ceramic coating of the combustion chambers
/liteweight contributor
So far everything I've seen is with all 8 coated.
J
I may need to borrow your (KVU's) wide band later this year sometime because I don't have two (yet).
Here is a direct synopsis of the Dow product, it is DC2, Darts high temperature highly reflective heat barrier. Enhances flame propagation, reflects more heat into the combustion chamber and off piston tops, piston rings, and lands. Ideal for high temperature-heat reflective-insulative application. Combustion chambers, valve faces, exhaust ports, intake manifold bottoms, brake calipers-pads-piston, turbo housings, down pipes, etc.
You couldnt possibly think we and all these other engine builders are ignorant enough to have done this without comparing the results with and without??
I mean if they were not smarter than the average Joe, then we could all race and beat guys like Warren Johnson and Greg Anderson, oh and I am not throwing around names, I have personally met, and hung out with these guys, been drinking with Jeggy, Larry Dixon, and Tony Pedregon, both Larry and Tony are married to family friends. SO I have some knowledge, no I am not a scientist, and wont claim to be one, but rather a normal guy who builds engines for myself, and works for Richard Maskin, and have had the fortunate oppurtunity to get to know and learn from all the guys listed above.
Our science lab is a machine shop, with three style of flow benchs, two dynos, multiple styles of race cars, and an endless list of fellow engine builders who help test and exchange information all the time..
Several large LS engine builders send us lots of pistons, turbo housings and header setups to coat with these thermal barrier coatings.
J
Some people are on here to just waste time arguing over things because they have nothing better to do. They want proof, but they don't have the functional knowledge or expertise in the field to understand the variables involved. I agree a scientific test will not *always* provide evidence that something works, and I'm sure that there probably is evidence somewhere that proves that they do. I also agree a home experiment with spray paint quality application and a home oven isn't going to show the same results as the professionals. That being said, for those that are actually interested in seeing some coatings instead of reading a pointless argument, here are a few pics of my coatings from Polydyn in TX for my 383 build. Heat rejection coatings on piston tops and combustion chambers, anti-friction/heat rejection on intake runners, and piston skirts.
I have some polydyn coated pistons in my garage right now, and one will get tested soon. It was professionally applied, so if the test fails, you'll have to reach for another excuse as to why yours is going to work in your engine.
Another thing. Knowing a bunch of great guys that often get together for B.S. sessions and have always had fast cars is in no way as credible as test data, for which sadly is not to be found in these posts.
I'm sure if great people were doing great testing, then it shouldn't be too hard to dust off the papers and show the exact conditions of the testing along with the resulting data.
the volume of the ceramic coating and the affect on compression?
Closing up the quench height by applying the coating is going to alter the expected readings.
If you are looking to control the results, it might be wise to deck the piston
to keep the compression equal.
anyway, i'm not knocking on you. matter of fact i applaud your stubbornness, but i think some of it was unneccessary though i'm not going to elaborate. looks like you'll just have to try and redo the same experiments that other companies have done because you need the complete proof. good luck.
These guys on ls1tech are behind the times.
(OK; these are just for cars, but still interesting . And you never know...)
Federal-Mogul Corporation has introduced a line of high-strength Sealed Power and Speed-Pro pistons featuring a complex ceramic head coating technology that withstands combustion temperatures of up to 2,000 degrees F and delivers three times the surface hardness of hard-anodized coatings.
New Sealed Power and Speed-Pro THERMOSHIELD-coated pistons are offered in hypereutectic and POWERFORGED designs for a variety of popular standard replacement and performance applications. The pistons' advanced THERMOSHIELD crown coating is produced through an immersion process using electrical impulses that convert the piston surface into an extremely strong, smooth and heat resistant complex ceramic. Because the THERMOSHIELD barrier is atomically bonded to the piston substrate, the material is highly resistant to flaking and cracking and provides exceptional protection of even sharp corners. THERMOSHIELD also is well suited as a top ring groove coating for the prevention of micro-welding; and now selected Sealed Power and Speed-Pro pistons include this added feature.
Conventional piston crown coating technologies such as hard anodizing, sprayed ceramics and electroplating produce significantly lower surface hardness than the THERMOSHIELD process which is far less resistant to corrosion, cracking, scratching and wear. The use of piston crown barrier coatings is becoming increasingly popular in many demanding performance and other high-temperature applications and the superior hardness of the THERMOSHIELD coating is the leading technology, providing added protection against spontaneous detonation.
"THERMOSHIELD is by far the best choice for engine builders who want to maximize performance without overheating the pistons," said Raymond King, marketing director, engine components, Federal-Mogul. "This exciting new technology makes hard-anodizing and other conventional crown coating technologies virtually obsolete in terms of strength, durability, finish quality and consistency."
As for friction coatings, here is a simpe anology, if it is slicker and therefore has less friction against the thrust wall, doesnt it jsut simply make sense that it works, doesnt require a rocket science to figure out. Just like it doesnt to know that an eel is slippery. Sometimes I think people on here or on forums in general just like to complain and stir up more crap. Sure if the piston is slicker and has less friction against the thrust wall, well then obviously there will be less "scuffing".
As for testing, I agree why does any company have to detail or present anything to the common public about their testing procedure. It wouldnt matter anyways, I could tell you whatever you want to hear, and you guys would argue it anyways. Its funny that a company who is established in this industry and proves things on a daily basis has to prove anything to somebody, prove to me we are wrong, prove to me it doesnt work. I dont care anymore, I am done with this $hit, and done with trying to provide FREE information and expertise. Go waste someone elses time!!!!!!
Thanks to the LS1tech board!!!
i'm glad your here! i would like your professional opinion if you have experience with hpcoatings. what do you think of their work? i already had my combustion chamber and piston coated on my motorcycle and so far i have no problems after 2000 hard miles with a working a/f tune(it's carburetorated so it could be way off). i'm just curious becuase i seem to be one of those people always looking for that little edge in performance(or longevity aka anit-wear).
