the difference.
A diesel engine is always WOT and power is based strictly on the amount of fuel or the A/F delivered. This is completely different.
And a very good N/A 1,000 HP BBC would still never make much more than a bar absolue manifold pressure (0 gauge) at any RPM.
Now, the PCM on an LSx series engine matches the fuel flow by regulating the injector duty cycle to maintain the desired air to fuel ratio (AFR). The sensed RPM and MAP are fed to the PCM electronically and are referenced to RPM vs. MAP cells in the VE Table. In Speed Density (MAF disabled) mode, this VE table is the only reference other that the Power Enrichment Table. Also, the mass air flow (MAF) value (if used) is blended with the SD calculation to help get the mixture right.
Regardless of the function of the PCM, any engine will accelerate if you introduce more oxygen into the cylinders and accompany that oxygen with more fuel. The throttle opening initiates the acceleration and the fuel sustains the RPM increase.
Note: with a diesel engine, there is no throttle valve and combustion always takes place with excess oxygen. The fuel flow is metered (or throttled if you wish) to control RPM's. If you introduce more fuel and the oxygen is already there for combustion, the engine will accelerate.
Steve
I really like to help people who want to learn to understand things.
All my best,
Steve
the fuel doesn't start burning until it's very compressed near TDC.
It also doesn't rely on a spark to start combustion.
If you had to start combustion via a spark at around 30* BTDC you would get the same problems.
Steve
My auto teacher always favoured us using the terms 'high/ low manifold pressure' as opposed to vacuum.
Vacuum in the truest sense is the absense of matter (air/gas in this case),
and you can never have a perfect vacuum...but rather partial vacuum.
As stated by White2001S10, the gauge reading is a reference to atmospheric
pressure at your current standpoint on earth. If you connect a gauge behind
the throttle blade, you can see the manifold pressure become closer to
atmospheric as the blade opens.
Just remember the gauge reading is not absolute.
As for going lean with a mixture, it creates heat. Depending on the extremes
it will cause the chamber to exceed optimum combustion temperatures causing
knock, or possibly component damage over a period of time.
But here is what I am thinking and someone correct me if I am wrong.
The real reason you can't run a gasoline engine lean is because the fuel burns so fast, that when you start the spark 30 BTDC, the fuel would have expanded to fast and it tries to press the piston down the bore, the wrong way!!!!
So, this would be true all the time. Except, now with electronic timing control, ie, not a distributer, we would be able to reduce the timing at leaner settings and compensate for the quicker burning mixture.
Now, this won't work for emmisions, because it will create more NOx emmissions, I think.
Ok, lets hear what everyone has to say!!!
on the piston is reduced over the duration of the stroke, and/or the peak combustion pressure is not occuring at the best crank angle.
Result is less power.
Not sure about the peak pressure occuring at the "right" time, ca50 around 10 degrees ATDC.
I think I need to see some good data on this subject. I am going to do a little research on it.
