water assisted engine!
Hope I have helped clear up some issues.
Water injection as part of combustion is a very different thing, I believe that is what Ricardo had studied.
By completing a full exhaust stroke and retaining only a small quantity of the combustion gases/heat, you severely limit how much water-steam you can successfully inject. This relationship is clear.
It may not be more 'complicated' than that, but it certainly involves more detail to be of true value.
Ricardo studied and devised systems for many forms of water injection, as well as methanol injection, nitrous oxide systems, cold air injection, exhaust recirculation systems, and many combustion chamber profiles, fuel systems, and other engine parts to include sealing rings, piston profiles, and other items. Ricardo was a genius who's study was not confined to water injection into the induction system.
Water as part of combustion is not so different to water-steam reaction as you might think. While water-steam injection doesn't make use of the water as a combustion catalyst/excitor, it does still utilize water's heat transport abilities in the same manner, as well as it's radiation absorption spectrum, albeit for a different purpose than combustor water injection.
On a different note, I realize my posts are long, but there is no need for this discussion to die out now. There are other things that can still be debated and discussed relating to the Crower Engine. I've noticed the post frequency has all but disappeared since I wrote my mini-essays. To all the previous partakers, "Come back!" Lol.
i think this system does have uses, if onlt in comercal plant machenary were water is avaialbe on top (haha)! you could use the hot enhaust to distil the "tap water" and then inject it onto the engine! as it apears the engines run cooler thank to the heat being transfered/used to convert the water to steam you coulfd the run the engine leaner (ie more efficently), run higher comp ratio or more boost and make more spesific power! also you would have to advantage of the "steam stroke".
do you guys think that for the same displacment power would be increased???
Chris.
I would think for an industrial setting, a filter would be more appropriate due to the ease/simpleness/compactness of the system, as well as the reduced concern for desposits and peak power output. BSFC is far more important in a stationary generator that spends over 95% of it's time in a very narrow operational speed range.
and if you could get rid of the water jacks think how much stronger the block could be!!
i agree about the industrial setting! filtters would be much easier!
Chris.
OverTq isn't a big deal on helicopter engines, it's big deal on the tranny's, though
Back to the discussion
The Daimler-Benz DB605 series of engines, as well as the Jumo 213, used something almost identical, they mixed alcohol into it though (MW-50). Of course, the Germans didn't have the level of fuel quality and quantity we did.
So water injection was definitely a plus. Then again, those were very high compression (high altitude) engines, with forced induction on top. I guess even 150 octane only goes so far. lol
While it has been shown that water likes to be atomized at over 100psi - there are no water injection kits out there right now that can supply 30% by volume - water as fuel - to a decent horsepower engine. So what we get is simply a cooling spray... it works - but it does not go far enough.
I firmly believe that whatever results were achieved on race gas - you could go further by increasing boost and/or compression and adding in water to around 30% voume between the torque peak and hp peak. Corrosion is the least of anyones problems - good leakdown build quality, lube and coatings etc - it should not be an issue. Oil system may need a water removal system like diesels is all for very high water use.
BTW - under the right conditions - water DOES crack in the chamber. We are hoping to map that soon - as funds allow... we're hardly going to get government let alone oil industry funding for that bit of reasearch.... lol
To make it simpler for me to understand what you are saying - is the reason you suggest direct water injection rather than a much simpler direct port injection because when you want to inject the water the intake valve will be closed?
Otherwise - would not a simply direct port injection setup get close to the efficiency gains of direct injection? I have often wondered about using direct port nitrous plumbing and injecting water instead - running multiple pumps to get the required volume at 140psi.
On another note: I think a water injector into a turbo could work provided it was close enough so it did not turn into steam before the turbine... you'd want that expansion going on in the turbine I'd have thought. I'd aim it right up into the exhaust turbo inlet from a non flow restricting boss in pipe to the turbo. Thoughts?
if you want to see water injection taken to the exstreames then you should look at WRC cars! i know the Subby run indavidual water injectors per cyclinder and they actually map the water injections per cyclder to get the aboslute most out the engine under full boost (over 40psi in the mid range). and they are using race fuel of some discription to!
as for this water engine in question you have to directly inject the water! you need to get the water into the chamber AFTER the BANG stroke! then when you inject it the water turns to steam and prvides another power stroke! but the main advantage is the cooling effect it has on the cylinder! an engine like this would let you run massive boost because it runs soo cool!
thanks Chris.
thanks Chris.
Water works great! I was just saying I felt we could take it much further.
Re steam in the exhaust headers/manifold - would this not also cause reversion during overlap? The old anti-revesion header cones might be a good idea.
I too saw the Crower design as lacking in the way it was described (which is meant in absolutely no disrepect to Crower as an engineer). It seems a more efficient method to the BMW procedure linked earlier in this thread would be ideal. As an incomplete sketch, I envisioned a system where the heat energy fully exits an exhaust port (maximizing the power stroke), and is then transferred into the water fluid external of the chamber - creating steam. Yadda Yadda, it's late, and i don't want to think anymore.
