Advanced Engineering Tech For the more hardcore LS1TECH residents
Header Primary Size Mathcing w/ Cam and Heads
Old Apr 7, 2006 | 03:54 PM
Ferocity02's Avatar
Default Header Primary Size Mathcing w/ Cam and Heads
I have always thought that with the more displacement you have, the larger headers you should get. For my 427, I was planning on getting 1-7/8" stepped to 2" with a 3.5" collector. However, there is a question of the exhaust velocity relative to the primary diameter. Obviously the larger diameter primary will have less exhuat velocity than a smaller header primary. My question is, how do you know when more velocity is better than more volume? I assume this may have something to do with the cam duration/lift/ramp rate as well as head exhaust port flow/velocity/volume. Thanks!
Old Apr 7, 2006 | 04:55 PM
Beast96Z's Avatar
Old Apr 7, 2006 | 05:43 PM
Old SStroker's Avatar
Primary pipe diameter should relate more to power output than engine size. If you are well north of 600 fwhp on your 427, 1-7/8 > 2 is probably close. If you are more like 500 fwhp, it's probably too big.
Another thing primary pipe diameter influences is torque peak rpm.
Have you heard of software called "PIPEMAX" ? It will help you a lot.
Old Apr 7, 2006 | 08:41 PM
racer7088's Avatar
Thumbs up
Yes I agree with the Old one here as the power you are making will also give you an idea of the flow rate through that header and for the most part the more power you make the larger the headers will need to be.
Old Apr 9, 2006 | 06:54 AM
66deuce's Avatar
does anyone make a 1-5/8" header for an LS1?considering the HP of a stock motor or even a mild H/C motor,it would seem that the 1-3/4" would be a little big.
Old Apr 9, 2006 | 12:06 PM
racer7088's Avatar
Thumbs up
Even the 1 7/8 Kooks seem to pick up on the 346 inchers whereas the small header cars always seem to be weaker and slower. Maybe the smaller headers are also not as nice in design and construction but invariably they seem to be weaker most of the time?
Old Apr 10, 2006 | 11:01 AM
J-Rod's Avatar
6600 rpm clutch dump of death Administrator
Exhaust Valve Opens - EVO
Header pipe length (in inches) = ((850*(360-EVO))/RPM – 3
Header diameter (in inches) = ((cylinder. disp. * 16.38 / ((hdr len + 3) * 25))) * 2.1
These formulas are from A. Graham Bell’s Performance Tuning in Theory and Practice. For a street engine, the RPM used should be the peak torque RPM. For a race engine, the peak hp RPM should be used. For me, I've found that using the peak torque makes the headers way too long. So, I tend to stick with the peak HP number.
Old Apr 10, 2006 | 12:39 PM
Rick@Synergy's Avatar
I always asked the same thing. The one header I did try was headmens, its a 1 1/2 stepped to 1 5/8 header. Worked good.
Rick
Old Apr 10, 2006 | 08:27 PM
Ferocity02's Avatar
Rick
The only 1-5/8" header that I know of are only shorties.
Old Jun 4, 2006 | 05:38 PM
ToplessTexan's Avatar
The TTS long tube for the C5 is 1-5/8".
Old Jun 4, 2006 | 09:04 PM
52172's Avatar
I would go with a set of LG 1 3/4 new f bod headers. They made 630 whp with their 1 3/4 header on an ls7 427. The torque curve was great and they stated that they would lose low end torque with a larger header and also only pick up maybe 5-10 whp.
Old Jun 5, 2006 | 11:13 PM
UMD_Jesse's Avatar
From: Fairfax County, VA (You know you're here when you see the bad roads)
LG makes a f-body header???? the only ones for f-body's I see on their website are hookers
