Advanced Engineering Tech For the more hardcore LS1TECH residents
convert from water to mercury.
Old Apr 10, 2006 | 05:33 PM
firefighter's Avatar
Default convert from water to mercury.
If you have a measurement in mecury what is the conversion to water and the other way around. Thanks in advance I did a google and couldn't find it.
Old Apr 10, 2006 | 06:16 PM
red_pacu1's Avatar
Wouldnt the measurements be the same? Ex: if i had measured a cubical inch of mercury it would be the same as measuring a cubical inch of water. the dimentions are the same. an inch is an inch. What might be different is the weight difference between the two. one cubical inch of mercury weighs heavier then a cubical inch of water. you cant say that a pound of merc is heavier then a pound of water because both are equal to a pound. the quantity however may be different. can u elaborate on the question there maybe something leftout.
Old Apr 10, 2006 | 06:29 PM
P Mack's Avatar
1 inHg = 13.59 inches H20
red_pacu, he's asking about measurements of pressure.
Old Apr 10, 2006 | 06:44 PM
red_pacu1's Avatar
lol...oh.
Old Apr 10, 2006 | 08:45 PM
See I'm doing the Dyno Sym to try and get my injectors sized right for an old SBC (I'm just trying to get close before it gets tuned) and the mfg talks in inH2O and the program talks inHg. Also I wasn't thinking on the wave length of pressure I was looking for flow. Thanks guys.
Old Apr 10, 2006 | 08:58 PM
H8 LUZN's Avatar
Here is a great site.. I use it all the time at work.
www.onlineconversion.com
Old Apr 10, 2006 | 09:08 PM
After alot of messing around with the program I realize it has a converter in the program sorry if I put you guys out thanks again. I'm a lil de-de-deee
