Advanced Engineering Tech For the more hardcore LS1TECH residents
Intercooling taken to the next level
Old Mar 24, 2006 | 02:59 PM
HPP's Avatar
HPP
Originally Posted by MadBill
The AC intercoolers I have seen (e.g. Ford's prototype) use it to chill a mass of water, then use the water in the cooling core. This way, the system can be charged with surplus coolth (an HVAC Engineer's technical term for the opposite of warmth ) during normal operation, then used to extract far more heat (although only for a short time) than if using only the available AC output.
Is that a system to spray water onto the intercooler (like in the STis), or is it a re-circulating system? Is there any place online with more info on it?
Old Mar 24, 2006 | 03:14 PM
LS_RX-7's Avatar
I believe the Ford Lightning uses that system, if that helps any. I do know that it is a closed loop system that is recirculated and recharged.
Old Mar 24, 2006 | 04:09 PM
chuntington101's Avatar
doesn't it take 5 min plus to cool the water in the lightning???
Chris.
Old Mar 24, 2006 | 04:51 PM
HPP's Avatar
HPP
Interesting. Seems mostly useful for drag racing or emergency highway speed. Or would it actually be useful on a road course? (regarding how quickly it cools the water, how long it takes the water to circulate/heat up, and how much heat it manages to strip out along the way)
I haven't had time to google it yet, I admit. I do plan to though, as soon as I get some free time.
Old Apr 4, 2006 | 12:06 PM
Cheatin' Chad's Avatar
Originally Posted by chuntington101
this is it guys! i want to know how the hell the WRC teams are doing it! lol
if you wanted really cool intakes then you could run this system i have been thinking of!
run a air to air intercooler to get rid of most of the heat! then run it into a water to air cooler fed with iced water like you would in a drag setup! this way you would easly get below ambient temps!
but then you would get heat soak! so you could run the ac system (or a seperate one run of a standalone battery) to cool the water down again! this would work for a few min i would think but then you would have to cool it back down again! but wold give you well below abiemt temps!
Chris.
In a drag only application I think you'd be far better off using an AtoW intercooler and filling it with alcohol and dry ice (approx)-90*f. If designed and VENTED properly this would by and far give you the best cooling at a reasonable cost. I considered using liquid nitrogen as well but it would be cost prohibitive for most people.
I'd recommend a double wall stainless enclosure (use an expanding foam in between the layers or set it up to have a slight vacuum between the layers for the best insulating properties) and a vent ran out the highest point of the vehicle.
Old Apr 5, 2006 | 03:53 AM
LS_RX-7's Avatar
This is done frequently in the forced induction rotary world. The Aussies have had it down pat for years. (referring to the dry ice). The combination of dry ice and acetone gives the coldest temperature easily achieved, some -170C or thereabouts.
Old Apr 5, 2006 | 06:46 AM
-170 degreesC!!!!!!! dam thats cold! lol
shmae it cant last for very long!
Chris.
Old Apr 8, 2006 | 04:06 PM
Dry Ice (Frozen Carbon Dioxide) has a surface temp of about -109*f/78*c
How does combining it with Acetone drop it another 90*c?
Liquid Nitrogen boils at -320*f/196*c
If gettin -170*c is as simple as adding Acetone to dry ice I wouldn't have paid all that money when I was doing Cryogenic processing.
The Acetone as far as I know (I could be wrong here I guess) would be nothing more than a medium to transfer the temperature of the Dry Ice. I recommended alcohol because it evaporates and is available almost anywhere.
Old Apr 9, 2006 | 05:00 AM
just something about these supper low inlet temps! does anyone suffer with fuel freezing and what about the water in the air????
also how long would a "normal" dry ice sysrem last running say a 1000bhp engine????
Chris.
Old Apr 9, 2006 | 06:28 AM
Chris.
You're more liable to get icing while using alcohol as a fuel than you would be supercooling via a charge cooler.
The amount of time it woudl last would be heavily dependent on the size of the container and the outlet temps of the supercharging device.
With a turbo or (poorly named) centrifugal and a fairly standard sized AtoW charge cooler you should be able to get a couple of runs off. I can't say for certain without testing.
Old Apr 9, 2006 | 12:22 PM
LS_RX-7's Avatar
Same principle as adding salt to ice to create sub-0*C from 0*C ice. I can't recall if it is exactly -170*C or not, but I know it is something semi-close to that figure, at the least. I have reference materials, and will most gladly look it up for you when I get back home, and have access to them. Unfortunately, if you wait on me, you will be waiting till early June for proof. My apologies.
Old Apr 9, 2006 | 01:04 PM
  #32
bryson's Avatar
Has anyone heard anything more on this? It seems like an interesting concept. I wonder how accelerating two compressors would affect turbo lag and throttle response. If weight wasn't an issue, this would probably be incredible on a twin-charged car similar to VAG's new 1.4L. Would the second half of the second charger need to be shaped like a turbine housing and wheel, only with lighter/thinner fins? I would love to see this implemented, or maybe even try it myself someday. Does anyone have any other ideas of taking air to below ambient temps using pressure changes? That way, it wouldn't be a one time deal. I'm thinking more for running a street car on a road course, where you have to have a system that will work well for 10 mintues or so of continuous use.
Old Apr 10, 2006 | 09:19 AM
  #33
Salt + Ice generally will result in an exothermic reaction generating heat. That's why I use salt on the ice in my driveway in the crappy parts of the year
I'll do some looking of my own as well but if you do remember to gather up your info I would love to see it.While I do know a fair bit I claim to be no expert and love to learn about this stuff.
Thanks!
Old Apr 10, 2006 | 10:08 AM
  #34
LS_RX-7's Avatar
No problem. As I said before, I apologize for the long delay. My books are at home, and I won't have access to them for some time (several weeks, not hours.) But rest assured, as soon as I do get to them, I know where to look, and will post or PM the reference.
Old Apr 10, 2006 | 12:50 PM
  #35
thanks LS_RX-7, do you have any links to guys running this set up?? or to more info on the subject?????
bryson i have still not heard any more on the over presurising thing! really want to know more about it though!
one idea for a road course would be to run a large intercooler to get the temps down and then a large tank of iced water and a charge cooler to further reduce temps. should reduce temps below ambient and wouldn't be too difficult or costly. also thanks to the intercooler the iced water would last longer than running just the chargecooler on its own.
has anyone got anymore info on the cryocooling thing???
thanks Chris.
