Advanced Engineering Tech For the more hardcore LS1TECH residents
F1 style transmission?
Old Apr 10, 2006 | 02:36 PM
CTSmechanic's Avatar
Originally Posted by kozak
sequential is deff your best bet. you just need to hook up either an air cylinder and run a mini compressor and tank or find a solenoid operated linear actuator, these things are super fast but hard to find in the correct force requirements. air shifting and clutchless shifters are used alot on our FSAE cars.
That sounds like a pain in the butt..... you'll spend more time rigging up something thats pretty unproven a sequential system will work well if you have a motorcycle trans but to adapt it into a full size car would require alot of time and money which could be better spent elsewhere..Not to mention the T56 is pretty much the equivlent of 7.5 10 bolt in the racing transmission world...its safe to say a quality capable sequential trans is going to cost you around 20K.We just bought a sequential X Trac for an off road buggy and its was more than the cost of my car when it was new...
Old Apr 10, 2006 | 03:06 PM
Skele4door's Avatar
Originally Posted by blown2kss
a t-56 rebuild with g force gears and a trans brace has held 1300rwhp
and as for the actuator astin martin is running a t-56 with paddle shifter in the v12 vanquish. From what I heard ford worked on this setup.
and a ford mustang race car has the same paddle shifter setup making 800 hp.
That's correct. An old buddy of mine is an engineer over at Ford and he was loaned out to Aston to work on the shift calibration for the Vanquish. Apparently the results were less than stellar.
Old Apr 10, 2006 | 09:14 PM
H8 LUZN's Avatar
We made our FSAE car a "paddle shifter" every year. Granted its a bike motor that is already sequential.. but still, not having to take your hands off the wheel helps tons when every 0.1 counts
Old Apr 10, 2006 | 10:58 PM
THE_SUPRA's Avatar
http://www.popularhotrodding.com/tec...wst/index.html
this was a cool article in PHR a while back. im pretty sure the guy used a 4l60/80 i bet that thing would be a blast to drive. good luck wioth the project.
Old Apr 10, 2006 | 11:39 PM
johnpate01's Avatar
http://www.hewland-engineering.co.uk/
They say that they can make anything to customer requirements, seem to have a great reputation. (their straight-cut gears are noisy when compared helical-cut gears, but WILL NOT break)
Old Apr 11, 2006 | 06:45 AM
chuntington101's Avatar
now that sounds like a challange! lol
Chris.
PS, the early sequential shifter (inc the Alfa selaspeed!) where cr*p! notcy and didn't respond when you wanted them to. but the new stuff id gettting much better! i guess like everything it takes a little time to get things sorted! and when you are combininding a complex gearbox with complexe electronics it just makes things worse! but it will be there oneday!
the next thing will be the vw/a DCG! that thing is amazing!
Old Apr 11, 2006 | 09:12 AM
Theres no such thing in racing that will not break, MidValley Engineering transmissions run Hewland gears and Im positive they have had failures caused by driver or componets.I have been building transmissions for racing applications for awhile and I can tell you you see some pretty crazy stuff
Old Apr 12, 2006 | 06:14 PM
johnpate01's Avatar
True, I was simply saying that they are very good, strong, high quality for what they are. What about Rockland Standard's Tranzilla? Supposedly handles up to 1200hp/1000lb-ft torque.
http://news.thomasnet.com/fullstory/473624/rss
http://www.rsgear.com
Old Apr 13, 2006 | 01:43 AM
Tavarez's Avatar
Hopefully we can get more info regarding this all, this is really informative
Old Apr 14, 2006 | 11:00 AM
Loadre's Avatar
For the guy that ask, the majority of the Supras that start making lots of power swap to Turbo 400s.
Old Aug 23, 2006 | 01:01 PM
22GoinOn2's Avatar
Originally Posted by Zeus
what about the transmissions they use in supras? It seems like 1200 FWHP is basically a joke to them and I'm almost positive there's at least one in the 8's on a stock 6-speed. Would this be worth looking into or would the low end torque of the TT SBC tear it apart?
You're kiding, right? Supras are RWD. Most of them fall into the 400-600rwhp catagory with the rest generally coming in at 600-800rwhp. 800+rwhp Supras are few and far between. They generally swap out to TH400s and other similar boxes. Although there are some using the 6 speeds, but I don't know what mods they have. You could ask Ryan Woon of WOTM.com or ask TitanMotorsports.com. Those are two of the fastest drag/street Supras right now.
Old Aug 23, 2006 | 01:55 PM
  #32
joecar's Avatar
Originally Posted by AKAFRED
just use a lenco with 5 air cylenders?
I think this idea is the simplest to implement.
Old Aug 24, 2006 | 10:55 AM
  #33
ProdriveMS's Avatar
How will this car be used? Straight cut spur gears, especially, the thick, low tooth count ones like hewland makes are insanely noisy. Sounds like you're inside a tank when you're driving. You wont be able to talk to a passenger without headsets. A dog box needs to be torn down and the dogs checked for wear periodically. A dog box will allow clutchless shifting(you must lift or use an ignition kill/retard on upshifts, blip throttle on downshifts) but it wears out the dogs fairly rapidly. The majority of rally and race car drivers clutch when they shift. When you're sitting at a light, and you put it in 1st gear, there's a metallic crunch and the car shudders from gears impacting. Every shift, even when using a clutch, brings another crunch. A dog box with straight gears is really a race only item.
Al
Old Aug 24, 2006 | 11:33 AM
  #34
J-Rod's Avatar
6600 rpm clutch dump of death Administrator
If they ever finish it....
http://www.zeroshift.com/index.htm
Old Aug 24, 2006 | 05:32 PM
  #35
A air shifted planetary transmission wouldnt work..... sure up shifting like a 1/4 mile pass but constant up shifting and down shifting with auctuators would be a major pain in the ***.... plus you wont find many more trannys that suck more hp
Old Aug 24, 2006 | 05:45 PM
  #36
under_construction's Avatar
Something like what is used in the C6R Le Mans cars would be the simplest - looks like a hewland sequential trans, conventional clutch, fuel/spark cutout tied to pressure sensors on the shift lever. You still pull and push on the lever to shift, but get full throttle upshifts, with the engine being cut as you start to put pressure on the shift lever.
Now all you need is to program the throttle blip on the down shift
Old Aug 25, 2006 | 06:42 AM
  #37
....then you and a electromagnitic acuator to the leaver and paddles behind the wheel and you have F1 stlye transmition! wel ok its more like WRC transmition but its still pretty good!
The WRC guys gearboxes will change faster than they can pull the padles on the stearing wheel! they can go form first to swith 9eaither way) in less than a second!!!
now that could come in habdy on the 1/4 mile!
and you dont need throttle blips on the downshifts! well if you can left foot break anyway!!
Chris.
