Advanced Engineering Tech For the more hardcore LS1TECH residents
turbo idea
Old Apr 8, 2006 | 11:30 PM
camaroextra's Avatar
Default turbo idea
This idea may be a little crazy, but i think it leads to an interesting discussion.
Say you have a nice shortblock built for boost, and you wanna go with some twin turbos. and just for example your engine lags a little but has a great top end with two 77mm's, and two 72mm turbos boost right away but dont provide much top end. . .
could you connect the airways before the turbos (to equalize pressure) and run a 77 and a 72? one turbo to get the boost started down low, and one to carry the car through the top end. get that nice full power band.
discuss. .
EDIT: Here is a crude MS paint rendition (i have a laptop, so i drew this with a laptop cursor pad!) i don tknow why its so small, i drew it much larger!
Old Apr 8, 2006 | 11:33 PM
BLk01SS's Avatar
Yes, I believe that you can. I think they do that with diesels a good bit.
Old Apr 8, 2006 | 11:35 PM
yeah i knew they did that with some hardcore sequential turbo setups, but im not too knoweldgeable about diesels
Old Apr 9, 2006 | 08:35 AM
H8 LUZN's Avatar
http://www.atsdiesel.com/ATSWebsite/HIWCompounds.asp
http://www.internetage.com/cartercopters/writeups5.htm
a google search produces all kinds of information. BTW, your looking for Compound Turbocharging.
Old Apr 10, 2006 | 01:02 PM
chuntington101's Avatar
that looks like a great idea! how much preusre do you have to be running for this to become effective???
why isn't this used more on petrol engines???
Chris.
Old Apr 10, 2006 | 01:26 PM
very interesting, i want to see how this can be applied to gasoline engines. thanks guys
Old Apr 10, 2006 | 02:53 PM
b00sted's Avatar
This sounds like twincharging...Using a turbo and a roots blower. Roots get the bottom-end torque, and looses all it's efficiency just as the turbo spools up.
Sounds like it could work, but may be a pain in the *** to tune.
Old Apr 10, 2006 | 03:06 PM
1LoudTA's Avatar
if anything wouldn't it be easier to tune considering there is a more equal amount of boost along the rpm range?
Old Apr 10, 2006 | 09:02 PM
H8 LUZN's Avatar
oh.. trust me.. it is
Old Apr 11, 2006 | 06:48 AM
come on H8 LUZN spill the beans! hehe
also wouldn't the smaller turbo be a BIG restrictioninthe exhaust trac??? or can you forget about the 2:1 presure thing when using two turbos???
still be nice to see!
Chris.
Old Apr 11, 2006 | 07:33 AM
jyeager's Avatar
Chris.
Since you'd be joining the 2 sides of the exhaust and then splitting them again before the turbos, when the smaller one begins to be a restriction it would just push more exhaust to the larger turbo.
I don't see why this would offer any tuning issues. Both sides would feed in to the intake and become equalized. The only concern that comes to mind is that if the small turbo is too small, then the big turbo might want to push back against the small one's impeller creating reversion.
Old Apr 11, 2006 | 11:15 PM
Wesmanw02's Avatar
I believe that is the setup that many older twin-turbo imports like the Supra TT and 3000GT VR4 used. The idea is a good one, and works well stock, but once you start modding I've heard that tuning them can be a headache.
Hence the reason many Supra TT guys switch to a single turbo once they start making significantly more power over stock
Old Apr 12, 2006 | 06:46 AM
form the stuff i have seen on deisel engines they run the exhaust "outlet" of the small turbo into the exhaust "inlet) of the big turbo! so you have a little turbo in the way of a big one! dont you????
as for the little turbo, well it will just be preusring preusrriesd air wont it????
there must be a reason why this stuff insent used more! i just dont know whatit is! lol
i thought the main reason for the supra guys going for a big single (or big twins) was flow???
Chris.
Old Apr 12, 2006 | 06:54 AM
jyeager's Avatar
Chris.
One of us misunderstood the original post then. I thought he was describing a situation where the exhaust is joined, then split before entering the 2 different turbos. What you just described is simply sequential turbocharging.
Old Apr 12, 2006 | 11:34 AM
yeah hes describing sequential turbocharging, which i was aware of. i was describing them on the same air way but next to each other.
example relating it to an electrical circuit
if sequential turbocharging is a sequential circuit (with the turbos being the resistors). . .then what im describing would be a parallel circuit. does that clarify this at all?
Old Apr 12, 2006 | 12:10 PM
jyeager's Avatar
Right. My <i>guess</i> then is that this configuration would not result in any tunability issues.
I see no reason why this might not work pretty well. Although it does seem like it might be hard to package and plumb.
Old Apr 12, 2006 | 12:14 PM
it would be an involved process to plumb, but iv seen an 8 turbo small block before, which proves that almost anything can be plumbed
Old Apr 12, 2006 | 07:13 PM
Ari G's Avatar
You stole my idea
With the turbines only connected on the intake and not connected at the exhaust side,there would be some variation in power between the bank where the small turbine and the big one
I have been thining about the Cam and valves setup,woulden´t i need a diffrent valvespring seat pressure on the bank where the small turbine would be because of diffrent back pressure in the exaust?
What about the exhaust lobe on the cam on that same bank?
Old Apr 12, 2006 | 07:41 PM
Originally Posted by Ari G
You stole my idea
no the pressure would be equalized
Old Apr 12, 2006 | 09:50 PM
Ari G's Avatar
Why would you say that???
The small one can´t exhale as much as the big one so there must be more backpressure where the small one is
