turbo idea
The small one canīt exhale as much as the big one so there must be more backpressure where the small one is
yeah and the exhaust pipes would be connected so that extra back pressure would shoot over to the lower resistance outlet (bigger turbo)
thanks Chris
I just thought of a potential problem with this. Since both sides are connected, at lower exhaust pressures there is nothing that would force the air to the little one to spool it up...the exhaust would want to take the path of least resistance and that would probably be through the larger turbine.
"Some car makers combat lag by using two small turbos (like Toyota, Subaru, Maserati, Mazda, and Audi). A typical arrangement for this is to have one turbo active across the entire rev range of the engine and one coming on-line at higher RPM. Early designs would have one turbocharger active up to a certain RPM, after which both turbochargers are active. Below this RPM, both exhaust and air inlet of the secondary turbo are closed . Being individually smaller they do not suffer from excessive lag and having the second turbo operating at a higher RPM range allows it to get to full rotational speed before it is required. Such combinations are referred to as "sequential turbos". Sequential turbochargers are usually much more complicated than single or twin-turbocharger systems because they require what amounts to three sets of pipes-intake and wastegate pipes for the two turbochargers as well as valves to control the direction of the exhaust gases. An example of this is the current BMW E60 5-Series 535d. Many new diesel engines use this technology to not only eliminate lag but also to reduce fuel consumption and produce cleaner emissions. An example of this would be the Ford Power Stroke engine."
Heres the pic at the bottom of the page:http://www.atsdiesel.com/atswebsite/...dge/DTurbo.gif
be ncie to see them in practice on a pertrol engine! any idea what sizes these come in???
thans Chris.
What do you think of this?
750hp STARTER.
The gas turbine makes so much electricity, they actually sell it to the power plant which is about 1 mile away.
To me, this system is perfect for a car like a Supra, small displacement, stick-shift, and street-oriented. As far as camaroextra's question, turbo-lag shouldn't be much of an issue with our big V8s to begin with (unless you're talking about a huge hairdryer!), it's the tiny 4bangers that take 30 min to spool up
If you're looking for a drag only car, your best bet is get a huge single and a high-stalled slushbox so you can build boost on the line (this is what turbo Buick guys do almost exclusively) and if you really feel it necesary, give it a shot of nitros to spool up. But if you're talking about a street car, a well set up single or twin setup is probly going to suit you just fine in addition to being simpler. Just my .02
there are a few corvettes running MASSIVE (like 101mm!!) rear mounts. so could you run a front mont that conects into a rear mount????
this would give you compound boost like the big dieseld guys run. so you could run a little say t76 upfront and then hang a big 100mm turbo off the back! the smaller turbo would take care of things at low rpm and the big mother ****** would set the top end alight!
you would have to have the engine of course!
so what you guys think? could/would it work? there are NO vavles to complicate things (apart from the wastegate that would dump to atmospher located before the first turbo).
thanks Chris.
One reason for the switch was due to the complexity with all the intake pipes. Another reason was that the stock twins were poor units that did have common failures. People also reported that the twins were way more fun, and lag was an issue on the big single.
Then again, they are only 1.3liters, and you guys should have no problem's spinning some BIG twins.
Here is a crude "how it would work" in my mind:
1) Exhaust -> Small Turbo Inlet
2) Small Turbo Boost -> Large Turbo Inlet
3a) Small Turbo Exhaust -> Bypass to Exhaust Exit
3b) Small Turbo Exhaust -> After x,xxx RPM Bypass Directly to Large Turbo Inlet
4) Large Turbo Boost -> Intake Manifold
5) Large Turbo Exhaust -> Exhaust Exit
#3 could be 1 in 2 out bypass valve, and the RPM could be adjusted to get the best powerband for the application of the car. You could also have multiple profiles.
This could allow larger turbos to produce boost from very low RPMs, relative to how they would work if they were spooled directly by exhaust. Lag would be reduced, but not eliminated.
That's pretty much it.
Might look like this
This example is more of what I might try and do if I have the room in my engine bay.
In this example there are 3 boost actuated cut outs. I would open one to the large turbo say 5psi, second one to the large turbo at say 10 psi and close off the small turbo once the large turbo was spooled (based on a PSI setting). Since the exhaust is a 3" X-pipe, I would use a flow master Y-collector to go from dual 3" to single 4" or even 5" in to the big turbo. Just another thought.
